What clutch shudder does to your clutch parts. - Page 7
Page 7 of 7 FirstFirst 1234567
Results 181 to 201 of 201
Thread: What clutch shudder does to your clutch parts.
  1. #181
    Very Active Member snickaren's Avatar
    Aug 2012
    Sweden
    Quote Originally Posted by dandiele View Post
    Can anyone confirm that the pin has to be readjusted if parts #6 #12 and #13 are replaced? I thought I had read NOT to touch the adjustment at all when doing this....Thanks guys!
    When you do have everything apart, why shouldn't you adjust it at the same time? It's not rocket science (I made it) ;-) .
    Adjust it, then you know that it's OK, that's what I did anyway. Best of luck to you
    KEEP RIDING HARD
  3. #182
    If your in there I think you should readjust the pin. Some have used 3/4 of a turn out some stick with what the book says as 1 turn out.
    What happens is once you adjust the clutch cable at the lever, and then you run out of adjustment, you will have to adjust the cable at the lower end and then readjust at the lever. But once you are done with adjustments at both ends you will have to go into the clutch "again" because you didnt adjust it when you added new parts. Hope this kinda explains it a little.
    But like I said, its super easy to adjust, just go ahead and do it.
    Also when you adjust the pin, make sure on the other side of the 9. The arm where the clutch cable attaches to is up all the way before adjusting the pin. On mine I had to manually pull it all the way to the top because the spring that is on the arm will only raise it so far.
  4. #183
    Jul 2013
    United States
    OK I will give it a shot. I had read absolutely not to touch it because it was a giant pain in the rear to get set right again. I printed out directions that I think future put up so I'll follow that. Gonna have a friend help me do all this at his house so hopefully I get it set the first time. Thanks guys!
  6. #184
    Where did you read that to not touch the pin at? Youll be fine. If you get stumped just post up and someone will be around to help.
  7. #185
    Jul 2013
    United States
    https://www.m109riders.com/forums/sho...=153581&page=2
    This thread made me nervous about messing with it. I've read it is very touchy so I figured I'd be better off not touching it. But if its not as difficult as they made it sound I'll see if we can get it done.
  8. #186
    Ok, read the thread your talking about. Huff and I was discussing in that thread. I think you might be confussed on the "no adjustment" part.
    Here is the short version. If you are going to open the clutch up to get rid of the shudder by grinding the pin "only" then you dont have to adjust the pin.
    Now with that said, when you get in there depending on how you have ridden it you might find that some of the steels and or fibers need to be replaced.
    I didnt see which year/model you have but if you replace ANY of the parts in there you will NEED to adjust the pin.
    When I did mine I changed out the affected parts. The #6 drive plate, wave washer & seat.
    For me its a little harder to find "N" but not to difficult.
    So the adjustment of the pin really depends on if you are replacing anything or just grinding the pin down and throwing it back in there.
  9. #187
    Jul 2013
    United States
    OK cool. I've only had it since late last summer so I don't know how the previous person drove it. I've been fairly easy on it from take offs. Especially once the shudder started. I'm planning to replace those 3 parts so probably best to adjust the pin. Hopefully we can get it right the first time!
    Its an 08 with I think about 10k miles.
  10. #188
    If your replacing the parts then, yes you will need to adjust it.
  11. #189
    Jul 2013
    United States
    Sounds good, I will give it a shot. BTW, do you know were the best place is to buy the parts ill need? best price, fast shipping. And also, could you recommend a good after market clutch kit? I don't think mine needs replaced but if if its not to expensive I may just replace all of the plates and the #6 #12 and #13
    Thanks so much for the help!
  12. #190
    I dont know where you are located in tge US based on your profile. I relaced my clutch last year because I was nearing 50k mile.
    You want to stick with OEM for clutch parts. Some have had some success with aftermarket kits and some havent.
    O'Neida Suzuki was the cheapest when I bought my clutch parts. If you are only buying a couple parts it might be quicker and cheaper to get them from your dealer.
    If you replace the steels, fibers, #6, #13, #12 it will run around $300, FYI.
  13. #191
    Jul 2013
    United States
    Gotcha. I'm in Des Moines Iowa. Probably best to just visit the Suzuki dealer. Thanks for the info. Since I'm only at 10k miles I highly doubt I'll need a new clutch so that's good.
  14. #192
    You might be suprised. Based on how the clutch basket gets very little lubrication, some plates may be blued from the heat. My steals where and that why I just ended up replacing mine.
    Just inspect them by the book and you should be ok.
  15. #193
    Very Active Member Gold5th's Avatar
    Dec 2010
    Athabasca, AB, Canada
    From what I've found the fibers go for about $40/ea (need 6), steels are $15-16/ea need 5. the #10 plate is $30ish. #6 plate is $15ish
  16. #194
    Very Active Member RChow's Avatar
    Nov 2010
    NW Florida
    I just finished doing this mod and I would say it was pretty tough for a non-mechanic type like myself. But thanks to the outstanding guidance from guys like FutureR and Huff in this thread, I was able to replace the three clutch parts, grind down the adjustment push pin (used my 6in Ryobi bench grinder) and properly adjust the push screw (although it took me 5 tries). I was a bit overzealous in grinding the push pin...went to about 5mm wide rather than 3. If this causes a future oil issue, I'll post that.
