clutch check
Results 1 to 4 of 4
Thread: clutch check
    Active Member
    Feb 2017
    Birmingham england
    Default clutch check
    Hi folks just had my clutch apart and checked everything out but i think i have put the spring washer on the clutch sleeve hub the wrong way around (dumb i no ) will this be a problem any advise is much appreciated
    Jan 2009
    Oro-Medonte, Ontario, Canada
    Quote Originally Posted by majalomalk View Post
    Service manual shows this:
    I did spend some time to browse through this blog to find definite answer to no avail, maybe you
    will have more luck. Use custom Google search small window on the bottom of every page here.
    Active Member
    Feb 2017
    Birmingham england
    Thanks for the reply i have got 7 8 9 the right way around its the washer behind the nut in the middle that holds it all on that is my concern it is a spring washer and the nut is a lock tab so don't see what difference it would make but they do say to put it a particular way around
    Jan 2009
    I see now which spring washer you are talking about:
    I did not take my clutch apart that far, so I am no help,
    hopefully someone will chime in, there were several guys
    here inspecting their tubular nut, so they for sure needed
    to reinstall this washer as well..
