LOWERING BONES INSTALL- detailed pics - Page 9
Page 9 of 9 FirstFirst 123456789
Results 241 to 248 of 248
Thread: LOWERING BONES INSTALL- detailed pics
  1. #241
    Active Member
    Jul 2015
    Florida
    Default Excellent Tutorial
    Lowered mine 2" (Barons). A friend and I and it went well thanks to this thread and the pics.
    FYI I stripped all the plastics off first and we broke all the nuts and bolts loose before lifting the bike.
    YES put the jack as forward as possible. Also remember to put a little grease on all four bolts.
    Thank you again!
  3. #242
    May 2018
    New Jersey
    Bump for an old but useful thread! Helped me install Baron 2" bones. Thanks!
  4. #243
    May 2017
    Sault Ste Marie Ontario Canada
    I purchased lowering bones and am about to bring it in to a shop and was told that the swingarm would have to be removed to lower the bike and it would take up to 4 hours? This does not make sense to me?
  6. #244
    Aug 2007
    Montreal subburb
    get the bike out of there , 4 hours ....
    if you have a bike jack , time to find a piece of cardbord to use as a bed ,and do it yourself .
    put jack far enough forward to clear the movement of swingarm , the rear may want to go down ,
    strap it to ceiling any method will work .
    and remove long bolt at the front .
    all info needed is in the thread .
    Swingarm pivot shaft = 72.5 lbs
    Rear and front shock absorber mounting bolts = 32.5 lbs
    Cushion rod nut = 79.5 lbs
    Cushion level mounting nut ( upper ) = 79.5 lbs
    Cushion level mounting nut ( lower ) = 61.5 lbs
    Every Time You Lift Your Tank Beware Of This .
  7. #245
    Dec 2016
    Saskatchewan Canada
    Nope. Swing arm stays as is. It's just the bones
    You will need a good impact though to break bolts loose
  8. #246
    Aug 2007
    Montreal subburb
    Found a couple of pictures in my file , I deleted most when I went Air Ride ( selfish Me )
    once you have the tension of the shock removed , just a matter of replacing bones .
    tricks to reach where it is not confortable = tools .Part shaped in a curve is the Dogbone = cushion lever .
ID:	383870   Click image for larger version.
  9. #247
    Dec 2016
    Saskatchewan Canada
    Once your get the bolts loose you have to monkey with the rear wheel with a piece of wood or other things to lift the wheel to get it aligned
  10. #248
    Very Active Member W8INLINE's Avatar
    Aug 2015
    Canada
    That shop is trying to rip you off. I got the adjustable bones and did the install by myself in about 2 hours. Used only hand tools (no power tools) and a stand. It was also my first time doing it with a youtube video as my guide.
    <img src=https://www.m109riders.com/forums/signaturepics/sigpic65778_1.gif border=0 alt= />
