Great job on the how to thanks, I`m getting ready to order a couple just have to fig out what I want on them exactly!!! How about changeing the color bulbs? What kind of bulbs do they use?
Hi just ordered replacement dials for speedo and tach from Joe (excellent service) but could not find post on tach dismatling - anybody help please?:dontknow:
I have to get my bike through a SOVA test here in the UK. I need to get a replace my current Speedo with one marked accurately in MPH and KPH Could one of you kind gents who has replaced his speedo Post a Scan with dimensions if possible on here. I've checked out the customised speedos and they look great.
I'll probably order one soon. But gotta get this test out of the way first.
I bought one of these and found it was of poor quality, I had to spend 10 minutes trimming it to make it fit, not to mention the numbers are very hard to read at night. Good idea but poor production, had also heard some dramas with copyright issues :dontknow:
The two speedo faces I ordered came in and were a breeze to install. I'm very happy with how they turned out. The Skull is the one i'm using currently and I can read it just fine at night. Actually after swapping out the plates, my speedo is more accurate than when it was stock according to my GPS.
The first one I purchased I had orange mph #'s & it was almost impossible to focus on my correct speed. I had another one made with white mph #'s and it is still hard to read at night. I even used some fine sandpaper to "thin" the plate, still no where close to the illumination of the original. BUT I have a SLAYER plate...when you are listening to Hell Awaits or Mandatory Suicide mph is not an issue. lol
Hi, I got my custom speedo installed, looks great except the speedo doesn't work now.The needle is not moving.Anyone have any ideas on how to fix it? Thanks.
you probably put the needle right on the zero. i think from memory you have to push it on just under the zero or just above it,cant remember now.
but i do remember i put mine on wrong as well and when you turn the key and the needle does the cycle it didnt go all the way.
Thanks, I saw it and tried it, the OD is still 15-20 miles off.I'll be at a Suzuki dealership on Sat. with a Radar gun to see exactly how far off I am and what they think.Has anyone tried a Speedo Healer here?
Hey, I unplugged the harness took off the faceplate cover, plugged it back in turned the key.It Recalibrated itself.Then I set the Needle to Zero.Put back together.Back to Normal.:bigthumbsup:
Related Threads
M109 Rider Forums
1.6M posts
32.7K members
Since 2006
