Page 3 of 3 FirstFirst 123
Results 61 to 74 of 74
Thread: Wider Holley Intake
  1. #61
    Apr 2011
    Alberta, Canada
    Has anyone tried running the K&N's as well as the foam? Why I ask is cause the Edelbrock foam doesn't seal around the edges very well. I have both in place but bike is still in pieces therefore have not ridden it yet. Will this still provide enough air... don't want to lose any performance.
  2. #62
    Active Member Munchy's Avatar
    Aug 2007
    Papakura New Zealand
    Try repositioning the foam around the cage to make sure the foam touches all round, it only needs to sit against the back plate and the oil should help the seal.
    Not sure about the K&N's but with the foam element you need to keep them well oiled with filter oil otherwise they will pass fine dust.
    I clean mine every couple of months and only once have I found any signs of dust on the inside of the filter.
    Debeaver, JSD, Factory Pro Star, Pair Valves Bocked Off, Removed Secondaries,
    Cylcle House Clutch Pack, MTC H/Duty Clutch Springs, Holley Air (Wide), Home Made Header,
    Street-Strip Cams and Porting, Hi Comp Pistons, PCIII, Relocated Tacho, Radiantz Flexible Front & Rear Indicators,
    Plasti-dip spray on cantrasting parts
  3. #63
    Apr 2006
    Annapolis, Md
    Quote Originally Posted by M1K View Post
    Yes a lot of people have run K&N's along with the Holly Mod.
    2013 Mid Atlantic Meet CLICK HERE
  4. #64
    Apr 2011
    Alberta, Canada
    Ya I think if I was only going to run the foam I would coat the air intake runners with vaseline or grease. This will give you an indication as to how good your filter is and also provide a bit more filtering. Very common practice in the motorcross scene.
  5. #65
    Jul 2011
    denver
    I've been running Edelbrocks since sometime in 06. But I did them the real simple way. I took the Edelborck back plates and tossed them. Fit the mesh assembly with the filter installed over the stock back plates, drill four holes at what would be approximately 90 degrees, stick a self-tapping screw through the Edelbrock mesh and filter into the stock back plate.
    I also utilize the thingamabob, whatchamacallit, dohickie that Edelbrock supplies to keep the filter from collapsing against the intake hole.
    Good to go. Its worked for me for dang near four years. Still makes that evil intake hiss that I prefer over a loud exhaust.
    Hey is there any way you could supply some pictures of this way? I dont have all of the tools to do the plexiglass set up. This sounds like a pretty easy way to do it. Any help would be awesome!
  6. #66
    Very Active Member Dragonback's Avatar
    Feb 2008
    Staten Island, New York
    Not to mention that you can find the Plexiglass in many different colors.. which can accent the bike.. I first made it in clear.. But have since gotten shinny Black.. but now mayb looking to put spike air kit.. im so confused!!
  7. #67
    Very Active Member scalemaster's Avatar
    Nov 2010
    Pearland,Tx
    I have a "Q" I just order a set of Holley ,so r this the same as the ones for the cars or r they diff .
  8. #68
    May 2006
    The same although they come in 2 different sizes where the holly backplate would mount to the intake. Either one will work since you will be cutting it out anyway.
  9. #69
    Very Active Member Boogs109's Avatar
    Dec 2009
    Caboolture QLD Australia
    Quote Originally Posted by scalemaster View Post
    Email/phone the dealer and ask for blank backing plates (they can supply blanks). This way you can cut your own hole in it any shape you want.
    Boogs
    K6, Black, PCV, Spike filters, 2-1 custom exhaust, Pair valves blocked, Secondary butterflies removed, Lowered 2.75", Tacho junked, Indicators replaced and relocated,
    Debeavered, 280 rear on Contrast Gasser rims, ISO Grips with Stiletto's, Cycle House Leavers & matching shorty Kickstand, Scythe II Mirrors & Axle Spikes,
    Nacel Glove Box
  10. #70
    Nov 2010
    Pearland,Tx
    Thxs guys for that info .
  11. #71
    Jul 2009
    Lees Summit, MO
    Quote Originally Posted by Boogs109 View Post
    Boogs
    I tried this and no deal. I tried Holly and Edelbrock and neither one really wanted to talk. Maybe you have a better in than I did. If so can you explain how you did it?
    2008 Grey M109R tach relocated, lowered 2", 250 back tire, 2" riser extensions,Squirrel side mounted licence plate, Mini LED turn signal, Rifle windshield,Cobra swept exhaust, PCV and JSD-3M.
  12. #72
    May 2006
    Quote Originally Posted by Rusty View Post
    There really is no need for a blank backplate other then it makes it a tad bit easier to lay your pattern out. Your gonna cut away most of the material where the hole is already stamped in the self kits and with that big hole already there its just that much less cutting you will have to do!
  13. #73
    Jul 2009
    Lees Summit, MO
    I certainly agree, I just was trying to let others know it could be very difficult to find blank back panels.
  14. #74
    Very Active Member Scorp's Avatar
    Jan 2011
    Sebewaing, Micihgan
    You can't get them here in the states. You can have them shipped into the states but your going to pay almost 100 bucks each.
