The REVO Generation V Integrated Knight Rider LED has been one of the proudest products of REVO and there has been five generations since its launch in 2008. The first generation Knight Rider LED was just a series of LED light bowls connected together and added with a swing marquee design. When the second generation came out, we began to compile the swing formula so that it could have different patterns to select from. When it came to the third generation, we started to integrate turning signals and braking lights into our product; moreover, we updated the LED strip to 5050 LED chip and that contributed to colorful patterns. Moving on to the fourth generation, we still used the 5050 LED strip; however, this whole strip was built on one IC panel, that is to say, what was behind all those LED light bowls were hundreds of IC chip. Meanwhile, the motherboard was updated form 16 bytes to 32 bytes, and we were able to produce the higher level RGB color which was different from last generation's seven color options, and also it came with both turning and braking lights.
G5 KnightRider LED advances in motherboard and IC; therefore, you would find its color more brilliant. In terms of the patterns, we modify the unnecessary one and add few more high-order RGB color patterns. Experienced numerous modifications, the G5 KnightRider LED is pretty mature now, you definitely do not want to miss it. www.revo-cycles.com
