LOWERING BONES INSTALL- detailed pics - Page 3
Page 3 of 9 FirstFirst 123456789 LastLast
Results 61 to 90 of 248
Thread: LOWERING BONES INSTALL- detailed pics
  1. #61
    muhbeef
    Guest
    has anyone measured a before and after from the ground to the peg?
    Before this 9 I had a VFR and although the only time I've been on the 9 was to bring'r home, I noticed a BIG difference going around corners. I'd be concerned about scraping around corners. Do you guys have to really watch it while cornering? I wouldn't want that to be a constant potential problem.
    ...looks good in the garage tho! Looking fwd to the next few days now that it's my weekend
    oh, and if I were to install a 300 kit down the road would the stock bones need to be reinstalled?
    Thanks guys - AWESOME site!
  3. #62
    Very Active Member Blakester71's Avatar
    Apr 2009
    Summerville, SC
    Quote Originally Posted by mvnvltn View Post
    I dont recall having to remove the shock?
    I should be getting my 2" lowering bones tomorrow. Had some free time, plus it calls for rain today, so I decided to remove the stock bones.
    I had my jack positioned to where the shock was not able to drop down far enough for the bolts through the fram to slide out. I ended up having to put a 4x4 and two 2x4's on the edge of the right side of the frame and the jack on the other side. (left kick stand down to pull jack out when lowered)
    After that, shock dropped down far enough for the bolts to slide right out.
    Removing stock bones was MUCH easier that I had expected. 20-30 mins for removal.
    Question about the sleeves. Do I remove just the inner part of the sleeve or the whole unit?
    Package should be here around noon tomorrow. Thinking the worst. I should have it done within two hours. Bit of a challange doing this solo. But doable. Plus you get to know and understand your bike a little more. Will post before and after pictures when complete.
  4. #63
    muhbeef
    Guest
  6. #64
    Very Active Member EYELESS's Avatar
    Apr 2009
    Albuquerque NM
    Quote Originally Posted by muhbeef View Post
    no
    -Dave
  7. #65
    muhbeef
    Guest
    ok ty ...thought those kits lowered it some after installed.
    thanks again for the reply :)
  8. #66
    Apr 2009
    Summerville, SC
    I have to say that this was one of the easiest mods I had done to my bike. After reading about the lining up the shock bolt I was a little concerned. I was able to control the jack speed and the bolt slipped right in.
    In all I got about a 2 1/4 drop. It was raining when I completed so I was not able to go for a ride to see if there was a difference.
    I wasn't able to use my sleeve from the stock bones either.
  9. #67
    Apr 2009
    Albuquerque NM
    NO prob there's a few guys here running 300's lowered
    -Dave
  10. #68
    muhbeef
    Guest
    hole-ee smokes guys, I'm a new 9 owner and knew that I'd scrape a peg here and there but I find that I'm constantly worried about grinding at most corners. I took er out today for my first long ride around the backroads loop I always have done on previous bikes and bout scared the who-who outta me when I got a boot full of asphalt!!
    I don't think I'll be lowering this one.
  11. #69
    Mar 2010
    Tulsa
    Default 3" bones
    Looking for feedback on 3" bones before I install mine.
    I am 240lbs and worried that 3" may be a bit much , any experiences out there?
  12. #70
    Very Active Member CanadianM109R's Avatar
    Jun 2008
    Whitby, Ontario
    Quote Originally Posted by chadcla View Post
    If you take corners and curves aggressively, you might have a problem with 3" drop.
    Mine are 2 1/4 and I haven"t had a problem, except when I'm aggressively going around corners or tight curves.
    Grey 08 gone to heaven/ 2010 Connie- my new ride!
  13. #71
    Very Active Member NMclay's Avatar
    Sep 2008
    Fort Wayne, IN
    Finished this job a couple of weeks ago with a 2 1/4" drop. It was pretty easy (because I have a compressor and air tools!). This is not what I would call a job ANYONE could do. It had some difficult parts. However, the end result is SICK! Pics coming!
  14. #72
    Apr 2009
    Summerville, SC
    Quote Originally Posted by NMclay View Post
    I think if you have the basic tool experence and follow this thread they should not have that big of an issue. Just lining the bolt to the shock would be the hardest as most people on here have said. IMO
  15. #73
    Sep 2008
    Fort Wayne, IN
    My point was that without Air Tools I would have been hosed. I tried to do it manually but I eventually had to break out the impact wrench. From there, it went OK.
    K&N Filters, Debeavered, gutted stock pipes, Lowered 2.25". Suzuki Engine Guards, Suzuki Backrest, Irate Mesh Grill, Stebel Air Horn, Back Off Flashers, Polished Wheels, 250mm Rear, Kuryakyn foot pegs and shifter cover, Duck's Covers, ISO Grips
  16. #74
    Very Active Member Nine Rider's Avatar
    Oct 2009
    Marietta GA
    I went to walmart and picked up one of these babies for about $20 and the bone and shock bolts were very easy! Just make sure you get metric.
