Dyno Results and Mods "Dedicated Thread" - Page 8
Page 8 of 8 FirstFirst 12345678
Results 211 to 230 of 230
Thread: Dyno Results and Mods "Dedicated Thread"
  1. #211
    Jul 2015
    Sweden
    Default M109r/M1800r from Sweden
    mine gave 118.9Hk o 160.2Nm done not so bad against stock 111,2Hk o 135,5Nm and air-o noise and PCV without adjustment 114,8Hk o 154,4NmClick image for larger version.
    Cobra sweept pipes Baron XXL big suckers air filter Power Commander V
  3. #212
    Greenville, SC
    Quote Originally Posted by geofftl1000r View Post
    You don't need to adjust every map in an ecu. You might want to equalise the ignition maps which would only take a few minutes just so you don't need to use a tre.
    Tuning the secondary throttle plates to open at the correct speed to maintain air velocity may take a while, does anyone actually do this or just open them all the way? SAme for SET maps for those with OEM exhausts.
    You could mess with the cold start maps, the engine temp maps, altitude maps but do people really do this?
    I meant the fuel maps... (speed density and Alpha N) nobody can adjust all of them.... in all the throttle positions in 3 hours from a super lean condition like what is shown in Pete's dyno chart....
    (this takes more than 3 weeks to do properly if you work on it every day and do nothing else with modern data logging equipment.
    Creating the best sub-throttle maps also takes a few days of testing and should include a fair amount of seat time to get properly adjusted for response and feel... this needs to be done first before the fuel maps are fine tuned
    I don't see there being much difference in tunes from one bike to another that has similar setups. 2-2 exhaust, 2-1 exhausts etc.
    But it is nice to know that your ecu is tuned perfectly for your bike even if you'd never feel the difference.
    The owner of the M109R that is on my site says the difference is night and day in driveability and response compared to his previous stock ECU/TRE combo, with a high rpm pull that pulls noticeably harder and for longer than before the ECU was reprogrammed.
    One thing I would like dyno runs to show is ACTUAL horse power. We only ever seem to get corrected numbers (which is fine for comparisons) but people at high altitudes always have way less power and they need to understand that you can't tune that power back, there just isn't the oxygen to do it...... well you could add a turbo!
    Actual HP is uncorrected and will vary dramatically depending on the day (answer is for the many that don't understand)
    My dyno is actually a heartbreaker for many people... (reads lower HP than most of the Dynojet model 250's)
    I can post some uncorrected #'s if people want to see them.
    Ivan
  4. #213
    Aug 2015
    Finland
    Default Power Cmander only, first..
    What about if i first buy and install PCV( ´cos money) and leave everything else original. Especially the pipes because all parts all very expensive here in Finland. Will i still be able to get more torq and better throttle etc even original pipes are too small? My bike is original and i really don´t like it under 3500rpm. Twitching in low rpm, as you know.
    Was here anybody´s result in dyno, only with commarder?
  6. #214
    If you have twitchy throttle at low revs a TRE will help that lot.
  7. #215
    Aug 2015
    Finland
    Yeah, I've been thinking buying TRE but if I put PCV afterwards, isn't tre useless then? Or if it's not, what would be best order when buying and installing 1 at time?
    Tre, pc, air intake, pipes? Of course dyno every time.
  8. #216
    Feb 2010
    Quote Originally Posted by tv79 View Post
    They do two different things. The TRE alters the timing, the PC-V alters the fuel.
    You can install the TRE at any time. You need the PC-V after you do both pipes and intake. You can do either pipes or intake without adding fuel, but I think they run better even stock with a good tune.
  9. #217
    Aug 2010
    Great NW
    Quote Originally Posted by Board Support-1 View Post
    agreed, and U just a postin machine tonight, 2 so far
  10. #218
    Very Active Member SKIDMARK's Avatar
    LAND OF THE LONG WHITE SMOKE CLOUD,.NEW ZEALAND
    Lol....
    Sent from my GT-S7275R using Tapatalk
  11. #219
    Feb 2010
    Quote Originally Posted by Nemo View Post
    Yeah, but they were both basically the same question. I can handle two posts like that.
  12. #220
    new jersey exit 117
    Default dyno results
ID:	282929Click image for larger version.
ID:	282937Click image for larger version.
ID:	282945Click image for larger version.
ID:	282953good numbers? looks like everybody else has better?.guy said solid #s.....sideburner,pcv,k&n thunder chargers
  13. #221
    Member Mando's Avatar
    Jun 2015
    Antwerp, Belgium/Patoka, IN
    HP/Torque: 121.1Hp/ 115.6lbft
    Year:
    2006
    Mods:
    K&N air filters
    Fuel management and settings:
    fuel/air ratio tune-up
    Before and after differences:
    before tune-up 120.3HP/112.1lbft
    Location of shop and prices to tune: Goes (Holland) $140 (Ruud Frederiks)
    1/4 mile times: don't know
    Additional comments, suggestions, and observations of your experience at the dyno: this was done in July, now she has Cobra swepped exhaust, Duck covers air filter covers (cutout skull) I closed the back side of the filter cases so only cool air gets in and I can already feel the difference, next wednesday I go back for a power commander install and re-map, lets see what she brings!!
