Fi2000 settings--please share - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 31 to 60 of 142
Thread: Fi2000 settings--please share
  1. #31
    Very Active Member pynikal's Avatar
    Jan 2008
    Blue Springs, MO
    well i got colder here and wondering what i should do with these settings??
  3. #32
    Very Active Member GUS09's Avatar
    Aug 2009
    Queensland. Australia
    Just fitted my FI2000R yesterday, any advise on setting for K&N High flow air filters & Cobra Dragster pipes.
    It's Summer & hot here at the moment (35 deg C or hotter).
    Im thinking running 2-3-2 at this point but any other feed back would be great.
    Thanks all.
    2009 Pearl Black Suzuki Boulevard M109R (VZR1800K9)
    MODS: Cobra Dragsters, FI2000R, K&N high flow air filters, K&N Hi flow oil filter, Dunlop E3 250, Chrome Grill.
  4. #33
    Very Active Member Gramps's Avatar
    Sep 2007
    small ranch/farm out in the country 10 miles north of Burlington N.C.
    You can try another .5 to 1. on the 1st pot...1 on the 2nd and another .5 on the 3rd. If your still using the stock air boxes,try sealing the cylinder side intake and opening up the cold side for more colder air through the K&N's. Duck's makes some nice looking functionally superior intake covers,or do a "Tony" mod or just do what I did and drill 90-100 1/4 inch holes in each cover. I call it my "Jason mask" mod
  6. #34
    Very Active Member MarlboroLts's Avatar
    Sep 2008
    San Antonio, TX
    4-5-3. It's rich on hard acceleration, but perfect for everyday here in Hawaii. This beast is just GNARLY on hard throttle.
  7. #35
    Aug 2009
    Quote Originally Posted by BigpapaM109 View Post
    start with 2-3-2 and start riding and bumping .5 at a time until it feels right. Only bump 1 pod at a time though otherwise you will not know which caused it to run better or worse.
    Thanks I will give that a try.
  8. #36
    Jan 2008
    Blue Springs, MO
    bigpappa knows what he is talking about, he is the one that convinced me to stay wit hthe FI2000 over the PCIII. and this spring when it gets nice out again and i have my big air and TRE on i am going to take a day and just tune tune tune with the FI and see what happens.
    thanks again bigpappa for all you input on this and with everything on the site.
  9. #37
    Member Rossco's Avatar
    Dec 2009
    Adelaide
    I have just fitted the unit and have F1 display on taco light and flashing on the speedo. Runs fine except a different sound when the key is turned on, hoped I haven't damaged anything pulling the injector plugs off? What do I do next??
  10. #38
    Jan 2008
    Blue Springs, MO
    Quote Originally Posted by Rossco View Post
    search it my friend. that is VERY common.
    good luck!
  11. #39
    Aug 2008
    salmon,Idaho
    Default fi2000r settings
    I am planning on buying the fi2000r and had ?'s about settings after reading this thread I still do,a lot of the members have similar intake exhaust set ups and different settings on fi2000r,would elevations make a difference?I am at 4000' and have K&N filters 8 (1/2"holes drilled,this thread did help a lot.
  12. #40
    Sep 2007
    Quote Originally Posted by sagerat View Post
    Start with the Cobra default settings 1-3-2 and adjust up or down as necessary.
  13. #41
    Dec 2009
    Adelaide
    Got all the problems sorted out just a loose fuel pump plug. I have the opportunity to use a dyno at the local mech institute as a project for the apprentices, cant wate to see what a stock bike can produce with the baffles removed and a fi2000 fitted.
  14. #42
    Jan 2008
    Blue Springs, MO
    keep us posted on that!
  15. #43
    Member mwcarl's Avatar
    May 2009
    Colorado Springs
    Running mine at 2-3-2. I have the Barrons big air kit and am running at an altitude of 6000 Feet. Havent had the chance to really fine tune it yet but is running pretty good at this setting.
  16. #44
    Aug 2006
    Quote Originally Posted by mwcarl View Post
    Those are interesting settings for an altitude of 6000 ft.
  17. #45
    Jun 2008
    Germany
    Default Setting for FI2000r
    Still trying to tune mine! It got late last night, but when I quit last night at 2-3-2, it was still sputtering and backfiring.
