Forcewinder and Spike styled intake on the cheap - Page 6
Page 6 of 6 FirstFirst 123456
Results 151 to 180 of 180
Thread: Forcewinder and Spike styled intake on the cheap
  1. #151
    Very Active Member Canadian's Avatar
    May 2011
    Duvall, WA
    Warning: The kit I got came with bolts for the rod mount to the head that only went in a couple threads with the spacer in place. I highly recommend getting longer bolts to go in more threads. When I was messing around trying to align where each spike was pointing I ripped the couple outer threads off one.
    2010 M109R LE - Hard Krome American Classics, gel seats, debeavered, cobra case guards, cobra std sissy bar, kaoko cruise control, Fi2000r, spike intakes, X-TRE, 250 rear
  3. #152
    Apr 2007
    west coast canada
    Quote Originally Posted by Canadian View Post
    Yes I had the same issue.Will need a longer metric Screw.LOL
  4. #153
    May 2011
    Duvall, WA
    If I remember right the bolt that came with mine was 35 long so I bought a couple 40s and 45s. The 45s worked so no I have a tonne of threads holding it on. Luckily I only stripped a couple so no real harm done.
    Does anyone have any pics of what they did for the 2 tiny screws mounting the spike?
  6. #154
    Very Active Member Mrg's Avatar
    Nov 2009
    San Antonio, Tx
    For those wanting the spike intake and making their own backing plate?.. Here's some more part info
    http://www.biker-direct.com/fuel-air...les-for-harley
    Or be different try one of the ones found on page listed below:
    http://www.harleycustom.com/Prod-BSL...ers-7-744.html
  7. #155
    Very Active Member scottr63's Avatar
    Sep 2006
    D'Iberville, MS.
    Default Uneven
    Quote Originally Posted by jimmy450r View Post
    look kick butt from sides but it is noticeable that one side is lower than the other and one is farther forward......
    not bad for that price but it would drive me crazy knowing they where off
    I run with these intakes, and one is lower than the other. I figured what the hell, one can only see one side of the bike at a time. I consider it an non issue, with no preformance issuses. And the look great
    Cobra Dragsters Long DeBaffled Chromed front and rear rims Chrome covered lower fork/front calibers Chrome covered rear caliper Chrome coverd Drive shaft Chrome covered swing arm Kuryakyn Flame Grips and Foot Boards Arlen Ness Mirrors Carbon Fiber Fuel Tank Bra LED Tail Light ATRE Gear Emulator Dual Spiked Air Cleaner Intake Filters Billet Backrest m109 Fender Eliminator Bracket Plate Mount Fi2000R Processor Speedometer and Tach cover plates
  8. #156
    May 2011
    Duvall, WA
    So what's the consensus on the spike vs. the open filter? Is the spike with the smaller filter significantly more restrictive than the open K&N? Is it worth forking out the exta $$ for the filters if I already have the spike setup?
    Which is the preferred filter for looks and/or surface area? SP3459 or RC3680
  9. #157
    Very Active Member Candypaintdrip's Avatar
    Aug 2012
    Minnesota
    I have Only had the spikes on my bike and it's a love / hate thing. Performance wise who knows. The bike is a monster no matter what and can't tell a difference between these and my old Holly IntAkes . My friends love the spikes but a times I think they are too much, and might buy so e [email protected] -air filter cones to fit on them. Can't give u a performance opinion on the two yet, good luck
  10. #158
    Apr 2007
    west coast canada
    The bigger the filter area the better IMHO.But earlier in this thread on another subject,those with OEM crash bars cannot use the RC3680 on the right side unless you make up a new baking plate.I studied the way the OEM crash bars are mounted and could not come with a pleasing mod that would look Good.So I have ordered two Shorter K&N RC9080 Filters.I will taKe Pics soon and post for those interested.
  11. #159
    Aug 2012
    Minnesota
    You can fit the [email protected] filters on the tube of the spike intakes. I lost the link but very cheap to switch back and fourth. Beats buying the Tornado intakes for &700 plus
  12. #160
    Aug 2012
    Minnesota
    Default Forcewinder and Spike styled intake on the cheap
    Quote Originally Posted by ta-kid View Post
    Both my intake back plates made by ( Damguy ) you can fit crash bars. Both my intAkes fit dead even both up and down and left to right. It's the only way in my eyes. Off center would drive me nuts!!!
  13. #161
    Apr 2011
    JERZEY
    Quote Originally Posted by Candypaintdrip View Post
    Just a question because I have never seen anybody mention it. Is it a pia when its time to change the spark plugs? Looks like you would have to remove the spikes to get the front jug covers off.
