How to install a hidden garage door opener
Page 1 of 3 123 LastLast
Results 1 to 30 of 72
Thread: How to install a hidden garage door opener
    Very Active Member avago's Avatar
    Oct 2012
    New Zealand
    Default How to install a hidden garage door opener
    Step one - Remove Suzuki badge.
    Use heat gun and warm up badge. Use low heat so you do not melt anything.
    The badge is held on with a soft double sided tape so you are just trying to soften it.
    Gently pry off badge with a very thin screw driver or knife.
    Step two - Remove console from bike.
    Undo the bolt holding the console to the tank.
    Remove side covers and remove bolt holding an in place.
    Slide tank back and unplug console.
    For the lazy just remove the bolt, lift up and slide protective sheet over tank.
    Step three - Prepare
    Here is a pic of most of the things you need. The switch is a micro switch design to go on circuit boards.
    These can be obtained from any basic electronics shop.
    Open the door remote and find the two tracks that go to the button. Solder a wire to each track, drill a hole in the remote control cover and feed the wires out. You may need to super glue the remote back together depending on what you have.
    Solder the other ends of the wires to your button/switch. TEST!
    Mark the center of the rectangle the badge came out of and drill a hole big enough to allow the switch through. Mine was 7mm.
    Step four - Install
    Get a mate to hold the console up (for the lazy one's like me who did this in place ) and use hot glue to fix the switch and remote in place.
    It now looks like this from the top
    Now use your double-sided foam mounting tape and cut pieces to fit the back of the badge.
    Leave a circle in the middle clear so it does not stick to the button when in place.
    This allows the foam to compress and only push the button when pressed .
    Stick badge in place and bolt console back in.
    Done!
    You now have a completely concealed garage door opener. Well done!
    Very Active Member The Chief's Avatar
    May 2009
    Napa,CA
    Great idea!
    Political correctness is a doctrine, fostered by a delusional illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
    Very Active Member Chops's Avatar
    May 2011
    Oz
    Brilliant !
    Sep 2012
    Long Island, NY
    Very Nice.
    Very Active Member Canadian's Avatar
    May 2011
    Duvall, WA
    Damn wish I had seen this last year before I converted my flash to pass button to do the duty. Great thinking.
    2010 M109R LE - Hard Krome American Classics, gel seats, debeavered, cobra case guards, cobra std sissy bar, kaoko cruise control, Fi2000r, spike intakes, X-TRE, 250 rear
    Very Active Member candyapplered M109's Avatar
    Jul 2012
    Patterson, NY
    Thats an awesome idea!!! Thanks for sharing!!!
    Very Active Member Tigz's Avatar
    Feb 2009
    Matteson, Il
    Pretty cool...it sure us better than mine.
    Sent from my LG-E980 using Tapatalk
    Very Active Member PHKsRIDE's Avatar
    May 2011
    San Diego, CA
    Very clever dude, I love it!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Very Active Member GRUMPY's Avatar
    Feb 2012
    Denham Springs, Louisiana
    Now that right there is pretty ingenious! Excellent work sir!
    BOTM - January 2016
    2011 M109R LE....Not quite stock!
    I'm only GRUMPY when I'm not riding 1SICK9!
    Very Active Member Candypaintdrip's Avatar
    Aug 2012
    Minnesota
    Wow I'm impressed!!! One of the better How to's in a while. Can't wait to do it
    Very Active Member fatazz109's Avatar
    Sep 2013
    Lake Charles, LA
    Very clean.. Great job..
    Very Active Member TORQ's Avatar
    May 2008
    SOUTHWESTERN NEW HAMPSHIRE
    Thumbs up
    Absolutely Phenomenal, I don't care what your wife or, mistress say's about you That best thing I've seen on this Forum in quite sometme!
    Owner of The Rarest M109R, THE 2006 Burple. THE ONE Suzuki Promised, TO NEVER make again!! Do to IT BEING, JUST to FAST for the General PUBLIC!
    May 2011
    San Diego, CA
    I wish this board was more modern and allowed for "likes" because I would definitely give the OP a "like".
    MoCo Maryland
    Quote Originally Posted by PHKsRIDE View Post
    Thumbs up is just as good.:thumbup:
    sent from my Galaxy S3 from somewhere outside space
  17. #15
    May 2011
    San Diego, CA
    Yep, I agree, however I like being able to identify active members that contribute positively as voted by forum members (i.e., number of likes). It's like seller ratings that help identify good/honest folk).
