How to make your own trailer full universal coupling
Results 1 to 9 of 9
Thread: How to make your own trailer full universal coupling
    Very Active Member avago's Avatar
    Oct 2012
    New Zealand
    Default How to make your own trailer full universal coupling
    This thread is for those who aren't comfortable or just don't like the standard tow ball and cup hitch for their bike trailers.
    Having had a trailer roll completely on to its lid whilst being towed by a motorcycle, I am one of those people.
    It is designed more for the light trailers but could be made beefier if your tow a heavier trailer such as a camper.
    FYI A lot of outback campers in Australia run similar systems.
    Start with a piece of flat steel and some steel tubing plus two 10mm galvanised bolts plus nuts and split pins
    Mine are 25mm x 3mm and 25mm dia tube.
    I have not mentioned specific dimensions as they will vary according to how big or small you want to make it.
    Cut in to pieces like so.
Name:	2014-10-26 11.59.06.jpg
    Loosely assembled pre-welding
Name:	2014-10-30 14.11.04.jpg
Name:	2014-10-30 14.11.17.jpg
Name:	2014-10-30 14.07.13.jpg
    Welded and had a lick of paint.
Name:	2014-11-12 16.43.09.jpg
    I have welded a square plate on the front because my coupling is recessed in to my drawbar.
    The two nuts welded to the side of the tube are so it can be bolted in from the underneath of my drawbar.
    Quite often I have seen the tube just welded to a steel plate which is either bolted or welded to the drawbar.
    Purely up to you how you do it. This is just o give you guys some ideas.
    A man would be more interested in a womans mind if it bounced gently as she walked.
    Oct 2012
    New Zealand
    Continued...
    This is how it looks when installed.
Name:	2014-11-04 19.49.10.jpg
    And this is the trailer it is installed in. (Not quite finished in this pic. WIP)
Name:	2015-01-12 17.02.13.jpg
    Here is another coupling along the same lines to help with other ideas.
    To use this coupling, all you need is a hitch with a flat tab with a hole in it.
    Put a bolt through with a split pin through it and you are good to go.
    Good luck and hope you find this useful.
    Aug 2010
    Great NW
    Default One I made, Just grease the ball.........
    and 480lb trailer I built........... pulled nice.
    and tape on wheelie wheels, when I nailed it LOL
    Oct 2012
    New Zealand
    That's a great set up you got there. Nice solid hitch too. 480ib is not bad for something that size.
    I've got a custom hitch being made at the moment.
    This was the first crack at it but the engineer wouldn't listen and it was too weak.
    I'll show you the new one when its done.
    Sent from my portable microwave emitter
    Sep 2012
    Long Island, NY
    Avago the set up is nice and at first when you look at it, it looks like small little bolts and wonder how that little shyt is gonna attach to a trailer but after when you see it you understand how big it really is. Nice work. Rick your set up is awesome bro I like the way you attached it to the 9 and wow I can't believe you really pull that thing with the 9, the only other thing is
    lol
    Oct 2012
    New Zealand
    Quote Originally Posted by some 9 View Post
    lol
    Cheers mate.
    Very Active Member Copper's Avatar
    Jun 2011
    Vancouver, BC, Canada
    No car tire in that pic, Rick....and I've seen you when you've nailed it, no wheelie wheels required - like straight out from a cannon
    ((sorry for the jack, just had to comment...)
    Good luck with the trailer!
    Very Active Member STL-TIGER's Avatar
    Jul 2009
    Raleigh (Apex), NC
    Just because you can doesn't mean you should. After seeing what happened to one rider here I don't think I'd ever pull a trailer with a bike.
    Oct 2012
    New Zealand
    Quote Originally Posted by STL-TIGER View Post
    Fair enough. I had a trailer roll after one wheel dropped in to a huge pot hole.
    Was on a big trip round our South Island and there had been huge amounts of rain and lots of land slides. Where the slips had been cleared there were big holes left in the roads. Came round a corner and realised too late to stop so just guided bike between holes. Felt the tug on the bike as the right wheel dropped in the hole and watched it go over in my mirrors. Having a full universal coupling like I have shown saved my ass. Didn't upset the bike at all. Just flipped the trailer back over and away we went. Funniest thing were the expressions of horror on the faces of the people in a car coming toward us lol. I think they were more scared! Haha
