FactoryPro shift kit for M109R
Page 1 of 3 123 LastLast
Results 1 to 30 of 71
Thread: FactoryPro shift kit for M109R
    Very Active Member CaliMan's Avatar
    Sep 2007
    Santa Clara, CA
    Default FactoryPro shift kit for M109R
    Some of you may have seen my posts about my 2007 LE that's currently in the shop with tranny issues at 2k miles (jumping out of 2nd gear into neutral). So in the spirit of the 6 Million Dollar Man, I am going to make it better, I am going to make it stronger...
    Years ago I installed a FactoryPro kit in my VFR and immediately noticed smoother, more positive shifts. They did not have one listed on their web site but gave them a few calls and spent some time with Leigh there cross-referencing M109R part numbers with him and it turns out that the Shift Kit for the SV-1000 will fit the M109R... now I have not installed mine yet (still battling with Suzuki to get them to warranty cover it failing) but I have a kit on order. He said they will be listing the kit for the M109R in the future.
    http://www.factorypro.com/products/F...Pro_shift.html
    Before I put it in I am sending my gears out to have them undercut.
    http://www.aperaceparts.com/transmissions.html (the Hayabusa cut)
    I am going build this transmission the way Suzuki should have designed it in the beginning.
    more to come...
    UPDATE ON MY BATTLE WITH SUZUKI (5/16/0:
    http://www.m109riders.com/forum/inde...c,25775.0.html
    UPDATE ON TRANSMISSION IMPROVEMENTS (2/29/0:
    http://www.m109riders.com/forum/inde...c,25603.0.html
    still more to come...
    2007 LE: Upgraded Shift Forks, Solid Steel Shift Shafts, Undercut gears, FactoryPro Shift Kit, G-Man Shift Bushing, BevelGear Set, Propeller Shaft & Rear Rotor, Edelbrock Air Fiters, Lloyds Fuel Controller, Barnett SS Clutch Cable, GIpro, Rivco Aux Fuse Panel, Debadged, Debeavered, Designaled (rear), LED stealth signals(rear), Plate Reloctor, Integrated Garage Door Opener, HID Headlight (6000k), Stebel Air Horn, Kuryakyn Signal Mirrors, Gorilla Alarm, FasTrak
    Mar 2007
    West Virginia
    Default Re: FactoryPro shift kit for M109R
    Sweet! We were having a discussion about the FactoryPro shift kit last night in this thread: http://www.m109riders.com/forum/inde...c,25633.0.html and wondering if they had one that would already work or not.
    Mine shifts fine, but I wouldn't mind doing something to it to insure that it stays that way.
    Very Active Member lostrider's Avatar
    Apr 2006
    nope
    Good deal Caliman. I hate to say you are the guinea pig but someone has to do it. Keep us posted on your progress since I am just finishing up my Bluey mod and would definitely go your route if it all works out. Thanks Ray
  5. #4
    Sep 2006
    bothell wa
    That is good to hear. Had been thinking about that all day. Can they do a clutch fix for us?
    How fast is too fast? mods: pc3, shaved beaver, clear lens and tail light,fire pegs& grips, rifle shield, gel seats, Road House exhaust, e3 250, cold air, engine guards, chrome shaftcove, ,and engine flame cover, HD pssgr back rest-luggage rack mod, 1" riser ext, maniac mod, 2" bones, HID headlight
  6. #5
    Seasoned Member seapup's Avatar
    Jul 2006
    Lake Ridge, VA
    Awesome! I'm going to have to do some research and try that kit out!
  7. #6
    Sep 2007
    Santa Clara, CA
    My shift kit arrived today.
    The M109R already has a roller bearing detent arm (a small for Suzuki) so the kit consists of the EVO Shift Star and a beefier detent spring. Like it says on their web site: "...at last count, we'd eliminated over 7,223,243 missed shifts and saved about 32,711 2nd gears and shift forks. Transmission gears and forks get damaged when you miss a shift." Guess what, it's my 2nd gear and shifter fork that ended up being the culprit.
