The Widest Tire on a C
Results 1 to 12 of 12
Thread: The Widest Tire on a C
    Very Active Member silveradols's Avatar
    Oct 2009
    Wewahitchka, FL
    Default The Widest Tire on a C
    What is the widest tire that we can run on our C's?
    Can u run a 280mm without installing a new swingarm?
    2008 Suzuki Boulevard C109RT: HardKrome Velocity Pro Lites 2-1 Exhaust, Tank Bib, GMan TRE,Gman Bully controller, Speedo Visor, Everything Debadged, Front fender bra, Stock risers with GMan risers, Large ISO highway pegs with floorboard mounts and coming soon front, rear fender mud flap and lots of chrome accessories. Almost forgot Cobra 1 1/2 engine bars and Cobra driving light bar. Dual exhaust coming soon.
    Oct 2009
    Wewahitchka, FL
    Anybody
    Nov 2012
    IL
    Quote Originally Posted by silveradols View Post
    Not sure about that but one suggestion I have is to visit your local motorcycle shop and see if you can get one of their junk tires in the size you want to put on the rim and try it. You should be able to get that tire for free since they have to pay to throw it out. Also, you can change that tire in your garage so it will not cost you anything and you will know what fits and what doesn't. I did that when I switched to 17" rims on my old vmax. It takes a bit of time and work but it's free and you will know for sure what works and what doesn't. Comes in handy especially when you can't find anyone that has done that in the past.
    just remember to mark your original tires (with chaulk) before you take it off (I use a valve stem as reference) that way you can put it back on exactly the same way so you don't have to worry about re-balancing it.
    Very Active Member grandpatractor's Avatar
    Jul 2008
    Grantsburg WI
    Car or bike tire?
    What is the widest bike tire on a 16 inch rim?
    J.D.
    AKA Big King Daddy $hi+
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by mzycki View Post
    So far, I haven't been able to find any wider 16 inch tires, other than what is already on the C.
    Nov 2009
    ARLINGTON, TX
    No, you can not. The 280 tire will not work on the C109 without using some sort of aftermarket swingarm. A friend of mine tried to make this work last summer, and it was just not possible. Nothing lined up properly, as he had to try using a 17" wheel. Nothing was compatible. However, you may have an idea that he and the specialty mechanic/fabricator in our area didn't think of.
    Good luck!!!
    Oct 2009
    Wewahitchka, FL
    I wonder if a swingarm from an M will fit on a C?
    Oct 2009
    Wewahitchka, FL
    Never Mind, they want swap. Heck, they look completely different and have 2 completely different part numbers.
    I'll bet I could move up to a 260mm tire, if I could find one in 16 inch.
    Very Active Member NSRiar's Avatar
    Jun 2012
    Surrey, British Columbia
    C has smaller rear tire, wow. we have 18 inch on M
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by NSRiar View Post
    Yes, the C has a 240mm tire on a 16 inch wheel and the M has a 240mm tire on an 18 inch wheel.
    Very Active Member RadGen's Avatar
    Apr 2009
    Yucaipa, CA
    Default Metzler
    the metzler gives you a wider tire because of the ratio (45 vs 50)
    Suzuki windsheild, Cobra Fatty Bars, Suzuki LightBar, 8" Risers, Tank Bra, EMGO® "Big One" mirrors, Hard Chrome Big 3" Straights, Tsukayu hard bags, Russell Cycle Products Custom Saddle, Custom world rack and backrest, G-bushing, Bully FIC and TRE, Sage Brush Designs engine guard chaps. Metzler 880 tires
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by RadGen View Post
    Right. I'm probably going to switch to the Metz's to get the lower profile tire.
