Forcewinder and Spike styled intake on the cheap
Page 1 of 6 123456 LastLast
Results 1 to 30 of 180
Thread: Forcewinder and Spike styled intake on the cheap
    Very Active Member Mrg's Avatar
    Nov 2009
    San Antonio, Tx
    Cool Forcewinder and Spike styled intake on the cheap
    For those looking for an intake mod. The parts listed below will give you two different intake looks. Forcewinder or spikes, have both looks for approx $120.00+ less than the Forcewinder kit.
    - http://store.knfilters.com/search/pr...x?Prod=RC-3680. (2) w/shipping $82.00 or
    - http://www.autozone.com/autozone/acc...ntifier=161028. or
    - http://www.meancycles.com/store/part...?partID=216349. Tornado cone style filter
    - http://www.motoleather.com/48-0515.html. Force winder show off cover (flames)
    - http://www.phatperformanceparts.com/...p/5061-100.htm.
    - http://www.bikerperformance.com/forc...its-p4294.html. Forcewinder show off cover (Bad Ass)
    - http://store.knfilters.com/search/pr...Prod=RC-3680DK $21.00 per + tax (K&N dry sock) or
    - http://www.debrix.com/Forcewinder-bl...p/31091-k1.htm $27.99 each +tax (Forcewinder dry sock) or
    - http://www.outerwears.com/proddetail.asp?prod=75598 $16.45 per + tax (colored dry sock)
    - http://motors.shop.ebay.com/i.html?_...506.m270.l1313 $299.00 shipping included.
    You may be able to find the spike intake on ebay for less than I paid.
    Approx $423 or less for the entire setup.. Two different looks for the price of one.
    Note: Psycho Moto has 4 sets of Spike Air Cleaner Intake for $179
    http://cgi.ebay.com/ebaymotors/Suzuk...ht_2677wt_1054
    That brings the price down to approx $303
    More dry charger socks
    http://www.useforce.com/product-cate...-charger-sock/
    http://www.partsmotorcyclebikes.com/...rcewinder.html
    Installation instructions and photos courtesy of Scott109:
    Note: Rod installation... B goes on the left w/ the B on top and connected to the engine. A goes on the right w/ A on the bottom and connected to the engine. The tip of the A points to the engine.
    Quote Originally Posted by scotty109 View Post
    Got mine today, they are just as good as th epics on ebay. However i still think they are chrome. they are to shiny.
    1st Take the tank off (if you use a long allen the tank removal is not required), Remove the filters and fit away.
    The first adapet will go straight into the exsisting hole of the rubber grommet .Loosen that clamp right off they are tight as a nuns nasty to push on, lube will help.
    Since A and B rods are a tad bit short, you will have to bend the tabs flat on the mounting brackets (this the the pice with the rubber grommet. The tabs are designed to fit between the engine fins but for this install the tabs are not needed.
    Place the Second piece on with gasket
    you will see one hole has no thread on it, This is for the black rod and use the longest bolt and nut with it ,i bent mine the slightest bit as it was against a hose , And just place the other end of the rod onto the bolt that is already there holding the standard bracket.There is spacers provided but you dont need them.
    I took that bracket off and just used that bolt you can see, as the bolt that came with it was to short. the two rods are market A and B, Dont know why, obviously they dont know either or they would have instructions.
    On the right hand side mine wasnt able to go into the rubber grommet like the left side did, I just removed that bracket, just fit the Rod the same as the other side.
    As Bobby mac said they do not sit equal ,the right sticks out further then the left and more forward,So if your Anal forget about them , if not go buy them they look the goodsand for the price you cant go wrong.
    will post pics tomorrow was to dark by the time i finished fitting them up.
    cheers scott
    Had a few people asking about fitting these up.
    first picture is the left side see the rod? that bolts to the motor head take out the original mount .
    2nd picture same side differant angle
    i used the exsisting original mount ,just left it there and pushed the stub into the rubber grommet
    now the other side ....same as the other straight into the motor head .
    again same pic differant angle this one kept jumping out of the rubber grommet which held the original air filter on so i put a ball of jb weld on the end of the stub after i pushed it through the hole. it aint going anywhere now.it is a bit hard to see here but do the same as the other side and use the bracket , you might need to reshape them a bit to fit also might need to bend the rods a little . just takes time.
    Dont forget to get rid of the grub screws holding the actual filter spike on,they are useless as **** on a bull.
    i just used a stainless bolt and nut to hold them on.
    Nov 2009
    San Antonio, Tx
    Other filter cover options:
    http://www.lowandmean.com/index.php?...d=98&Itemid=60. - low and Mean K&N filter covers and screens
    May 2006
    Wow it looks like low and mean sells that same airkit for almost $700
    Nov 2009
    San Antonio, Tx
    Yep... Way too rich for my blood...
