Page 1 of 3 123 LastLast
Results 1 to 30 of 74
Thread: Wider Holley Intake
    Active Member Munchy's Avatar
    Aug 2007
    Papakura New Zealand
    Default Wider Holley Intake
    Hi all, this wasn't going to be a "how to" but by the time I uploaded all the photos to explain what I had done it kinda ended up that way.
    I have always liked the Holley mod because I thought it gave the best bang for your buck and I liked the clean look. But I see many had problems with fitting the clips on and I liked the use of perspex (I think plexiglass to you guys) used in early mods to keep some heat away.
    So I went a step further and used 2 layers of perspex to allow room for the clips and this tidied things up while spacing the Holley units further out.
    But this is a lot of work and took quite some time.
    All the cutting was done with a jigsaw and then filed and sanded.
    Anyone that has had the stock cleaners apart will know that the lip the stock filter sits against is raised
    So the first layer is cut oversized around the old air filter area
    The shaped hole in the second layer is cut closer to the shape of the plastic.
    Notice all the raised lumps around the screw holes are all different heights and I had to drill all the holes to suit.
    I tried to make them all have a small amount of clearance when assembled and I used a spade drill the same as you would use on wood so the bottom of the holes are sort of flat.
    Of the larger holes the two lower and the centre top are drilled about 2mm into the second layer.
    This is both layers ready to glue (just 1 side) I used Araldite and sanded the surface to be glued.
    Notice the second layer with the extra cut off the top and bottom for the clips, and the odd shaped hole at the bottom is serves no purpose.
    I got the back plates blank so I could cut them as I wanted.
    I Used Silicon to make a seal surface and left it flat with the perspex so it will compress like rubber when dry.
    I also used silicon to seal the holley back plate to the perspex and silicon on bolts and screws on assembly.
    This is the adaptor on the bike ready to have the filter element installed.
    I used the original screws thru the holes that once held the original elements in place and 5mm stainless bolts for the rest.
    This is off the bike with the holley attached, I painted the edge matt black to suit the plastic.
    This is the end result
    As I said before this is a lot of work but I think the result is good and tidy
    I have a few more mods on the go so I will keep you posted.
    Cheers
    Munchy
    Debeaver, JSD, Factory Pro Star, Pair Valves Bocked Off, Removed Secondaries,
    Cylcle House Clutch Pack, MTC H/Duty Clutch Springs, Holley Air (Wide), Home Made Header,
    Street-Strip Cams and Porting, Hi Comp Pistons, PCIII, Relocated Tacho, Radiantz Flexible Front & Rear Indicators,
    Plasti-dip spray on cantrasting parts
  2. #2
    Very Active Member WAYNE109's Avatar
    Oct 2006
    Meyerton , South Africa
    Default Re: Wider Holley Intake
    Very neatly done!
    Life is what you make of it!
  3. #3
    Very Active Member Dark Shadow's Avatar
    May 2008
    Albuquerque, NM
    Great step by step. That was an excellent job. Very clear and easy to follow.
    There are a lot of Holley intake users that will love this thread.
  4. #4
    Very Active Member tonymontanna1983's Avatar
    May 2008
    White Castle, Louisiana
    Great job Munchy. Maybe the best looking Holley-mod I've seen .
  5. #5
    Aug 2007
    SE Florida
    Very neat, clean and nice.
  6. #6
    Very Active Member M109R-N-KY's Avatar
    Jan 2007
    Fulton, KY
    Thanks for the How to. I liked it so much I made a pdf file and saved it for later.( mod list just keeps growing)
  7. #7
    Very Active Member BIGIRISH109's Avatar
    May 2008
    Herkimer, New York~ERIN GO BRAUGH~
    Looks nice. Alot of work and time for something most won't even notice but, well worth the effort!
    May your blessings outnumber the Shamrocks that grow. And may trouble avoid you wherever you go!
  8. #8
    Very Active Member Bullie's Avatar
    May 2006
    Bakersfield, CA
    if you get bored and want to make another set of those.......I'm buying!! Sent PM
    (IF) America will Bless God
    God (WILL)Bless America
  9. #9
    Active Member
    Feb 2008
    Central Illinois
    That's the fix we need on these filters. I would buy a set also, just tell me your price.
  10. #10
    Apr 2006
    Annapolis, Md
    Nice job. It looks great.
