Leaking fork seal
Results 1 to 25 of 25
Thread: Leaking fork seal
    Very Active Member waytootall67's Avatar
    Nov 2012
    Calgary Alberta Canada
    Default Leaking fork seal
    So got myself a leaky fork seal, any have any idea what a shop is going to charge to repair?
    House of Chrome peg extensions, Full cut gel seat, CWI back rest,
    Cobra solo rack, Tsukayu hard bags, Gman TRE
    Factory installed GO FAST STRIPES
    Dec 2016
    Saskatchewan Canada
    a hell of alot more than doing it yourself
    I'm sure there is alot of how to on the forum
    Very Active Member Dam Guy's Avatar
    Nov 2007
    Huntington.West Virginia
    Do it your self. Check fork tube makesure you don't have a rock chip in it. Or it will leak.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Air Ride, Irate Grill, LED turn signals,Trick True Fire paint with Dragons,Over 500 LEDS,TI Peg feelers, Freedom exhaust. Coastal Moto Chrome rim 10" 300 Avon, SUMO-X 26"Rim tire /Dam Guy's Custom Fender, Modded Swing arm, SUMO-X 9 Degree Triple trees.
    Feb 2009
    Oklahoma City
    But are there not some special tools that are needed to take the fork apart to get access to the seal? Won't those tools set you back a bit as well? Myself, I also have one that leaks slightly, and not every time I ride it. I am just going to take the forks off and deliver them to my dealer. The cost goes way down when you do that. Done it many times in the past, though not yet on my Nine. Put bike on jack, remove brake calipers, remove front wheel, take forks off and drop them at my dealer. They'll call me when they're done.
    SILVER 2006 M109R. Brembo front brake calipers, Corbin Smuggler, Low & Mean chrome chin scoop, Cycle House chrome kickstand, Mean Cycles T-Rex speedo trim, Cobra Tri-Pro exhaust, LA Choppers xXx Big Air intakes, D2Moto tail light, Kuryakin clear signals, Yana Shiki One Inch Drop Risers, BreakAway Cruise Control, Suzuki Full Cut Gel Seat, JDA Chrome Fork Caps.
    Sep 2013
    Cary, NC
    Post
    The bike shop that I go to quoted me about $350 to replacing the seals and upgrading to the Racetech 1.1 fork springs. I bought and used the seal mate tool and my leaking stopped.
    JESUS IS LORD! 2008 Candy Max Orange Debeavered, Yana Shiki 2" bones, Grasshopper backrest, V&H Big Shots, Dunlop Elite-3 250/D251 150, LED brake lights, micro brite rear turn signals, Arlen Ness billet chrome grips, smoothie rear fender, ATRE, Wolo horn, Scorp motor mounts, Gel seat, Chrome M109R derby cover, A&R 6K HID.
    Very Active Member stormiezzz's Avatar
    Dec 2014
    Cape Town
    It's really easy to do with rudimentary tools. I did both of mine a little while ago and the 9 is not that difficult to do on your own. The hardest part for me was to get the bike propped up in the air without a trolley jack in order to remove the from wheel and the forks. I used tripods stands under the foot peg mounts. I also added 50ml more oil than recommended to the forks due to me being a a bit bigger than most guys and also the lowest part on my fork tubes were slightly pitted so I wanted to mitigate fork travel of the seal to the pitted parts to an absolute minimum. Once you have your forks opened, make sure to clean out the tubes properly. If there is the slightest amount of dirt in there, you are most likely going to end up with a leaking seal again soon. Also polish those fork tubes as best possible in order to remove any possible burrs from pitting.
    "RIDE IT LIKE YOU STOLE IT"
    Very Active Member Andy33's Avatar
    Jan 2010
    Calgary, Alberta
    Quote Originally Posted by waytootall67 View Post
    I did my fork seals over a year ago. Should be able to do both in an evening. I've got all the tools you need.
    Maybe its time to call Bob and have a Calgary get together.
