new speaker sound system prototype. revision 3
Page 1 of 2 12 LastLast
Results 1 to 30 of 54
Thread: new speaker sound system prototype. revision 3
    Sep 2011
    FL
    Default new speaker sound system prototype. revision 3
    as you guys have all seen, I love my tunes.. my original goal was to build something marketable. well revision one sat way on top the bars. Result, only good behind a vstream. revision 2.. also sat on the bars, but looked a bit mickey mouse-ish without the vstream. now revision 3 is done, and while it has some imperfections and it not ready to be reproduced. I thought I would send out some pictures to get your thoughts.
    What you will see is a refabricated narcell, and modded fairing stay, and a new liner. what did all this prototype fab work create? space for a rockford 300 watt RMS amplifier.. 2 6.5 inch Focal component speakers. and still leave room for a HD ballast. what do your really see now? a slightly wider narcell thats pushed forward a bit and down a bit back to stock height and angle. to make sure your lighting is still spot on. finally what would be the benifit to all this change. a stereo you can hear at more than highway speeds, but not change the look of the bike.... MUCH.
ID:	75656Click image for larger version.
ID:	75657Click image for larger version.
ID:	75658Click image for larger version.
ID:	75659Click image for larger version.
    more pics on reply post.
    Sep 2011
    FL
ID:	75661Click image for larger version.
ID:	75662Click image for larger version.
ID:	75663Click image for larger version.
ID:	75664Click image for larger version.
    keep in mind this is a rough system, and will get more tweeks to improve a few things and make this a smooth look and direct bolt on application. it already is direct bolt on, but it needs a few things.
    oh one more benefit i made in this design was adding secondary mounting locations for use of the vstream if you would like to use it. thats why there are more holes. the bottom two spikes are pending a new spacer to change the angle to allow a better fit.
    MoCo Maryland
    Sorry man, all those "spikes" remind me of a dog collar. Not feelin the look at all. However, if you like it, that's all that really matters.
    Sep 2011
    FL
    well clearly spikes are a optional look. regular screws would be included as the spikes are threaded into spacers adapters, and the top two were added for my collar appearance. and are not functional holes.
    Very Active Member Wjduke's Avatar
    May 2012
    live in Fall River, Mass.
    In all fairness B, the spikes aren't the main attraction....don't think they're part of the speaker system! If they are, then I agree! Hey, my bike still has badges and isn't de-beavered, you must love that!
    Klock Werks Flare windshield...Baker Hand Wings...Grip Puppies...passenger pegs removed.
    Rivco anodized highway pegs...12V/USB outlet...Superbrite LED flashing brake lamps.
    MoCo Maryland
    Quote Originally Posted by Wjduke View Post
    At least you took off the reflectors but yeah.
    Jul 2012
    Oz
    You guys get pretty thirsty over there , or is that an ashtray on the right side of the handle bars . Hmmm spikes !
    Very Active Member AWESOME109's Avatar
    Jan 2007
    San Diego
    Nice idea!!!!! That's the best speaker mounting I've seen for a 9. Are you planning on making kits and selling these. I am not someone who cares about having music on when I'm riding but I like the how you accomplished your goal
    Sep 2011
    FL
    First off, ty for staying on topic. Secondly... If i can get the reproduction costs cheap enough after its tweaked, yeah ill be offerin these if i get more interest
    Apr 2011
    JERZEY
    I have to say out of the 3 versions you have done I def like this one the best. I like that it is (mostly) concealed and if it can be heard well at highway speed then it's a winner. I do agree that an optional mount other than the spikes should be available. Nice job
    MoCo Maryland
    Any chance you took pics in the fabrication state. I'd like to see how it got to the finished product.
    Sep 2011
    FL
    I guess i should point out that the bottom two holes are stock locations and could use stock screws. The upper sides have frame supports added purely for vstream mounting and i suppose could also not be drilled for reproduction, as well as the top holes are purely non functional. So in theory if u have no need for windshield mounting which adds a bit more clearance for taller riders for buffeting the unit would look closer to stock
    Very Active Member Top Shelf109's Avatar
    Sep 2008
    Gulf Coast
    Default I like this version
    I don't care for the spikes but I like the fact it flows with the bike. I would be interested in this version.