    2013 Mid Atlantic Meet CLICK HERE
  11. #11
    Very Active Member aceventura's Avatar
    Jun 2006
    Las Vegas
    Quote Originally Posted by Dark Shadow
    VERY NICE write up
    Las Vegas, NV
  12. #12
    Very Active Member Giddyup109's Avatar
    Jan 2008
    Maryland
    Sweeeeet! I have these and I just "forced" the wire behind the cover because it stuck out to far. This is a great idea to get a cleaner and more flush look for these intakes!
    "Blaze"
  13. #13
    Aug 2007
    Sorry guys but you may have noticed the state of my garage in the pics which is due to me being half way through renovating part of our house.
    I had enough grief from the little lady when doing my own work on my bike (which aint finished yet either).
    But I am more than happy to give anybody any tips or help online.
    And thanks for the comments
    Munchy
  14. #14
    Very Active Member HyperPete's Avatar
    May 2008
    Lancaster County, Pennsylvania
    Is there any chance you can trace those spacers and post them as templates? That would be great...
  15. #15
    Aug 2007
    Sorry not without tearing the units apart again but all I done when I made mine was make a cardboard template.
    I marked thru the screw holes in the airbox first and cut holes to suit the raised portions on these then pressed around the old filter area with my thumb to mark it and cut this out oversized by a mm or two.
    I finaly marked the outside with a pencil but I used the airbox to mark the outside of the plexiglass to finish off after I had glued both sheets together. But I did use the cardboard template to work out and mark where the retaining wire cut-outs go.
    My template was pretty rough but the important thing is getting the holes in the right place then final fit up is after you drill the holes and mark off the airbox itself.
    I had done 3 pairs before I was happy.
    Hope this helps
    Munchy
  16. #16
    Sep 2006
    Quote Originally Posted by Munchy
    How did you go about that? I'd love to do this mod exactly as you've done, but don't know where or how to get "blank" back plates. Thanks for the post!
    - Semper Fi -
    They are in front of us, behind us, and we are flanked on both sides by an enemy that outnumbers us 29:1. They can't get away from us now! Lewis B. "Chesty" Puller, USMC
  17. #17
    Aug 2007
    I used Ramflo filters which seem to be exactly like the Edelbrock.
    I got mine at a local (New Zealand) supplier http://www.autopia.co.nz/ramflo.htm?sub_1_1=&menu_1=&
    The US site is http://www.ramflo.5u.com/
    I couldn’t find exactly what I wanted on either site so I sent Autopia an email and asked what the options were on backing plates and they said they could get blanks. The entire filter units cost me around NZ$100 each which is quite expensive for what they are but it was exactly what I wanted.
  18. #18
    Very Active Member wallyn591w's Avatar
    Mar 2008
    maine
    what a great job very sweet
  19. #19
    Jun 2007
    New Jersey
    Have you heard any differance in the air intake sound or performance ...Would buy a pair in a minute...looks awesome...Very neat and clean.
  20. #20
    Apr 2006
    Annapolis, Md
    I was looking for this post the other day. You did an awesome job again.
  21. #21
    Mar 2008
    maine
    excellent
  22. #22
    Aug 2007
    Thanks.
    Definately yes to both.
    There have been posts quoting 6 to 8HP gains and I would say thats fairly real.
    There is a noticable increase in induction noise and I just can't get enough of it.
  23. #23
    Very Active Member Boogaone's Avatar
    Oct 2008
    Brisbane QLD Australia
    Thanks Munchy, I have wanted to go with a Holley air kit but have heard problems with fitting the standard kit and over the past few days have been thinking how I could make it better. Then, I found this thread.
    Love your work
    I'll be going this way definately.
  24. #24
    Active Member
    Apr 2007
    Quote Originally Posted by Munchy View Post
    Thanks.
    i just finish my holey mod and i wish i would of seen this one this very good and i wish mine came out like that but hopefully it would work thanks for the step by step
  25. #25
    Default Part #s please
    Could you please post part #s for the filters and blank base plates.
  26. #26
    Apr 2006
    Annapolis, Md
    Quote Originally Posted by yahooskidoo View Post
    With the Holley airs you use no filters, just the foam as the filter that comes with it or a lot of people use the K&N filters.
    If you are talking about the base plate on the left (metal part), it comes with the Holly airs.
  27. #27
    Default baseplate
    Part # for blank base plate please, I'm sure it comes with a hole cut for a car carb.
  28. #28
    Apr 2006
    Annapolis, Md
    Here is a link to the Holley air kit.
  29. #29
    Aug 2007
    Try this http://www.ramflo.5u.com/
    I emailed the NZ supplier when I done mine and they sent me blanks back plates on request, I assume you can do the same.
  30. #30
    WickedRican
    Guest
    Very clean! Awesome...