    My niner is my freedom
  18. #46
    Aug 2006
    Quote Originally Posted by SoCal-LE View Post
    2-3-2 with Cobra Swept/K&N. No probs to report from these
    Same here
  19. #47
    Very Active Member RicoChet's Avatar
    Nov 2006
    Richmond Hill, Ontario
    Vance & Hines Bigshots, K&N Air filter, Custom Air Covers .... I am trying a settings of 2-3-2 so far. The ride is smooth, although I did hear 1 deceleration pop today. I don't know if thats not normal as all the sounds from the exhaust are louder so it could be. I can't really tell how much more of an improvement it was over 1-3-2
    Previous Bikes: 2001 Honda Shadow VT750, 2005 Suzuki M50, 2005 Yamaha MT-01, 2008 Suzuki M109R LE. 1982 Honda CB900F, 2003 Honda ST1300, 2012 Rocket III Roadster Phantom Black
    Current Bikes: 2007 Yamaha MT-01 & 2016 Yamaha Super Tenere ES
  20. #48
    Jun 2008
    Germany
    Guys I had to go to 3-3-2 to even get the thing to stop stuttering at 3500-4000, and it is still doing it a little. But I got on the autobahn and it ran like I never felt it run before. I'm concern that its still sputtering during cruising speeds. It cleared up a little the longer I rode it. I'm going to work with it a little more later.
  21. #49
    Nov 2006
    I have just adjusted my unit to 2-4-2 .. Still trying to figure out how different it rides. Moving the pot1 from 1-2 seemed to make more of a "Gassy" smell and 1 seems to make small pops on deceleration... very small pops.
  22. #50
    Very Active Member bmz's Avatar
    Nov 2006
    Auckland, New Zealand
    had my fi200r since 2008 never missed a beat, settings are 2 4 2 with 2 into 1, pod filters , but are reviewing all the stats , it is way better to unlock the ecu and reset that , better than a power/c and fi200r , and once you unlock the ecu you will never use any thing else
    C:\Users\bmz4247\Pictures\2008-03-04\DSCF6160.JPG CUSTOM ROLLED M109R
    http://projectxcustoms.co.nz
  23. #51
    Very Active Member Tiny71's Avatar
    Apr 2008
    point marion,pa
    just bumped mine up to 4-4-2.5 to get rid of the jerking of idle and 2500 to 3000 rpm range haven't had a chance to do a long run to see how it does.
  24. #52
    Very Active Member wrisperj's Avatar
    Jul 2009
    Southeast GA
    Default Ne wInstall
    Just install my Fi2000r and all is well at 2-3-2 except the deceleration popping. Is that norm. I am running a duck type breather, JSDM, and stock pipes with scorpion tips. I am thinking of going to 1-3-2 which i think i stock
    Blessed to be the best
  25. #53
    Member ballesteros's Avatar
    Jan 2010
    fort worth,tx
    Default ?
    What settings do yall recommend for just scorpion tips and a smart tre? Anyone with this set up that can give me their settings is greatly appreciated, thanks
  26. #54
    Very Active Member Canuk's Avatar
    May 2006
    Mississauga, Canada
    How many of you Cobra unit owners use the JSD or some sort of TRE with it.
    With all this talk about how smooth it makes the bike run, I'm wondering the JSD is necessary anymore.
  27. #55
    Nov 2006
    Quote Originally Posted by Canuk View Post
    I have a JSD and a Fi2000R on my bike and they appears to be working very happily with eachother, my bike is smooth as ever
  28. #56
    Very Active Member Hink's Avatar
    Jun 2008
    Pittsburgh PA
    HMI's, and RAW pipe. My settings are 5,8,7. (Thank you DJ).
    New Member? Click here: Frequently asked questions.
  29. #57
    Sep 2007
    Quote Originally Posted by Hink View Post
    5-8-7 JEEZ Hink you must be burning some fuel
  30. #58
    Very Active Member Skullster's Avatar
    Dec 2006
    Wilmington, NC
    And suckin alotta air
  31. #59
    Apr 2008
    point marion,pa
    got a chance to ride tonight went back to factory settings and so far so good. i think i had a bad ground, i went to pull my unit out to adjust it and the ground wire came out of the connector. i added some extra wire and stripped the end and put it directly on the bat. term. and it is running alot better.
  32. #60
    Jan 2008
    Blue Springs, MO
    Quote Originally Posted by Skullster View Post
    suckin alot of something...........
Tags for this Thread