    Very Active Member Gsxrrobb's Avatar
    May 2011
    Kandahar, Afghanistan
    How long have you been running this mod? Any performance info? Any other issuses than the JB weld fix?
    Out of every one hundred men you send me, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make good the battle...... Ah, but the one....one is a warrior.... and he will bring the others back.” -Heraclitus
    Nov 2009
    San Antonio, Tx
    I've been running it for two months now... With no issues.
    Lots of other board member are running the spike intake. The only thing I did was to remove the spikes an use the same filter as the force winder kit. I get the look I'm after at a BIG savings.
    Very Active Member g9r's Avatar
    Aug 2011
    Tennessee / North Carolina Mountains
    Would like to see some more pics of each side and different angles if you get the chance.
    Nov 2009
    San Antonio, Tx
    For photos: https://www.m109riders.com/forums/album.php?u=32491
    Let me know what you think.
    Very Active Member Bones M109R's Avatar
    Sep 2008
    Blue Springs Missouri
    I would like to see a pic straight on from the front. Are they level with each other when viewed from the front?
    Nov 2009
    San Antonio, Tx
    I'll have to post a new pic for you tomorrow.
    Very Active Member Highway's Avatar
    Jun 2008
    South Florida
    I say its a Bargain at under $194.00 shipped...
    http://cgi.ebay.com/ebaymotors/Motor...item2567aca5bd
    Phat & Low " Thats How I Roll ".
    May 2011
    Quote Originally Posted by Bones M109R View Post
    Same here....looks good so far, but I am wondering what it looks like head on.
    Nov 2009
    San Antonio, Tx
    New pic are loaded
    https://www.m109riders.com/forums/album.php?albumid=2923
    Very Active Member jimmy450r's Avatar
    Nov 2007
    Eastern Kansas
    look kick butt from sides but it is noticeable that one side is lower than the other and one is farther forward......
    not bad for that price but it would drive me crazy knowing they where off
  17. #15
    May 2011
    Quote Originally Posted by jimmy450r View Post
    It would drive me nuts as well. I love the look from the side! If someone finds a fix for this I would be all over it.
  18. #16
    Nov 2009
    San Antonio, Tx
    The one side being lower .. I can fix. But the kit is as designed by force winder and copied by the eBay supplier. The pipes are the same length but because of the design of the bikes main intake and the kit the filter do end up staggered. That doesn't bother me. If you don't like the staggered look and have the money then the tornado kit may be for you.
    With the kit as is I can trade off between the spikes and the K&N filters. And the price was right for me.
  19. #17
    Jun 2008
    South Florida
    Quote Originally Posted by Mrg View Post
    Mrg your bike looks great...
  20. #18
    Nov 2009
    San Antonio, Tx
    Quote Originally Posted by Gsxrrobb View Post
    There is a way to fix it but it requires a redesign of the intake hose length under the tank.
  21. #19
    Nov 2009
    San Antonio, Tx
    Quote Originally Posted by Highway View Post
    Thanks .... This board makes it easy. Lots of good ideas and tech tips.
  22. #20
    Jun 2008
    South Florida
    Well installed mines and they went on pretty easy, both sides fit in the rubber holes, only difference is on the right side I used the bottom hole on the motor to mount the black brace, what you all think.
    Looks like the right side is up againts the plastics but its one inch away plenty or room..
  23. #21
    Dec 2006
    Australia,Ocean Shores.
    you took the tank off to fit them?
    dont forget to change those piss ant screws that hold the spike to the round pipe.
  24. #22
    Jun 2008
    South Florida
    I had the tank off already, and yes those screws look cheap... Got some stainless allen head ones at Home Depot..
  25. #23
    Nov 2009
    San Antonio, Tx
    Nice job. She looks good.
  26. #24
    Jun 2008
    South Florida
    Thank you for your write up, it gave me a good start.
  27. #25
    Jun 2008
    South Florida
    Both sides and tank on...
ID:	37230   Click image for larger version.
  28. #26
    Nov 2009
    San Antonio, Tx
    She looks good.... Nice job.
  29. #27
    Jun 2008
    South Florida
    Thank you...
    Had a guy ask me Saturday what they set me back? I told him like $194.00 to my door and he freaked asked me for the link to e-bay and ordered a set right there..
    He thanked me and bought me an Ice coffee...
  30. #28
    Nov 2009
    San Antonio, Tx
    Nov 2009
    San Antonio, Tx
    Quote Originally Posted by BobbyMac View Post
    I found this on DLP's site. What do you think?
    Chrome Tornado Filter Clamp Cover
    http://www.directlineparts.com/produ...=44785&str=290
    https://www.m109riders.com/forums/sho...d.php?t=152227
  32. #30
    Active Member SGT5278's Avatar
    Apr 2008
    Holt MI
    Default Spike styled intake on the cheap
    Thank you for the heads up on this. Install was very easy and quality is outstanding.
ID:	57863Click image for larger version.
ID:	57864Click image for larger version.
