Handlebar Risers - Page 3
Page 3 of 3 FirstFirst 123
Results 61 to 77 of 77
Thread: Handlebar Risers
  1. #61
    Very Active Member silveradols's Avatar
    Oct 2009
    Wewahitchka, FL
    Ok, I got two different answers. Are the stock riser bolts M10 or M12??
    2008 Suzuki Boulevard C109RT: HardKrome Velocity Pro Lites 2-1 Exhaust, Tank Bib, GMan TRE,Gman Bully controller, Speedo Visor, Everything Debadged, Front fender bra, Stock risers with GMan risers, Large ISO highway pegs with floorboard mounts and coming soon front, rear fender mud flap and lots of chrome accessories. Almost forgot Cobra 1 1/2 engine bars and Cobra driving light bar. Dual exhaust coming soon.
  3. #62
    Oct 2009
    Wewahitchka, FL
    Are the handlebar riser bolts an M10 or M12?? I've received 2 different answers.
  4. #63
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by RadGen View Post
    I'm running with 8" pullbacks. I had to reroute my controls but they work fine and I love the position of my bars.
    I know I'm reviving this old thread, but what size bolt did you use and did you have to add a spacer to make the bolt hole smaller in the triple tree top plate?
  6. #64
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by silveradols View Post
    Never Mind. However, will the C50T or C90T handlebar risers work on the C109RT?
  7. #65
    Oct 2009
    Wewahitchka, FL
    why don't the C50T or C90T aftermarket risers use a metric bolt, instead of the harley 1/2"-13 riser bolts
  8. #66
    Oct 2009
    Wewahitchka, FL
    Since my stock risers and handlebars have the little grooves in them, will the smooth Drag Specialties or Baron Custom Accessories aftermarket handlebar risers still work?
  9. #67
    Very Active Member 1r's Avatar
    May 2011
    cincinnati ohio
    basically the reason that most after market risers use the 1/2 inch 13 thread bolt , becuse there is more money to be made in the masses of those bikes then trying to do a single metric style unit Baron makes a very nice looking unit but it is very costly and not better and geting you any closer to your bars then you have now . about as far as i can try to figure the stock riser " called handle bar holder by the manual " has a rise of about 3 and 1/3 of an inch . with you having g mans extensions you should be at 5 and third . Now keep in mind since the bars went up and they are mounted on a raked tee facing you as it went up the extra 2 inches they also did come back some to you at the same time , probaly a little less then 1/2 an inch . but that extra height also gives you more room to try to rotate the bar up or down for more comfort . that can help get the bars closer or a little farther away . I am only about 5'10" and with spinal deterioration setting in very badly that extra inch can mean a lot when out for 500-700 mile ride .
    and i can not say for sure give me a week or so i can confirm but i believe its a m 10 . and if you look at the pics in the manual there is a sleve in the tree with that bolt , it shows it in the illustration but makes no comment as to a name or anything else about it.
    and yes to the best of my knowledge you can use a clamp style that is smooth on the inside with the textured grip on the handle bars , i have seen some that use a sleeve to change sizes but I would NOT recomend trying any of those
    2008 c109rt . wolo air horn, gman tre, gman bully ,kuryakyn cruiser pegs, tsukayu jumbo strong bags ,tsukayu 6x9 bat wing , LED head light, driver backrest, k&n air filters, m109 tach, and electric cruise control ahhh !
  10. #68
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by 1r View Post
    Actually, the stock bolts are 12MM. I have several different lengths of 1/2" bolts. However, I'm going to try the ones that came with my new risers. I have the 4" rise with 1 1/2" kickback risers. They actually bring the bars closer to me than the stock risers and GMan riser did. According to the instructions the new studs are 1/2" on one end and 12MM on the other end with a 14MM shoulder to fit the hole in the upper triple tree plate. I'm going to work on the later today. I'll get pictures, if I can get them mounted correctly.
  11. #69
    Oct 2009
    Wewahitchka, FL
    handlebar riser bolt problem solved. They are nice and tight now. I'll get pics tomorrow. I'm
    taking them for a test ride Sunday and then I'll know if I need a small extension or not.
  12. #70
    Oct 2009
    Wewahitchka, FL
    Risers are fully installed and torqued down. It doesn't look like I'll need a 1 inch extension afterall. I'll see how they feel tomorrow.
    Here's some pics: They'll look better washed.
  13. #71
    Very Active Member GMan's Avatar
    Jan 2007
    Renton, Washington
    Let me know how they work. When I tried similar style several years ago they felt very unstable. I could move the bars and the front tire stayed straight, worse yet the front tire moved and the bars didn't.
    Admittedly I was in some high speed twisties in the low triples when this happened. I don;t like the small contact patch of the risers on top of the triple tree, but maybe it's just me and an isolated experience.
    2008 C109RT, Stage 3 Bully Controller, Performance Intakes, GMan Performance Exhaust, ATRE, High Performance 'GBat' Battery, GBushing Shifter Bushing, Handlebar Riser Extender, Corbin Heated Seats, Custom Leather Tank Guard / Fender Bra / Windshield Bag from GMan Industries!
  14. #72
    Oct 2009
    Wewahitchka, FL
    I didn't get far. I went to top off the tank and my battery died However, the risers work pretty good. There's a little movement front to back, but none side to side. The best part is that the bars come back into a much more comfortable position for me.
  15. #73
    Oct 2009
    Wewahitchka, FL
    Quote Originally Posted by GMan View Post
    My risers work real good. There's a slight movement from front to back, but none side to side. They bring the bars back enough, so that I'm sitting up straight and able to utilize my backrest better.
  16. #74
    Oct 2009
    Wewahitchka, FL
    Is there something I can do to these risers, so they don't flex forwards and backwards? They're fine from side to side.
  17. #75
    May 2011
    cincinnati ohio
    The reason for the fore n aft moment in the bars is most likely due to the "sleeve " that passes through the uper tee . Thats i cased 8n rubber .It is slightly longer then the thickness of the uper. And your replaced riser is siting on it . Not being directly on so you can try to grind down the sleeve that the riser bolts pass through ( good luck doing that without causing damage ) .. or you could do what I did . I put a large stainless washer under my riser with a hole wider then the sleeve . I have just a very small amount of play in mine but it's due to the rubber of the sleeve .
  18. #76
    Oct 2009
    Wewahitchka, FL
    I'll try some bigger washers then.
  19. #77
    Active Member
    Jun 2016
    Tampa Bay, FL
    Quote Originally Posted by ELI View Post
    I know stock is metric 10mm?I got the gman units, came with longer bolts, the stockers were a bitch to get out!!!
    NVM, I got it installed yesterday!
    Attached Images Attached Images
    Bought on 06/18/2016 for $6,500, with 1,864 original miles on the odometer (and I'm the third owner! Da fuq were the first two thinking?)
