Throttle POV on I-94
Results 1 to 3 of 3
Thread: Throttle POV on I-94
    Jun 2020
    Glenview, IL
    Default Throttle POV on I-94
    This is a little better. I figured out how to clip and transition between clips. So, this is a little long just less than nine mins. Now, I think I will work on another POV. I kinda like the idea of what the ride looks like away from the rider perspectivehttps://www.youtube.com/watch?
    https://www.youtube.com/watch?v=XSbLLMf3eyI&t=378s
    Very Active Member Frotosride's Avatar
    Jun 2013
    GA
    What is the GoPro actually mounted to? I do like that view because it allows you to be a little more engaged with the rider, allowing you to see some of the control inputs and bikes response to those inputs. Keep plugging away at it.
    "Beat it like a red-headed Ford":
    '19 M9 '06 M9
    '09 commander
    '87 silverado on35's'87 c10 lwb(LS twin turbo sleeper project)'83 k20'83 k5 cucv 6.2 Detroit
    Jun 2020
    Glenview, IL
    Default GoPro mount
    I actually have wrist wrap with the GoPro mount on it. It uses velcro to secure around your wrist. A purchased a GoPro mount set on Amazon. I think it was around $29. Comes with a case for all the mounts, second plexiglass case for the GoPro, and small camera case as well as quite a few mounts... more than I will use. It was a good deal and great quality. - Glenn
