Fi2000 settings--please share
Page 1 of 5 12345 LastLast
Results 1 to 30 of 142
Thread: Fi2000 settings--please share
    Very Active Member pynikal's Avatar
    Jan 2008
    Blue Springs, MO
    Default Fi2000 settings--please share
    post your cobra Fi2000 settings here and your mod list so we can compare what works and what doesnt.
    possibly sticky this for newer n00bs than myself.
    mine are currently at 1, 3, 2
    and havent really messed with it at all.
    Mar 2007
    West Virginia
    Home made exhaust, which is pretty much a straight through pipe. GiPro and K&N filters.
    I run mine on 2-3-2 and it runs smooth as silk.
    Very Active Member Tigz's Avatar
    Feb 2009
    Matteson, Il
    Cobra swepts without baffles and big air kit. FI2000r set at 2.5, 3.5, 2. Runnin a bit rich, I think.
    Jan 2008
    Blue Springs, MO
    does anyone know what the number actually mean i know what the pods are but the numbers?
    pod 1---low speed
    pod 2---mid range
    pod 3---high range
    Mar 2007
    West Virginia
    I have no idea, and I've searched a lot to find out. It would be nice if they said each number equaled 5% more fuel or something like that. I guess since these are used on a variety of different bikes the percentage of fuel it adds would be different, as all it does is keep the injectors open longer as the numbers go higher.
    Jul 2008
    Forney, TX
    Cobra Dragsters, K&N filters. (stock setting) 1-3-2.
    Very Active Member Gramps's Avatar
    Sep 2007
    small ranch/farm out in the country 10 miles north of Burlington N.C.
    V&H baffled Bigshots,K&N's with cold air side inlet, settings on 2-4-3. Last tankful general driving 41.4 mpg. Best trick I learned is make sure you have the Cobra right side up before you make adjustments
    Very Active Member 2kool's Avatar
    May 2008
    Naples,Fl
    Cobra Dragsters w/quiet core baffles,stock air boxes and K&N filters. 2.5-3-2.
    Apr 2008
    mass
    shorten stock exhaust,ducks cover with k&n filters set at 1-3-2 runs great
    Jan 2008
    Blue Springs, MO
    Exclamation
    so if that is correct. they are increasing the duty cycle of the injector there fore the higher the number the more fuel is put to the system. maybe i will email them to see exactly what they mean.
    Apr 2008
    Rochester, NY
    With debaffled pipes & K&N's & stock plugs I ran it at the default for a while - no issues - getting 40-45mpg.
    Then I installed "9's" for plugs and readjusted it to 1-1.5-1 and ran for a while - no issues - getting 45-50 mpg.
    With Road Rage pipes (arriving this week) and K&N's I'll start it at 1-2-1.5
    Mar 2007
    West Virginia
    Quote Originally Posted by pynikal View Post
    Actually, it would be extending the injector pulse width, or the amount of time the injector is powered on for each cycle. Basically the same thing, but if you ask them they may be more familiar with one term than the other.
    Jul 2006
    Rochester, NY
    pod 1---low speed
    pod 2---mid range
    pod 3---high range
    IF YOU GO TO COBRAUSA WEBSITE - YOU'LL FIND THIS IS WRONG, GREEN POT - IDLE OR OFF IDLE UP TO 5000 RPM'S - YELLOW
    POT = ENGINE LOAD TRIGGERED FUEL DEMAND, RED POT = FUEL MIXTURE
    SETTING
    HOPE THIS HELPS
    MINE ARE AT - 2.5, 4.5 & 2.0 - I HAVE K/N FILTERS, OPENED STK EXH AND NO OTHER MODS -
    NO ONE BELIEVES HOW GOOD IT RUNS
    Very Active Member SoCal-LE's Avatar
    Aug 2007
    Rancho Santa Margarita, CA
    2-3-2 with Cobra Swept/K&N. No probs to report from these
    Baron's Big Air, Cobra Swept, Cobra Tri-Pot FI, Debeavered, HID
  17. #15
    Jan 2008
    Blue Springs, MO
    i just put on my roadburners. and my fuel econ has gone to the floor. im getting like 28-32 MPG i think i will adjust it to 3-4-2 and see how that works.
    everyone that i ride with says when i get on it there eyes burn from it being so rich.
    im still stock on the intake side. hopefully that will be changing soon.