    Greetz mando
  14. #222
    Jun 2015
    went back to the dyno and installed a power commander V and did the remap, this is the result:
    HP/Torque:
    119.0 Hp/ 127.9 lbft
    Year:
    2006
    Mods:
    K&N air filters, Duck covers, Cobra exhaust
    Power commander V, remap
    only K&N air filters (tune up with Yoshibox) 121.1 HP/115.6 lbft, added Cobra exhaust and Duck airfilter covers 115.2 HP/121.0 lbft
    Location of shop and prices to tune: Goes (Holland) $510 power commander included
    Additional comments, suggestions, and observations of your experience at the dyno: exhaust and covers gave a power loss of 6 Hp but gained 5.4 lbft of torque!! question is if I should de-cat the standard exhaust and use that or stick with this set-up?
  15. #223
    Aug 2015
    Finland
    Default what do you say?
    First at all. Friend of mine has a dyno for cars and we just tested for fun what we get. Results are computer´s calculated powers from motor ( for the cars), not from back tyre.
    Like your results from mcdynos!?! Those are real power from tire?
    But like i said, just for fun and see how the line goes.
    Also we drove the dyno on 3rd gear, drivers mistake.
    HP/Torque: 130,2HP / 106,7 lbft(144,6NM) (From backtyre 117,5hp/6722rpm, checked from computer)
    Year: 2007
    Mods: Power Commander V, Autotune, TRE, everything else stock
    So, were is my torque? I mean if factory promises 125hp/160Nm and those results are power from motor... We had like 130hp/144Nm....
    I mean, after PCV they should be even near what factory promises, even they give little big bigger results than real...
    But what you think next, V&H when i get enought money...
    And little bit of topic, do they made slipper clutch for M109? had almost accident, because i don´t have gear indicator, and i put accidentally the first gear on while turning right on crossroad with too much speed so back tire went lock and i almost flip the bike.
  16. #224
    Very Active Member aqwik69dart's Avatar
    Mar 2008
    El Dorado Hills, CA
    Default My 2011 Dyno Run (w/video)
    Well, after I installed a pcV and some mods I decided to see where I am at. I basically wanted a baseline to decide if spending $500 on a tune is necessary. I got a map file from Latinrascal since our setups are very similar. I am pleased with the results, however I am running pretty lean according to the Dyno operator. Anyway, here are the results.....not too shabby considering the map is "generic" to my bike.
  17. #225
    Quote Originally Posted by aqwik69dart View Post
    I would of thought the TQ number would of been a bit higher. I regularly see them closer to the 100 range.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  18. #226
    Active Member BKojac's Avatar
    Jul 2016
    NC
    2016 M109R BOSS
    Bassani Pro Turnouts
    Baron's Big Air Kit
    PCV
    Dyno tuned at Twin Performance Cycles in Garner NC
    Healtech XTRE to be installed soon(it doesn't arrive until Monday&#128546
    I see some pretty impressive numbers on this thread for the mods that have been done. I will take what I got out of mine as you can see by the pre-tune graph there was a horrible lean spot that had been eliminated via the tune.
    Sent from my SM-N930V using Tapatalk
  19. #227
    Mar 2008
    El Dorado Hills, CA
    It's funny you say that.... I thought the exact same. I did notice that my max torque is actually 110.79 in the lower left corner of the screenshot but he marked my torque on the graph where Max hp is. I didn't ask why.
  20. #228
    Quote Originally Posted by BKojac View Post
    2016 M109R BOSS
    Baron's Big Air Kit
    PCV
    Ok, that number sounds better. I just had never seen a TQ number that low with the mods. But Im no expert on these things or a Dyno either.
  21. #229
    Jul 2016
    NC
    IMHO, I would get that tuned. It might just be me but your a/f ratio would make me paranoid. That could easily adversely affect the torque. Not quite sure why the hp and tq are so far apart on this dyno but I by no means am a mechanic, just an avid wrencher.
  22. #230
    May 2016
    chambersburg pa
    2013 m109r 2500miles
    conical intakes
    cobra swept exhaust
    power commander v
    before Dyno tune
    109.83hp
    110.51torque
    after Dyno tune
    113.79hp
    112.52 torque
    would have liked to do a stock run before I added things to see what bone stock was but couldn't. the shop did a great job and they said the map I had load was real close on a/f but they sill managed to gain me an extra 4hp and 2ft lbs of torque. wish it was a bit more, but the bike is much smoother now as well
