Installed k&n's, but . . .
Results 1 to 9 of 9
Thread: Installed k&n's, but . . .
    Very Active Member Landlubber's Avatar
    Salmon Arm, B.C.
    Default Installed k&n's, but . . .
    Had new k&n's installed some time ago at my first service. Dealer told me the intake tubes were no longer needed. Now I'm thinking, was this correct? Tried using "search" but found no answer. Bike runs fine but does pop and fart a bit. Feedback appreciated.
    "I used to think I was indecisive, now I'm not sure . . . "
    Very Active Member Hink's Avatar
    Pittsburgh PA
    He is correct!
    New Member? Click here: Frequently asked questions.
    Very Active Member pynikal's Avatar
    Blue Springs, MO
    you must have a newer bike.
    i wouldnt worry about them because the 06s did even have them. not mine anyway.
    Very Active Member EYELESS's Avatar
    Albuquerque NM
    Talking
    yanked mine out
    that didn't sound right
    -Dave
    Blue Springs, MO
    very few of the things you say do ................
    Albuquerque NM
    see what happens when all you do is make dirty comments? even the ones that shouldn't sound dirty still do
    -Dave
    Very Active Member backinthesaddle's Avatar
    Huntsville, Alabama
    Quote Originally Posted by Landlubber View Post
    Are you talking the small tube that attaches to the back of the stock air intake? If so, where does the directions say not to re-attach? My directions say to just re-assemble once the K&Ns are installed. What is this tube for? What if you leave it connected?
    2006 cobalt blue w/realfire
    Roll Tide Roll!!
    Find out more about motorcycling in Alabama
    I am curious as well. There are 2 tubes that run off the intake/filter housing. The large tube that attaches with 2 clamps that run from the top of the the air/filter housing to the main air box and then the other "smaller" hose about 3/8" I believe, that goes from the air filter housing to the main air box. I have both hooked up right now and was wondering which one(s) should or should not be installed? I am assuming the post and what Hink was refering to is the smaller hose should be removed, correct?
    Very Active Member RicoChet's Avatar
    Nov 2006
    Richmond Hill, Ontario
    I just tossed mine in a box. You don't need them.
    Previous Bikes: 2001 Honda Shadow VT750, 2005 Suzuki M50, 2005 Yamaha MT-01, 2008 Suzuki M109R LE. 1982 Honda CB900F, 2003 Honda ST1300, 2012 Rocket III Roadster Phantom Black
    Current Bikes: 2007 Yamaha MT-01 & 2016 Yamaha Super Tenere ES