  18. #16
    Sep 2007
    If you are running rich and not running an intake why not try something around 1-2-1,or 1-2-2. Default is 1-3-2 which is supposed to be used with a free flowing exhaust and intake..you only have the exhaust,the factory map runs lean to about 3500 or so for emissions. Your settings do sound awfully rich for your set-up.
  19. #17
    Jan 2008
    Blue Springs, MO
    im at 1-3-2 now.
    maybe ill try 1-2-1 and go from there.
    thanks!
  20. #18
    Very Active Member game warden's Avatar
    May 2007
    I`M RUNNING K&N FILTERS IN STOCK BOXES AND JSD WITH ROADBURNER 2 TO 1 VEL PRO AND I AM USING GRAMPS SETTINGS ALSO 2-4-3 AND WORKS PERFECT FOR ME.
    WHATCHA GONNA DO WHEN THEY COME FOR YOU ??
  21. #19
    Sep 2007
    game warden I bet if you blocked off the back side of the air box's and opened up the outside with one of Duck's custom jobs or some sort of a "Tony" type mod it would really breath through that exhaust you have oh and Happy Birthday
  22. #20
    Seasoned Member seapup's Avatar
    Jul 2006
    Lake Ridge, VA
    I'm running 2-4.5-3.25 with modded K&Ns, Roadhouse pipes with baffle cores but no packing, GIPro, NGK 9s and PAIR valves blocked.
  23. #21
    Jan 2008
    Blue Springs, MO
    seapup:
    everytime i see your screenname i think of you with that spikey thing on your head!
    back to topic.
  24. #22
    Jun 2007
    Clinton, MD
    Sideburner + K&N Filter (all else intact/stock)......
    what settings used?
    Live your own life....... everyone else has one!
    '07 Red with a "Natural Mystic Blowing Through The Air........."
  25. #23
    May 2007
    GRAMPS, THANKS FOR THE TIP ...ILL TRY IT OUT.
  26. #24
    Jul 2006
    Lake Ridge, VA
    ....everytime i see your screenname i think of you with that spikey thing on your head!....
  27. #25
    Jan 2008
    Blue Springs, MO
    i got 47 MPG last tank with them at 1-2.5-1.5 just roadburners.
  28. #26
    Jan 2008
    Blue Springs, MO
    28 mpg this tank.....
    same settings alot colder though. and did 3 dyno runs on it as well.
  29. #27
    Active Member
    Oct 2006
    Lexington, S.C.
    You need to get it on a dyno.....get rid of the FI2000r, had it along with the holley intakes and cobra dragsters. Put the bike on a dyno, had to turn each dial to 10 just to keep the bike from running hot, was not getting enough fuel with the FI2000r. Threw it away and went with a power commander, same dyno, same conditions....gained 22hp before tuning 27hp after dyno tune. Spend the 300 dollars for a power commander.
  30. #28
    Mar 2008
    reality
    Quote Originally Posted by graciesdad View Post
    Sounds like you had a defective fi2000 or had a wiring issue. Mine never runs hot. Just sayin.
  31. #29
    Very Active Member will23boxing's Avatar
    Feb 2009
    Apopka, FL
    I'm running mine 1 - 4 - 3 and it feels great. Cobra Dragsters & Tornados Air Kit..
  32. #30
    Sep 2007
    My FI2000r has performed flawlessly for over a year...I haven't had it on a dyno...which is why I bought the damned thing in the first place...and with my mods I have smoother acceleration through out the entire rpm range and definitely more pull in mid to high rpms ranges. My mileage is still in the 38/42 range...my pipes (V&H's) have not discolored...that would be under the heat shields...but I did install and adjust it myself...as did dozens of other members here. I have heard of more malfunctioning pc-3's then I have Cobra units...but they do cost more...and you have to pay for a dyno too so I guess they are an alternative...for some people.
Tags for this Thread
