I just purchased my '09 M109 special edition. I just checked the oil an it appears a quart low. What oil do you guys recommend for the beast?
From the factory, or if a Suzuki dealer has worked on it recently, 10W-40 synthetic of Suzuki's house brand.
Myself, I use their 20W-50 petroleum oil. I've never had a lick of trouble with the clutch or transmission on my 06 using that oil. A friend who has run the synthetic in his 06 since new, has had to have the second gear rebuilt twice. Not saying the oil is a cause or a help, just sayin what's worked for me.
You'll most likely receive quite a few different opinions on this one but the most common would probably be...Mobile 1 Racing 4T Full-Synthetic Motorcycle Oil, AMSOil Full-Synthetic Motorcycle Oil, or Suzuki/OEM Conventional Oil.
2007 M109R LE: Kuryakyn Scythe II Mirrors, Xtreme Revolutions Stage 3 Intake Kit, Xtreme Revolutions Floorboards, Rivco Tach Relocation Kit, Rivco Brake Pedal, RIS Designs Grille, Corba Fi2000 POWRPRO, Heal Tech SpeedoHealer, Heal Tech Gi-Pro, Back Off XP Module, Highway Hawk Taillight Cover, Swint LEDs, Greggs Side Cover Accents, Hard Krome 3" Big Straights Exhaust, Raw Design Storage Box, Suzuki Crash Bars, Suzuki Gel Seats, and much more
Would Honda brand oil hurt this bike?
No it would not. No oil brand should cause harm to any motor, no matter whom manufactured it. There may be exceptions, such as I heard the newer vettes required the use of Mobil 1. But they are truly exceptions. Most vehicles you can pour whatever oil you have in there, just be conscious of the oil's weight.
This statement isn't entirely correct. Where "wet" clutch systems are present, a special oil, that does not include friction modifiers is necessary to keep from causing damage to the internal clutch plates. The Suzuki Boulevard M109R utilizes a wet clutch and therefore, requires a "motorcycle-specific" oil blend.
Make sure you checked your oil properly before you top it up
very slightly modified
I do like that 'motorcycle specific oil' does it come from dinosaurs that rode Harleys?
And it's the friction modifiers you want to avoid. Teflon/PTFE or whatever they add to the high mpg oils doesn't really go well with clutches. Having seen the pictures of all the dry clutches I'm not even sure the 9 is a 'proper' wet clutch. Certainly the driest wet clutch I've ever seen.
And to the OP my personal choice is a known brand Semi-synthetic. Shell Rotella I think it is I always used in the USA.
+1 on the Shell Rotella. I use it in all of my bikes.
- My memory's not as sharp as it used to be. Also, my memory's not as sharp as it used to be.
- God grant me the senility to forget the people I never liked, the good fortune to run into the ones I do, and the vision to tell the difference.
Mobile 1, 15w50
what your suppose to put oil in these things
Besides additives that have friction reducing ingredients, you want to stay from oils marked as "energy conserving" oils as they may contain friction modifiers which can mess up a wet clutch. If you absolutely want to use a wet clutch compatible oil you will look for the JASO certification which means it's approved for a wet clutch.
Let me make it simple for you. Open the owners manual to the oil section. Look at the rating it says to use and then buy whatever you want that meets the rating. If that don't suit you I use Mobil 1 V-Twin in the 9 and Racing 4T in my Honda. Whatever brand you can come up with someone on this forum uses it. Good Luck and don't overcomplicate it.
Just look at the back of the bottle, ensure the API rating does not say Energy Conserving
NO NOOOOOOOOOOOO Not another oil thread......LOL I use
Shell Rotella T6 for me too. Full synthetic at a reasonable price, and I've had no problems with it. I've got 38,000 miles on mine and most have been with this oil.
wanna ask about tires?? LOL Sorry, I can't help maself.............
I'm gonna try to get one of these batches on ma 9. WISH me luck
You drinkin again Nemo?
5,000 posts and I don't own a 9!
http://www.zeemaps.com/map?group=484949
Facebook http://www.facebook.com/groups/590949870932032
that;s standard procedure here................. spellcheck is a POS also..................
Blue Murder - Blue Murder (1989)
https://www.youtube.com/watch?v=RF_zBTKYOx0
Valvoline 4 stroke conventional...
Now it's more confusing
One who leads with no followers is merely taking a walk
Anyone use Klotz fully synthetic? I'm running Klotz 10/40w in my 9. The transmission seemed clunky on the oem suzuki oil that the dealer used. I switched to klotz per service managers recommendation also a friend. The 1st to 2nd gear change seems to be smoother after the oil got in there and cleaned up all the moving parts. about 300 miles. Has a very unique smell also and looks like strawberry concentrate. My friend also told me to stay away from ams oil. however that is what my father runs in his 9. No issues so far. I know this is another oil thread and everyone has different opinions Just seeing if anyone has ran Klotz and thier experience?
