HELP! Gear Problems
Results 1 to 2 of 2
Thread: HELP! Gear Problems
    Mar 2008
    Tampa Fl
    Default HELP! Gear Problems
    While out enjoying an awesome day in Tampa Fl on the 9 and preparing to make a left turn, suddenly she won't go into first gear from neutral. As I play with the clutch and gear shift, she goes into first gear but simultaneously jump and then shutoff. As I tried to start the bike in gear she would jump very aggressively. She would only start in neutral and then jump and shut down when an attempt was made to get her in gear. A I checked the clutch cable to ensure that it was engaging the transmission it all looked okay . Has anyone experienced something like this ?
    Jun 2006
    Indianapolis, Indiana
    Quote Originally Posted by O-ZONE View Post
    You must have an '06-'07. Either you have a clutch cable failing---look at top adjuster and look for frayed cable and look behind the middle left side cover for the same thing. If the cable looks good, then you have the clutch tube (hub) nut backing off on the outer basket. 99% that this is the cause due to what you have described. Either way you are dead in the water. You can do a search under clutch hub nut or tube nut to help you understand what all is involved. Wish I were closer, I would be happy to help. Oh, the more you start the engine, the more damage you can do to the hopefully not yet damaged parts.