    Very Active Member RUBZERK's Avatar
    Jul 2008
    Wrightsville, PA.
    "You cant argue with my 9mm..........well you can, but you'll end up bleeding alot"
    RUBZERK = Are You BZERK
  17. #15
    Very Active Member LOFLYR's Avatar
    Mar 2012
    Boise, ID
    Looks good, how do they sound pointed down like that? Still pretty clear?
    2007 M109R Pearl White - Mods: Gutted/Debaffled Exhaust, Yana Shiki 2" Bones, TDE TRE, V-Stream Windshield, Debadged, Debeavered, Kury Rear Tails, Tach Relocated, Kury ISO Grips, Kury Transformer Throttle Boss, Baron Bullet Bar Ends, Kury Switchblade Pegs, Cyclehouse Levers, Boulevard Mirrors, Rivco Highway Pegs, Corbin Seat, Metz 240/160. ​RIP
  18. #16
    Very Active Member jimmy450r's Avatar
    Nov 2007
    Eastern Kansas
    is this an option for those who have relocated the tac to the headlight? I love the idea of having "hidden tunes"
  19. #17
    Sep 2011
    FL
    No i havent and since this is a part i ha hoped to reproduce a a marketable idea i wouldnt see that happening
  20. #18
    Sep 2011
    FL
    Quote Originally Posted by LOFLYR View Post
    Ill be making a video clip shortly
  21. #19
    Sep 2011
    FL
    Quote Originally Posted by jimmy450r View Post
    I believe there can be enough room, ide love to see someones mod or stock version in the bucket... If i could get my hands on the parts or a local rider to let me take a peek, i could probably add a knockout or cut out option to the inner lining.
    These are the kind of things i needed to hear to see not only whos interested, but what obsticles and options need to be offered... Before going forward with final model for reproduction.
  22. #20
    Very Active Member CDM76's Avatar
    Jul 2011
    Grande Prairie, Alberta
    Quote Originally Posted by AWESOME109 View Post
    Not bad. I like the idea. Dont think would look right with my R2 though. Whats the final size and wattage of each speaker ?
    Posted on my BlackBerry Z30.
    __________________________________________________ _______________________________
    And the modding begins ....... Will it EVER end ?\
  23. #21
    Sep 2011
    FL
    Quote Originally Posted by CDM76 View Post
    You could use this system on a r2, but u would need to purchase a headlight housing and the chrome part of the narcell. Which u prob bought the r2 because u prefered its narcell. As far as specs, rockford 300pbx2 amp... 300 rms 2 channel. With focal 6.5 coax with 160 rms each. These are very clear speakers is why i went with them
  24. #22
    Sep 2011
    FL
    Default December Update
    Well ass you guys have seen in another post, my bikes down and doing a few crazy changes.. more coming, but i thought i would update everyone on the speaker chamber revisions. Work and the rest of life slows it down a bit in the custom world for me.. but here goes.
    UPDATES: per the feedback:
    1. Added the tach into the faceplate (on reproduction this will be a knockout in case you dont want to relocate your tach)
    2. The outer Narcell Replacement will only use factory location style screw holes (yes the two you are used to)
    3. Newest update faceplate is now a sealed inclosure with complete Fairing Stay replacement and headlight locators (you no longer will need to have a metal fairing stay, use of all factory mount locations are used in the new version)
    4. Complete bolt on replacement, just relace the wire looms using the disconnects..and reroute brake line accordingly and sell off your OEM parts
    heres a update. since i have been working alot, i havent had a ton of time to work on this. im going to show you the inside of the chamber back which basically locates the headlight eliminating the need for the fairing stay, then i will show you the prefit into the modded narcell which will be a little wider to allow the speaker width, basically it removes that ledge on the side of the headlight and make a continuous flow. i will also show you the addition of the mount lower tree bracket thats been reinforced for strength. and you will also see the basic first sand, and fitment. theres a bit more to do with final smooth and fill, and to shape the mount bracket, and then add the top support locators.. and drill the holes in the notched out area for the wiring. but its getting close to be able to have a mold made, i just need to make those final parts and make sure it road tests great , then its ready for reproduction.
