Leather Saddlebags, First attempt
Results 1 to 13 of 13
Thread: Leather Saddlebags, First attempt
    Member Ivan's Avatar
    Feb 2012
    Woburn, MA
    Default Leather Saddlebags, First attempt
    Hi all,
    I would like to share with you a little project Im doing. This is my first attempt to make saddlebags (actually, its the first time I do anything related to leather so dont expect anything professional looking!).
    I first did a mock with a piece of cardboard, basically to get an idea of the largest dimensions the bag could have.
    Ugly box
    I then went to sketch up to lay out those dimensions, and started cutting down corners, putting some tapers and made it smaller than the initial box.
Name:	Saddlebag Dimensions copy.jpg
    Since I dont have a printer, I drew by hand the parts on a poster board and then I transferred those onto the leather.
Name:	Photo Jun 17, 12 20 42.jpg
    Only a biker knows why a dog sticks his head out of a car window...
    Feb 2012
    Woburn, MA
    I got a side of 8-9 ounces veg tanned leather and I started cutting. These are the parts ready for tooling and dyeing.
Name:	Photo Jun 17, 14 12 19.jpg
    I used a mixture of brown dyes to match approximately my java ostrich seat, and I started with the smaller pieces, the handle and the straps. I was amazed of how good it looks.
Name:	Photo Jun 17, 19 01 28.jpg
    Baloo didn't seem impressed...
Name:	Photo Jun 17, 18 03 52.jpg
    After this I started with the side of the bag. Since this is pretty thick leather, its a PITA to work the curves so Im molding the side by wetting it down slightly and making a lip from the edges and clamping it between two 2x4.
Name:	Photo Jun 17, 18 59 59.jpg
    This is all for today. I will keep putting pictures with the progress!!
    Very Active Member Bobby1048's Avatar
    Mar 2017
    Uniontown Ohio
    Looks good
    U. S. Army Retired I was in Aviation worked on helicopters.
    2011 M109R blue and chrome massive get up and go.
    Dec 2016
    Saskatchewan Canada
    looking great especially for first time
    Aug 2006
    Okanagan Valley B.C. Canada
    Oh this is great! Looking good so far, thanks for sharing with us.
    Sent from my iPad using Tapatalk
    Planing a British Columbia Meet, PM if you are interested? June 21-25, 2018 some place in southern part of the Kootneys.
    Very Active Member LoBlo's Avatar
    Nov 2016
    Texas
    Thanks for sharing Ivan. Hope it turns out well.
    Feb 2012
    Woburn, MA
    Default Slowly but surely...
    Quick update on the bag. I did some carving on the flap and stained all the parts before I molded the gusset with the same curves of the back.
Name:	Photo Jun 19, 18 04 41.jpg
    Then I glued the gusset to the back using clamps to keep everything in place.
Name:	Photo Jun 20, 20 39 32.jpg
    Then I glued the front and... voila!!
Name:	Photo Jun 20, 21 17 57.jpg
Name:	Photo Jun 20, 20 42 22.jpg
    There is a lot to do still. I need to sand the edges to even them out. Then I need to burnish them and stitch everything nicely. Then the flap, straps, etc...
    I also attached an aluminum plate to the back to reinforce the back a little bit.
    I'll keep having fun and posting pictures. I can't wait to use it!!
    Aug 2006
    Wow! It's coming along quite nicely! Thanks fir the update!
    Feb 2012
    Woburn, MA
    Alright! Project finished. Here is the bag before applying finish:
Name:	Photo Jun 24, 13 59 42.jpg
Name:	Photo Jun 24, 13 59 18.jpg
    Ant this is after applying finish. Somehow I like it better without the finish... oh well.
Name:	Photo Jun 24, 14 12 30.jpg
Name:	Photo Jun 24, 14 14 51.jpg
Name:	Photo Jun 24, 14 14 16.jpg
    I'm pretty pleased with the results. It's great trying something new and not to f**ck it up completely. The bag seems huge!! I don't know if I'll end up making the right-side bag. Now I'm waiting for the support to attach it to the bike. I'll put more pictures when everything is done.
    Jan 2009
    Oro-Medonte, Ontario, Canada
    Obviously a man of many talents!!! (seeing your fine carpentry tools in the background)
    I feel that shine applied as a finish will dull eventually, I also liked the 'unfinished' look more...
    Now you buy an Indian motorcycle to fit it on to... Will blend right in!... JMHO
    Aug 2006
    I like the finished look! Well done! Mighty fine, can you post a pic of your mounting when you get to that point.
    Very Active Member bludoc's Avatar
    Mar 2016
    Sweet Home Alabama
    Nice work Ivan! Молодец
    Sent from my VS990 using Tapatalk
    Happiness is a motorcycle, a full tank of gas and a long twisty road.
    Apr 2008
    mass
    Great job,came out awesome
