new pads
Results 1 to 16 of 16
Thread: new pads
    Aug 2012
    mishawaka,IN
    Default new pads
    i changed my brake pads yesterday at 22000 the stock ones were toast
    i went with the ebc HH sintered pads got them off ebay total 110
    fairly easy to do and feels better than new
    08 c109rt
    bully k&n stealth intakes tre crash bars highway pegs, tank bra
    Hk sideburners mustang seat tsukayu batwing tsukayu jumbo strong bags
    Very Active Member smg3d's Avatar
    Jun 2010
    Quebec City, QC, Canada
    And you will notice that your brake area will be much cleaner now (the original produced a lot of dust).
    And they will last at least twice longer than the stock ones (over 40,000 km, and the front EBC-HH likely still have 10,000 km)
    (For the rear... still with the original pads after 61,000 km... likely still good for 10-15,000 km)
    2008 C109RT Black-Gray / bought June 2010 with 600km / 61,000km as Sep. 2014
    Clean front end / TRE / Spike intakes / K&N filters / Wideband O2 / Drilled pipes / 266mm Darkside Federal 595 / Tacho / LED signals & relay box / Mustang fender bib / Rear fender in spike shape / 23 cu.ft. trailer / ISO-Grips / Scythe Mirrors / 20+ Skulls. TODO : Horn / Paint / More spike intakes / Better bags / ECU hacking...
    Aug 2012
    mishawaka,IN
    ohh the brake dust on the stock pads are terrible
    cant keep nothin clean
    08 c109rt
    Very Active Member avago's Avatar
    Oct 2012
    New Zealand
    Quote Originally Posted by big jeff View Post
    Yeah all the dust started when they stopped asbestos being allowed in brake pads and they put some other rubbish in them. Don't last as long either.
    Sent from my portable microwave emitter
    A man would be more interested in a womans mind if it bounced gently as she walked.
    May 2006
    I don't care for the funny sounding/feeling noise/grind they make when applying the brakes other then that they were much better the stock and much less mess to clean off of your wheels!
    Dec 2014
    Lakeland, Florida
    EBC makes good brake pads. I use them on all my bikes. The HH sintered pads are harder than the stock organic type OE pads and are harder on brake rotors. The can sometimes chew up a set of rotors. I once installed a set of HH sintered pads to a heavy metric cruiser I once owned. I had to replace the front rotor and go back to the softer standard pads. The HH sintered pads damaged the brake rotor about three thousand miles after I installed them.
    2008 Suzuki C109R (sat on showroom for 3 yrs)
    Factory Pro Evo shift improver
    Power Commander III w/Exhaust Servo System REMOVED with Servo Buddy
    Exhaust baffle plate drilled modification (eight 1/2 inch holes)
    Gman Timing Retard Eliminator (TRE) Cobra FATTY Highway Bar
    Very Active Member Gold5th's Avatar
    Dec 2010
    Athabasca, AB, Canada
    I changed my pads last year as the front were totally toast, the new ones didn't even fit (don't recall what brand I put on). I had to fight to get the calipers back on.. then I think I warped the rotors :(
    Active Member
    Sep 2014
    Courtenay Canada
    Default New Front Brake Pads
    I have just put new pads on my C109RT. At best, they make a hissing sound while moving or braking. At worst, they heat the rotors up so much that the bike can hardly move even when the brakes are not engaged. I have cleaned the pads and rotors several times with brake fluid and reduced the amount of fluid in the master cylinder. Still, no change. I need help please. Cheers Patrick
    Feb 2010
    Quote Originally Posted by Pats Boulevard View Post
    Please tell me that you are using brake cleaner, not brake fluid to clean them. Brake fluid is mineral or silicone based, depending on which type you use, and neither is meant to be a cleaner. In fact, brake fluid will make brakes grab. If you've actually cleaned them with it, get a can of brake cleaner and try cleaning them off. You may have to replace them depending on how deep the fluid has penetrated the pads. The rotors aren't a problem once they get cleaned.
    If that doesn't work, you may need to bleed them. Air in the system expands when it gets heated and can shove the pads out enough to apply the brakes.
    The hissing at low speed is normal. I use the HH pads and they sound like you are running through sand.
    Active Member
    Sep 2014
    Courtenay Canada
    Quote Originally Posted by Board Support-1 View Post
    My mistake. I used brake cleaner. I will try the leading edge bevel and hacksaw cut. I have bled the system so I am at the last option. I am not so concerned about the pads hissing, it's the brakes stopping the bike when they have not been engaged by me.
    May 2006
    It may be possible that one of the piston seals either broke or is out of place or there may be some gunk/dirt buildup between the piston cup and the caliper wall. If this is the case it may be causing the piston to hang up which is causing the pads to continually rub/ride the rotor which is causing the fluid to overheat which is causing it to expand thus causing your problem with the brake grabbing without you engaging them. Your best bet will be to remove the pads then pull the pistons to clean and check that your seals are undamaged and seated properly.
    I have a few questions. Did you remove the master cyclinder cover before pushing the pistons back into the caliper? Did you push the pistons completely back into the caliper?
    Very Active Member DeafM109R's Avatar
    Apr 2012
    Kyle, Texas
    I'm in the same boat. I push the Pistons completely back to make room and bleed the brake fluid out to get the air out. Then put new DOT4 in the master cylinder. I kept on pumping the brake lever to get the fluid going and still haven't felt the tight on the lever/brakes. Help?
    If you want to be happy for a day, Drink.
    If you want to be happy for a year, Marry.
    If you want to be happy for a lifetime, Ride a Motorcycle.
    Very Active Member 1r's Avatar
    May 2011
    cincinnati ohio
    I apologize in advance if this sounds anything less then helpful . First since your sign pic is of a m109 not the c109 that has the linked brakes . When you " bleed the line " did you have the bleeder valve open ? With a hose of some sort going into a container to capture the fluid and prevent air from going back into the line ?
    2008 c109rt . wolo air horn, gman tre, gman bully ,kuryakyn cruiser pegs, tsukayu jumbo strong bags ,tsukayu 6x9 bat wing , LED head light, driver backrest, k&n air filters, m109 tach, and electric cruise control ahhh !
    Aug 2012
    mishawaka,IN
    No. My stock pads made all that brake dust, which causes caliper pistons to hang up. Which causes pads to chew up rotors. Brake cleaner and a small brush around the piston area.
    I followed the manual for flushing front and rear and linked. It takes awhile. I also used a hose and small cup. Mostly so not to get ANY brake fluid anywhere. Corrosive ****.
    Fyi I mostly use rear brakes. 28000mi rotor looks great. The ebc hh pads are awesome. Cleaner thicker no hang ups.
  17. #15
    May 2011
    cincinnati ohio
    Big jeff , I was in refrence to the comment from deafm109 . That's if you were responding back from my comment . I f so I apologize, I need to be better about hitting the quote button rather then the respond one ( when needed )
  18. #16
    Aug 2012
    mishawaka,IN
    I was agreeing with you