    The shudder is gone! So nice to no longer have to pre-load the clutch when starting from a stop. My #6 drive plate was severely etched and burnt. The original wave washer looked ok though. The entire clutch basket was dry.
  17. #195
    Very Active Member freestylejski's Avatar
    May 2007
    Chicago West Burbs
    27000miles getting some shutter at times.... time for this mod!!
    Let's Ride!!!!
  18. #196
    Member muvybuf's Avatar
    Bloomiington, MN
    Default Fixed my clutch shudder - Thanks guys!
    My 2008 C109RT developed the clutch shudder this summer with 13,200 miles on it and I nursed it along for several months.
    After reading the posts on this multiple times I ordered the parts and got it fixed.
    Just thought I would add my thoughts and findings to this list.
    I ordered a new pin so that I could take my time grinding it and have a spare "in case" I screwed it up. I didn't realize at the time that meant that the adjustment pin would require adjustment! But between the shop manual and the forum posts it wasn't a big deal.
    After sliding a spare tire (no wheel) under the exhaust I took the whole thing off by removing the 4 bolts into the head, two small bolts holding the exhaust valve pulley in place and the two big bolts holding the bracket that both exhaust pipes are connected to. I read this in another post and seemed to make the job go faster. Had to loosen the bolts for the foot rest to get the lower exhaust pipe free. Lowered the exhaust to the tire and dragged the tire out of the way.
    Removing the springs and plates were as expected and I made sure that I kept them in the right order and orientation.
    After replacing the three plates/washers everything went back together in reverse order and I installed the new ground adjustment pin. Torqued the spring bolts to 7 ft lbs and spent several hours scraping gasket off the motor surface and clutch cover. I was as careful as I could be pulling the clutch cover off, but the gasket ripped so I needed to clean off the old and install a new one. Since it was an aluminum surface I got some "plastic razor blades" that worked but were not particularly effective. I used Permatex Ultra Black in stead of the Suzuki 1207B (or something like that) in the two spots on the gasket the manual suggested.
    Because the shop manual didn't provide torque values for the clutch cover I searched around the forum in vain and just snugged them up pretty well with a 1/4" socket wrench which was suggested on one of the treads I read.
    The biggest issue I had was adjusting the adjustment pin because I installed a new one and used the old threaded rod and lock nut. As suggested in the manual I pulled up the lever on the left side of the engine and held it in place with a bungee cord. The manual suggested backing the threaded rod out 1 turn after sensing resistance. Some of the posts I read suggested 3/4 of a turn out. Several people posted that this had to be done several times before they got it right which seemed odd as you are just determining when the clutch is pushed out or disengaged. Never having done this before I wasn't sure what felt resistance meant and now I believe I understand why some people had problems. I felt resistance when the adjustment pin touched the plates, backed the rod out 1 turn and when I put the clutch cable back on, it wouldn't disengage the clutch (couldn't see the pressure plate move). I believe that I was feeling resistance from one or two or three plates but they weren't "all" pushed together. So I tightened the threaded rod until I saw the pressure plate move and the clutch start to disengage. I loosened it up and did that several times until all the plates were right up against each other. THEN I ran the threaded rod into the pin until I felt pretty good resistance and then backed the pin out 1 turn. After attaching the clutch cable again things seemed to work fine.
    The only small issue that I have as a result of what I did is that the clutch engages much sooner than it used to. If I were to take all this apart again I would only turn the threaded rod back out 3/4 of a turn or more. Just not one full turn. I think that would be perfect.
    I've ridden the bike several times now and the clutch works well.
    Thanks for everyone that posts their information and experiences on this forum. Your help is appreciated and very valuable.
    Dave
    -Dave
    Bloomington, MN
    2008 Blue & White C109RT - Cobra Fatty Freeway Bars - Kuryakyn Longhorn Highway Pegs - Cobra Light Bar
  19. #197
    Active Member AWD's Avatar
    Aug 2012
    Brasov, Romania
    Quote Originally Posted by BradSmith View Post
    I don't think its needed for 2010 or above. Had clutch shudder on my 2008 C109 at 14,000km
    2010 C109 had 32,000km with no issues
    2012 M109 with 27,000 km no issues so far....just put in Mobile 1 so will see if any issues with clutch friction (lack thereof)
    A good friend of mine has a 2012 M109. He had the same clutch failure, and needed pin mod.
  20. #198
    Very Active Member kshackelford's Avatar
    Jan 2017
    Ky
    So the adjustment pin mod, that is something different than push pin mod.
  21. #199
    Quote Originally Posted by kshackelford View Post
    They are one and the same. Its the adjustment pin for the clutch.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  22. #200
    Jan 2017
    Ky
    Gotcha appreciate it
    Sent from my SM-G955U using Tapatalk
  23. #201
    Hi Matt, i would love to see the images in this post. It says they are blocked. Thanks!
