Results 1 to 7 of 7
Thread: For those of you who have a service manual. I need torque specs.
    Apr 2006
    Default For those of you who have a service manual. I need torque specs.
    I need to get the torque specs on the oil drain plugs, oil filter, and gear oil plug. Much appreciation in advance. I will owe you a beer if we ever meet :)
    Changes: Kury ISO Grips w/Stilettos, Tag mod w/LED Turn Signals, Drag S Mirrors, Maniac Mod, [s]Cobra Dragsters w/homemade baffles[/s]. Modified stock pipes with JR styled muffler, [s]Soon to be[/s] Edelbrock&#039;d air intakes, De-paired, Secondary throttlebody flaps removed, Cold plugs and PCIII<br /><br />
  2. #2
    Apr 2006
    Annapolis, Md
    Default Re: For those of you who have a service manual. I need torque specs.
    I would not think that there are no torque specs on those things.Â* The manual states that you tighten the oil filter by hand, then turn two more revolutions with there wrench.Â* I am picking up my manual soon.Â* Hope this helps.
    2013 Mid Atlantic Meet CLICK HERE
  3. #3
    The only time I've ever snapped a plug was when using a torque wrench.
    Not really sure it is necessary. Just "common sense tight" should do it.
    Have you smoked an H-D today?
  4. #4
    Apr 2006
    Changed oil 3000 miles ago without torque specs and nothing broke, and nothing leaks.Â* Common sense helps.Â* You will want a cap wrench to get the filter off though.Â* It's in a position where it's difficult otherwise.Â* Didn't have one and ended up having to use a strong belt and a vise grip, but there's not much room to maneuver.
    I'm waiting on K&N oil filters from Directline parts as they have a nut on the outer end and will make changes easier.Â* I'm hoping Hal ships soon as next change is eminent.
    Jerbear
  5. #5
    Apr 2006
    Well, just checking the oil is way too complicated. I wanted to make sure there wasn't any oddball bit of info concerning the plugs. Thanks, for the replies.
  6. #6
    Quote Originally Posted by 300CREW
    Only thing I'd recommend is to order a supply of crush washers from your dealer.
  7. #7
    Apr 2006
    Already have them :)
