Flasher relay location
Results 1 to 6 of 6
Thread: Flasher relay location
    Very Active Member Shadow721's Avatar
    Apr 2013
    Staten Island, New York
    Default Flasher relay location
    Can someone tell me where to find the flasher relay on the bike? I need to replace it. Thanks
    Here for a good time, not a long time.
    Very Active Member cdn109's Avatar
    Tiny, Ontario
    Quote Originally Posted by Shadow721 View Post
    Here is a picture of where to find it. Are you replacing with a stock relay, or are you modifying to a flasher relay for LED signals?
Name:	Flasher relay.jpg
    Debadged, Debeavered, Tach Relo, Custom faceplates, Stealth LED Turns, Gregg's Sidemount, Coastal Moto Wheels, 280mm, 2" Bones, Freedom P. Exhaust, Derby, Axle Spikes, Irate Grill, Chin Scoop, Croc Seat, Lots of Chrome
    Apr 2013
    Replacing for LEDs. I can't make out where that is in the pic.
    Very Active Member some 9's Avatar
    Long Island, NY
    Behind left side cover in front of the battery box.
    Mods:New Motor Upgrade/Genesis Rims Mez 280/160 Tires/ 300 Swing Arm/Cobra Swepts/Chrome Spike Filters/Yani Shiki 2" Riser/All Braided Cables/Chromed Entire Handle Bars/Kuryakyn Iso Grips-Iso Boss/S9 Led Kit/Raw Design Led Front/Rear Signals/Corbin Seat/Air Ride/Low And Mean Busa Kit-Front Fender/Gothic Side License Plate/HID Head Light/Heal Tech TRE/Chrome Calipers/Cycle House Down Under Kit.
    Apr 2013
    Got it.. Thanks guys
    Tiny, Ontario
    Right on....
    I used a Street Magic M109 Flasher Relay from Custom Dynamics. This seemed like a better choice than some of the standard load equalizers because it's capable of controlling the rate of flashing for both front and rear turns simultaneously.