  14. #162
    Aug 2012
    Minnesota
    Quote Originally Posted by NJDEVIL View Post
    Keith I am not sure. I have never changed my spark plugs. The whole intake set up consists of two Allen bolts, and u disconnect the breather tube on the back and pop out the guide plug. Maybe a minute and a half to fully drop each side, very simple
  15. #163
    Aug 2012
    Minnesota
    So no it wouldn't be difficult, you would never need to take off the spike portion, it all can come off as one piece if you need it too
  16. #164
    Nov 2009
    San Antonio, Tx
    Post
    I've post lots of options for this setup... Start at page 1.
  17. #165
    Apr 2007
    west coast canada
    Pics of my new K&N filters that are shorter for the stock crash bar clearance.These are round instead of oval.
Name:	P1000603 (1024x768).jpg
ID:	122041   Click image for larger version.
Name:	P1000604 (1024x768).jpg
ID:	122049   Click image for larger version.
Name:	P1000605 (1024x768).jpg
  18. #166
    Very Active Member carnivor's Avatar
    Mar 2010
    bendigo,vic.,australia
    Looks great mate :)
    Sent from my GT-I9505 using Tapatalk
    Enter the beast for it has taken thee to its den and shared its power !!!!!
  19. #167
    Nov 2009
    San Antonio, Tx
    Please post your K&N filter number?
  20. #168
    Apr 2007
    west coast canada
    Quote Originally Posted by Mrg View Post
    RC9080
  21. #169
    Nov 2012
    Australia
    Ridiculous question... The original spike mounts with two grub screws..how do you mount the pod filter? ...long time listener first time caller here btw..have posted in the gallery but.
  22. #170
    Apr 2007
    west coast canada
    The filter has a rubber mounting collar that is flexiable enough to remove and reinstall for cleaning when needed,even with the crash bars on.
  23. #171
    Nov 2012
    Australia
    Thanks mate. Sounds simple enough.
  24. #172
    Apr 2013
    NY
    Default Spike intake
    Just ordered my spike from Ebay but will use that RC9080 K&N filter.I think it looks very aggressive. Running FI2000 with V&H Propipe.
  25. #173
    Very Active Member Mo H's Avatar
    Apr 2012
    Michigan
    Anyone know if and where I can purchase the shims in the picture?
  26. #174
    Aug 2012
    Minnesota
    Quote Originally Posted by Mo H View Post
    I bought my spike intakes like that on ebay, and the parts you are looking for came with the kit. Those are the gaskets
  27. #175
    Apr 2012
    Michigan
    Yeah, mine came with them as well I'm wondering if I can buy them separately. I would like to replace one of them if possible.
    Sent from my LG-D801 using Tapatalk
  28. #176
    Active Member
    Mar 2013
    Detroit
    Tag for reference!
    after 4 years... well worth the wait, she is home!
    6-12-13
  29. #177
    Dec 2016
    Durham NC
    Where can I find the force air intake kit for a 2008 Suzuki M109R without the spike filter covers?
    Sent from my SM-G920V using Tapatalk
  30. #178
  31. #179
    Active Member StitchsLoft's Avatar
    May 2018
    Wellsville, NY
    Does anyone run these XP Stage III Utra Air Flow Kits?
    http://phatpartsoutlet.com/suzuki-pa...a-flow-intake/
    Found Video too...
    https://youtu.be/vwFprmsOTSk
  32. #180
    Very Active Member 4fun's Avatar
    Apr 2018
    Spring Hill Florida
    older thread I know, But My question is my answer I think but want to make sure, so I buy Spike Intake Air Cleaner Filter For Suzuki Boulevard M109
    kit from e bay for 99.99 and I want to use the
    K&N RC-9080 Universal Clamp-on Air Filter and I need 2 @52.99 ea. then
    K&N RF-1001DL Dry Charger rain sock Air Filter Wrap, 5in Tall, Blue @41.98 ea. that should do it right. total 289.93! I am in
    Freedom Performance Exhaust, Exhaust Servo elimator,O2 sensors Removed,PC V,Grasshopper seat rest,Rear seat backrest,USB Phone charger,Pair valve blocked off, LED light kit with remote, derby cover M109R,JDM switchbacks. JDM H4 headlight,M109R swing arm cover,M109r brake cover,Tank bra, Spike air intake, Quick disconnect rear seat back,quick disconnect cowl, Powder coating all over, Factory Pro Evo shift star
