Cobra PowrPro Tuner - question
3K views 10 replies 7 participants last post by  thevili
#1 ·
I am looking at purchasing the Cobra Fi2000 PowrPro tuner for my 9. I have a 2010 M109R (I am in Canada). The part# I found online for the 2010 is Part#92-1845AT. I was looking at the Cobra website and it states "NOTE: THIS PRODUCT IS FOR U.S. SPEC MOTORCYCLES ONLY.". Can I run this with my bike? Are Canadian versions of the 2010 M109R any different from a "spec" perspective than U.S? This may be a stupid question but don't want to drop $500 to find out the thing don't work on my model. I have ordered some new intakes so I need to figure this out asap. Thanks
#4 · (Edited)
It is the correct model #. I have it on my 2011 bike! Did you find a good deal on that PowrPro??
Seems like best price from these guys:
https://www.twocycleguys.com/showPr...zfcxVjRSz_MbgNGXf768kP_-Y1t5Cq3tbcxoCCZrw_wcB
#6 ·
Has been discussed in the past. I believe the conclusion was that the Canadian 109's are like the US (non-California) 109's. I think in North America, on California 109 have O[SUB]2[/SUB] sensors...
#8 · (Edited)
I guess it's a difference between the C109 and the M109. I apologize for the confusion...
According to the VLR1800 service manual (C109):
  • Canada and USA (except California) : DO NOT have the O2 sensors
  • The rest of the world and California : have the O2 sensors
Hopefully this clarifies things a bit (at least for the C109)
page 1A-1 (page 70 in PDF document):
OXYGEN SENSOR SIGNAL (For E-02, 19, 24, 33) : Air/fuel ratio is compensated to the theoretical ratio from density of oxygen in exhaust gasses. The compensation occurs in such away that more fuel is supplied if detected air/fuel ratio is lean and less fuel is supplied if it is rich.
page 0A-5 (page 18 in PDF document) (bold = O2 sensors):
Country and Area Codes
The following codes stand for the applicable country(-ies) and area(-s).
Code Country or Area Effective Frame No.
VLR1800 K8 E-02 U.K. JS1CT111200100001
VLR1800 K8 E-19 E.U. JS1CT111100100001
VLR1800 K8 E-03 U.S.A (Except CA) JS1VY54A 82100001
VLR1800 K8 E-24 Australia JS1CT111300100001
VLR1800 K8 E-28 Canada JS1VY54A 82100001
VLR1800 K8 E-33 California (U.S.A) JS1VY54A 82100001
#9 ·
Cobra Fi2000 PowrPro ordered
Do we happen to have a video of the install process of the Fi2000? I walked through all the pages in the How To section but could not find one. Little worried about doing this since I have never attempted to install one in the past. Any help, links would be greatly appreciated.
Ted
#11 · (Edited)
Ted
Here, even thou this is older model, it is gonna be same like this:
http://www.m109riders.com/forums/showthread.php?t=67296
But the Cobra instructions in the box are very good..
#10 ·
Follow the directions when you get it. Its easy. Tank had to come off. You do not have to remove the airbox. A long pair if needle nose pliers are helpful. Its basically plug and play. If you have a problem PM me. In preparation for the install run the gas down in the tank. I did mine with a full tank. I like to do things the hard way.