    I am no rookie driver mind you, been riding for 32 years, taken the Reg Pridmore riding school at both Laguna Seca and Sears Point (http://www.classrides.com/). I KNOW how to shift a bike and I did certainly nothing to thrash mine. It's just a fragile design for such a bike. Everytime you miss a shift to 2nd think about that...
    Now I just need to send the gears out to be undercut and, oh yea, for Suzuki to honor the warranty repair.::) C'mon guys - do the right thing!
    The saga continues...
    Scott
  8. #7
    Apr 2006
    nope
    Sounds great Cali, As for Suzuki stepping up get ready to be disappointed. I hope you have better luck but the track record so far is not a good one....
  9. #8
    Sep 2006
    bothell wa
    I like what it said about another bike they were using on thier site. " the bike missed 2nd several times". I think we could say that about the 9. I see one of thier kits in Silvers future...
  10. #9
    Very Active Member Shock's Avatar
    Sep 2006
    Mansfield, Texas
    Let us know after the install and maybe you could do a little "how to" on the install.
  11. #10
    Very Active Member CBR1000DUDE's Avatar
    Feb 2007
    Oakley, Ca
    Quote Originally Posted by CaliMan
    That's good to know. I'll probably get to mine before yours is back together, I'll take some photos. From what I remember doing my 1500, it's not very hard to do, it's all on the left side of the bike. Drain oil, remove chrome cover, remove hydraulic pusher cover 2 or 3 bolts (just tie off to the side), remove shifter cover, 4-5 bolts, remove ratchet mechanism 5 mm allen, and you're looking at the star and detent arm. For my fix (adding to the spring straight arm) remove spring, arm, 1 bolt, add to spring a spacer with red loctite, reassemble and add oil, test ride. It should feel more solid on the first shift.
    A man has got to know his limitations... Harry Callahan
  12. #11
    Apr 2006
    Traveling America
    Waiting on some feedback.
    Coming to a city near you..
  13. #12
    Very Active Member silver bullet b's Avatar
    Sep 2007
    Long Island and Saratoga Springs NY
    Hurry please can't wait to here some feedback!!!
    2009 Hayabusa 2006 silver M109
  14. #13
    Mar 2007
    West Virginia
    I've got strong feet (no, not that kind of strong) and a stronger spring isn't going to bother me a bit. Can't wait to see how this goes.
  15. #14
    Apr 2006
    Perth Western Australia
    I like a heel toe shifter anyway.
  16. #15
    Feb 2007
    Oakley, Ca
    Quote Originally Posted by Zoom
    The slight extra effort to shift won't be a problem I believe, my 1500 seemed about the same effort , just more precise feel as it went into gear, it felt like it snaps into place rather than oozing. I don't think those without a heel shifter need worry. I'm anxious to see how this works too, I'd kind of forgotten about it since it's been 5 years since I did it.
    My wife just got home from her surgery late yesterday, so I'm tied up helping her,(not that I mind in the least) otherwise I'd have it done by now. It's been nice weather too. Oh well, I've got the whole spring and summer to look forward to.
  17. #16
    Jan 2007
    Bayonne, NJ
    hey bro sorry to hear about ur trans.. I dont have any prob with mine yet... but just wondering if i get this pro shift kit.. u mentioned that we already have a Microbearing Detent Arm soo is it safe to say for this mod out of the kit all we meed is the detent spring ....cuz it comes with the gasket spring and Microbearing Detent maybe we can save money and just get the spring....also is it an easy install for a 1st timer.... and if we have no trans probs do we have to undercut our gears?? thanks
  18. #17
    Jan 2007
    Bayonne, NJ
    sorry for no update on the heated grips ... i have had some personal issues im working on at the moment and im slowly working on everything. at the time i 1st posted the heated grips they where not complete i wanted to post to see if it was worth persuing i know the warm weather will be here soon but i am working on it and when i have answers everyone will get them... thank you all for your patients.. sooo can i please have a reply to the above post....thanks again
  19. #18
    Jan 2007
    Bayonne, NJ
    im actually in Bayonne NJ where in clifton is the restaurant on rt.3?