  25. #23
    Nov 2007
    Eastern Kansas
    coming along nice, can't wait to see finished product. Be so cool to have hidden tunes
  26. #24
    Mar 2012
    Boise, ID
    Looks really good, looking forward to seeing the final product!
  27. #25
    Very Active Member z71cad's Avatar
    Dec 2007
    channelview, texas 77530
    count me in for one when your done
    Robert Booty
    "I WOULD RATHER BE AN OPEN SINNER THAN A FALSE SAINT"
  28. #26
    Active Member AZDRAGON's Avatar
    Oct 2012
    Arizona
    I am way snobby with speakers and sound in general *disclaimer*. Good sound is subjective I know and I don't want to threadjack. BUT...I am wondering if you modeled the speakers/enclosure? I am just wondering because I have heard motorcycle stereos that sound like 3 cats, 1 monkey, and squirrel fighting over rocks in a garbage can.
    The nerd inside of me thinks there is potential and starts dreaming of resonating frequencies and the inefficiencies of sealed enclosures (more power more power more power). I like the concept, just wondering how it sounds and if there was any techy stuff behind what you are doing. Very cool project BTW.
  29. #27
    Very Active Member WineNine's Avatar
    Nov 2012
    Napa California
    [QUOTE=AZDRAGON;1713818]I am way snobby with speakers and sound in general *disclaimer*. Good sound is subjective I know and I don't want to threadjack. BUT...I am wondering if you modeled the speakers/enclosure? I am just wondering because I have heard motorcycle stereos that sound like 3 cats, 1 monkey, and squirrel fighting over rocks in a garbage can.
    Just moved my tach from the bars to the light housing...it's only money I guess. How's the sound at highway speed?
  30. #28
    Very Active Member rockey's Avatar
    Jan 2008
    Music City USA
    Had to look at the pics twice before I saw the speakers. Think it looks nice. Like several others though. Not fond of the spikes.
  31. #29
    Sep 2011
    FL
    Quote Originally Posted by AZDRAGON View Post
    ill address this as simple as i can so most will understand. Freeair mounting in our applications are impractical due to relativey no mounting space to separate the audio. What does this mean? In a trunk of a car its considered freeair as there is only a panel separating the speakers and a trunk providing a not truely sealed enclusure. Now onto the reason for needing a enclosure on our motorcycles? 1. Attempting to use a plate for free air proved to be not enough surface separation causing popping if u used any mid to low range frequencies. Hence the reason most batwing or small bar mount systems sound very tinny as your post implies. So now ive have painstakenly designed a application that will utilize the space and have secondary functions that will allow the speaker to have a chamber. This chamer will allow for more power clearly as sealed enclosures do require more power to drive the speakers but also allow for a crisper response. Now i know te chamber size wont be spec for running subs and thats not its intended purpose.... If u want low low end plan on har saddle bags and bigger class d amps and a larger stator basket and probably a cap and additinal battery. Once i can test this as i said worst case ill need to use pollyfill to trick the speakers that they are in a larger cabinet. Or the possibilty i could dow fire port tune the chamber but none of that makes this reproduceable in a affordable product because that would require me to suply each amp and speaker pair and tune them specifically for their proper ohm readings and frequency tune.
  32. #30
    Sep 2011
    FL
    [QUOTE=WineNine;1713824]
    When injad this just as the plate i could only run lower power to it but at that it ws clear with a full face around 80-90mph. Ill know more after my backs back together and can test the chambered version. Without a helmet my dumbo ears catch a bunch of wind but u can still make out the music. And of course if u run a windshield you will hear alot more. My group loves when i ride with them as no one uses headsets any longer when im around