    Ok. I took this thread off-topic. Apologies to the OP.
    Oh, and:thumbup::thumbup::thumbup::thumbup:
  18. #16
    Very Active Member waytootall67's Avatar
    Nov 2012
    Calgary Alberta Canada
    House of Chrome peg extensions, Full cut gel seat, CWI back rest,
    Cobra solo rack, Tsukayu hard bags, Gman TRE
    Factory installed GO FAST STRIPES
  19. #17
    Very Active Member Todd109's Avatar
    Jun 2013
    Indianapolis
    Nice job, grabbed it and made a pdf of that one before its gone.
    Thanks for sharing !!
  20. #18
    Very Active Member geofftl1000r's Avatar
    Nov 2012
    UK, London
    Nice work, thanks for the write up.
  21. #19
    Active Member
    Mar 2009
    Northern California
    I like it. Excellent!!!
  22. #20
    Very Active Member Captnpirate's Avatar
    Oct 2011
    Port Saint Lucie, Florida
    Now see, I just covered it up but I can remove that which I will be doing when I install my own door opener! Great write up!! Thanks for sharing
    Go Big or Go Home
    '07 RED -
    Cycle House Big Air intakes, Debadged/Debeavered, PC III, Kuy grips and pegs, 50 watt driving lights, 260 Metz., sport windshield, chrome wheels, Gen III Knight Rider, Drivers Backrest, Dragon Tail Light, Derby and Side Lic Frame, +2 risers, 5" Cannon.
  23. #21
    Very Active Member MADDMOE's Avatar
    Jun 2010
    MT VERNON, NY ( More than likely im on the bike, i could be anywhere )
    Glad i stumbled onto this thread, just did mines and hid the button . Now i dont have to stop and figure out what pocket that damn remote is in
    You only live once so , dont talk about it, be about it !
  24. #22
    Very Active Member jimmy450r's Avatar
    Nov 2007
    Eastern Kansas
    very cool, but now I have to put in an electric garage door
  25. #23
    Very Active Member NSRiar's Avatar
    Jun 2012
    Surrey, British Columbia
    Smart.
    dont have electric garage either. I gotta manually lift it
  26. #24
    Jul 2008
    Forney, TX
    That is pretty slick!!
  27. #25
    Very Active Member olmanswift's Avatar
    Sep 2013
    ID
    Very good idea and write up. Thank you!
  28. #26
    Very Active Member Blackey's Avatar
    Sep 2012
    Seattle
    I love it. Very ingenious. Question: How long does the battery normally last?
    09 "Blackey" - Swept, Engine Case Guarded, Derby'd, Iso Gripped, Badged, Boned, De-Shuddered, Beavered, Risen, Cabled
  29. #27
    Oct 2012
    New Zealand
    Quote Originally Posted by Blackey View Post
    Years! But if you install it with battery compartment accessible as shown you just undo the one bolt to lift the console to get at it.
    Sent from my pocket size microwave emitter.
    A man would be more interested in a womans mind if it bounced gently as she walked.
  30. #28
    Oct 2012
    New Zealand
    Quote Originally Posted by Sly Dog View Post
    Very cool, you definately made a mod that allot of people could and probably will use.... thats rare anymore for the 109. Especially since you did it in such a simple and functional way that is very appealing.
    A suggestion for people doing this in hot climates, use an epoxy instead of hot glue... I know it would be neccessary here in Vega$
    Great job!
    Sly
    Cheers mate. I'm glad everyone likes it. I agree that the hot glue is not the best in the world and others may be better. Given the bike shakes the tank a bit it might even be better with a more flexible choice like something silicone based. I suppose people will have to work out what is the best for their environment.
  31. #29
    May 2009
    Napa,CA
    Great job!
    Sly
    Hot glue fails in a high heat area? was not aware. You've experienced problems? or are you speculating?
  32. #30
    Very Active Member lcollins's Avatar
    Sep 2013
    Atlanta
    I love this mod! Great creativity
    Debaffled~Yana Shiki License Plate, Derby, Blade Levers, Anodized Exotic Kickstand~Knight Rider G4~Raw Design Stealth Rear Signals~Raw Designs C.A. Front Turn Signals~HH Taillight Cover~Ferreus Combat Skull Grille~Mean Cycles Chin Spoiler~X-TRE~Gman FI Controller & Stealth Intakes~Rex 3D Mirrors~R.I.S. Diamond Cut Grips~Progressive 465 W\RAP 1" Lower~Cobra Swept~Rick Mayer Custom Seat