  20. #19
    Very Active Member Alien109's Avatar
    Sep 2006
    Rockwell City, Iowa
    The kit has the EVO shift star and heavier spring. I don't think you will have to undercut the gears but it would help keep it in gear. I too want to hear when someone gets it installed and if it helps.
  21. #20
    Sep 2007
    Santa Clara, CA
    Alien,
    Thanks for saving a potential hijack of the thread (emails work great for side conversations Crayzj )
    So yea Soprano, the EVO shift star is cut in such a way where, in combination with the stiffer detent spring, makes sure it solidly engages in gear. When I put the kit in my 1999 VFR I really did not notice any additional force required; keep in mind the VFR back then did not have a micro bearing to begin with so that smoothed things too. I never have missed a shift since.
    My feeling is if you are going to go the the effort of installing the spring (really not a huge undertaking) defiantly put in the EVO Star too. It's your baby - no need to scrimp right?
    As an extra added measure I am sending my gears out to have them undercut but hey, my engine is out of the bike and the transmission parts are in a box... ::) I will be posting photos i took today of the defective gears and shifter fork on my other thread on 'Denied Warranty Coverage of 2nd Gear Going Out?' post on the Main Message board .
  22. #21
    Apr 2006
    Traveling America
    Quote Originally Posted by crayzj
    Since it looks like your in NY you should come down to Clifton Nj to hang at my restaurant...
    I run the Applebees where the Barnes and Noble,Chevys is.
    He seems to be a little confused to. He says that he owns it then that he runs it.
    Sorry that's all I have to say about that.
    Now back to the featured topic.
  23. #22
    Active Member
    May 2006
    [quote=CaliMan ]
    WTF?
    Did my thread really just get jacked by a manager of an Applebees in a strip mall in Jersey?
    It's like something straight out of Office Space...
    C'mon man - take this convo off line. We are talking about shift kits for a M109R not popcorn shrimp...
    [/quo This is a good thread that I;m very interested it. Thanks caliman I really want to know how this turns out.
  24. #23
    Sep 2006
    Mansfield, Texas
    Shift kit thread please......
  25. #24
    Feb 2007
    Oakley, Ca
    I did my fix today and took photos, I'll start a new thread since it's not this kit.
  26. #25
    Apr 2006
    Traveling America
    Quote Originally Posted by CBR1000DUDE
    And what kit did you use?
  27. #26
    Jul 2006
    Lake Ridge, VA
    Quote Originally Posted by rynosback
    He posted a great write-up in the How-To section: http://www.m109riders.com/forum/inde...c,25845.0.html
  28. #27
    Very Active Member Delmustator's Avatar
    May 2006
    Raleigh NC Area
    If anyone is interested, I have plenty of 1/2 inch steel tube if anyone wants it cut for this mod.
    I can probably ship it in a regular envelope too.
    Would you say it needs to be about 1/2 inch to 3/4 inch in length?
    -Del
    2006 VB M109R with a few MODs....
  29. #28
    Apr 2006
    Traveling America
    Quote Originally Posted by seapup
    Thanks.
  30. #29
    Jul 2006
    Lake Ridge, VA
    Factory Pro just put the <a href="http://www.factorypro.com/Prod_Pages...20109.htm">EVO Shift STAR</a> up on their website for consumer M109R use. Includes new star gear, spring and cover gasket. Bring on the group buy!
  31. #30
    Very Active Member Gramps's Avatar
    Sep 2007
    small ranch/farm out in the country 10 miles north of Burlington N.C.
    Even I think I would be up for this...and I don't even mind the niner shift.....but more positive is ...well MORE positive