Name:	Four-way lug wrench.jpg
  17. #75
    Jun 2008
    Whitby, Ontario
    Quote Originally Posted by Nine Rider View Post
    Now THAT is a great idea if you don't have air tools! makes the job much easier.
  18. #76
    Very Active Member MN Diesel's Avatar
    Mar 2008
    MN
    That's what worries me to. I love to corner to much and have a hard time telling myself to take it easy on the leaning. I've scraped way to much and have hit my exhaust header on the ground a few times as it is. But I really LOVE the way the lowered bike looks. I don't know what I want to do.
    Home made De-beaver, A & R 6K HID, Factory Pro Evo Shift STAR, Suzuki Engine Guard, JSD-3M, Road Burner Velocity Pro 2-1 exhaust, PCIII, Custom Speedo face, Suzuki Billet Engine Cover, Kuryakyn ISO Grips, Smart Man's Grill, Chrome Brake Reservoir, Cobra backrest and rack, Cobra Drive Shaft cover, Rifle Windshield and lowers, Much more to come...
  19. #77
    Very Active Member mojo!k's Avatar
    Mar 2010
    Salem, OR
    I feel the same way. The bike looks awesome with it lowered but I think it will make me slow down even more ...which is probably a good thing!
    Still on the fence.
  20. #78
    Member train's Avatar
    Jun 2007
    Madison, WI
    Default Is the suspension stiffer after lowering??
    So after your 9 is lowered is the ride then stiffer? That would be my assumption. I'm on the fence with holding off until I have the coin for air-ride as apposed to getting bones because I'm impatient.
    If the suspension becomes hard then an air-ride may be a better route for me.
  21. #79
    Very Active Member jdmitchell's Avatar
    Jan 2010
    Fort Leonard Wood MO
    Quote Originally Posted by train View Post
    I went with the cycle house 1.5 inch bones that Pynikal was getting rid of and IMO they ride just as smooth as stock. But as far as a more extreme drop goes I can't comment. I love mine though.
    You can run, but you will just die tired..............
  22. #80
    Jun 2008
    Whitby, Ontario
    2 1/4 rides the same as stock. I have not changed the factory ride setting, and i have had no issues at all with bottoming out.
  23. #81
    Apr 2008
    mass
    Quote Originally Posted by CanadianM109R View Post
    have had mine lowered at 2 1/4 for over a year with no problems and have done a couple of bikes highly recommend air tools, an extra hand to help lift rear tire and don't forget to grease (marine grease) and torque bolts
  24. #82
    Very Active Member HOTMOPR's Avatar
    Apr 2010
    Rochester, wa
    Subscribin! My bones should be here Monday!!
  25. #83
    Aug 2007
    Montreal subburb
    Just finished Installing my 2 inch bones .
    found a tip , after you have removed your left bone
    run a 6 inch extension on 1/4 ratchet ,through the holes
    of the left side bone holder ,stick 17mm box on inner right side
    bolt of the right bone ,and you have a straight line to apply
    force to remove right bone , I did it with a 3/4 closed key
    on the outside of right bone .
    Everything else is quite easy with the right tool .
    ............ the new look
    Thanks Canadian M109R good tutorial.
    Grease , Locktite ,
    torque at; 50 lbs ,widest bone end
    32.5 lbs , shock end
    79,5 lbs , narrow end of bones (extremely long bolt
    did it by the seat of my pants.
  26. #84
    great write up! - did mine the other day with help from this article
    went off without a hitch - did a 250mile ride last night, can't wait for the 160/260 to get here!
    Terry
    07 109R - black is better...
  27. #85
    Very Active Member Highway's Avatar
    Jun 2008
    South Florida
    I just installed the CD 1.75 drop bones and put the shock setting at 5, waiting on my 280 to test it out... Even a one inch drop looks better then stock, when cash is better I plan on an air ride...
    Phat & Low " Thats How I Roll ".
  28. #86
    Very Active Member Getlow109's Avatar
    Mar 2010
    Fort Washington, MD
    Just dropped mine 2inchs (didn't have any grease for the bones pin but I think I am ok) Very simple and straight forward, I did have to remove the shock it only took 5 mins and the rest is history! Thanks Canadianm109
    Modins Desease is the number one cause of Brokeness!
  29. #87
    Active Member
    Mar 2010
    Colorado
    Just installed my 2 1/4 inch bones this mornign with the help of this tutorial was a piece of cake. Some great info on this sight!
    2006 M109R Custom Paint, Coastal Moto Wheels, 280/160 Tires, Lowered 2.25", Corbin Seat, Modded Hard Krome Exhaust, Gregg's Side Plate, Rivco Risers, and more...
  30. #88
    Jun 2008
    Whitby, Ontario
    I think all 9's should be lowered. They look soo much better this way!
  31. #89
    Very Active Member webb09's Avatar
    Oct 2006
    Thanks Canadian and all other ideas.
    Hey Canadian, Next time be sure and get your hands dirty before taking a pic with a part in your hand.
  32. #90
    Very Active Member dagronmaster's Avatar
    North Central Okla
    Did any of you lower your front forks like mine are?? It came that way.
    Hey! Hey You!! Move!! I can't see my bike.