    2009 M109 LEISO grips, Swing Wing pegs, Kury Shifter/Brake MOD, Rivco 2" Risers, V-Stream Windshield, Cobra Sissy Bar/Rack, Tach Relocated,
    Kury Mini Bullet Signals, Kury Scythe 2 Mirrors, Debadged, DeBeaved,
    LA Choppers 2" bones, Cycle House Kickstand, Chrome Stock Wheels,
    Sideburner Exhaust, Goldwing Intakes, Cobra Power Pro
    Feb 2009
    Oklahoma City
    Quote Originally Posted by BIG MIKE 109R View Post
    But, how much of that $350 was for the new springs? Don't lie to us now, probably better than half. Plus new oil, which you're going to have to buy anyways.
    Just googled the springs, cheapest I could find around $120. And I'm sure if you're buying the springs from the dealer they're closer to $200.
    Nov 2012
    Quote Originally Posted by Andy33 View Post
    Regardless it's time for all of us to get together, haven't talked to Bob in a year!
    Sep 2013
    Cary, NC
    Post
    I don't know the price of the springs but $350 was the otd price for the job. I have a good rapport with everyone at the shop and the service manager remembered that I bought $1100 in parts when I had my accident so he said he would look out for me with the leak issue. I bought the seal mate tool and the leaking stopped. I let the service manager know and he said that he would honor that price whenever I'm ready.
    Feb 2009
    Oklahoma City
    I'm going to have to look into that Seal Mate tool, as I think that is the problem with mine. It's very odd, yesterday set out on a ride. Within five miles, I stopped and wiped off the right fork. Rode over 100 miles after that without one drop showing up. And this is what it always does, leaks during the first few miles, then no more for however long I ride that day.
    Jan 2009
    Oro-Medonte, Ontario, Canada
    Make your own, and be done with it today...
    just Google : "Homemade Seal Mate tool" . I am
    100% sure you will find suitable plastic in your household..
    https://www.google.ca/search?q=homem...&bih=935&dpr=1
    Feb 2009
    Oklahoma City
    I'm headed off to work soon. And Mother Nature has taken care of any possibility of riding through Sunday. So I'll get it done over the weekend, while I will only be able to admire my bike in the garage.
    Feb 2012
    If you pressure wash you bike usually, you can force up the dust seal some road crap, and in turn up into the seal, and cause weeping. Seal mate will help, however if you have pitted lower legs, from following to close behind other vehicles, like me, you will need to linish your lower legs, and smooth them out. Cost me, last week, $175 for new seals and dust seals and oil and spacers for more preload , and to clean out and tidy the lowers.....from my Suzuki guys here.
  17. #15
    Member jtf6dla's Avatar
    May 2017
    Santa Rosa, NM
    Default Change it yourself, if possible
    If you can fix it yourself, that is best. A couple of years ago, my left front seal was leaking (06 M109). In a small town, I only knew of one mechanic - they charged me $300, then the other side began leaking! UGH! I have a 2013 Limited Edition now, and really hope I don't experience that any time soon. Good Luck!
  18. #16
    Dec 2014
    Cape Town
    If you have a set of plastic casino quality playing cards, you can use one instead of a seal scraper like the seal mate tool to see if you can remove the crud that is causing the leak. Obviously the tool is better but I have had success on one of my other bikes with a playing card. If it works, cool, if not, I would do the rebuild and be done with that leak.
  19. #17
    Jan 2010
    Calgary, Alberta
    Quote Originally Posted by stormiezzz View Post
    Great idea on the plastic playing cards.
    I've used business cards in the past. Works good enough to get me through a ride until the seals can be changed.
  20. #18
    Very Active Member 60ratrod's Avatar
    Aug 2016
    Spokane Washington
    I just did the seals on mine Saturday night. I ended up making a fork spring compressor to the tune of $7 with stuff from lowes. I think in total i was in the job about $130ish, parts and oil plus parts to make the spring compressor
    Current Rigs:
    2007 Chevy Sliverado 1500 xcab z71- "Inmate the 2nd"
    2006 Suzuki M109R (dark blue)- "Caboose"
  21. #19
    Feb 2009
    Oklahoma City
    Quote Originally Posted by SKIDMARK View Post
    I have never pressure washed my bike, it's never been in a car wash. Wash it at home using low pressure garden hose. And from what I can see examining the fork legs, no pitting. I avoid following too closely behind other vehicles, typically blow by them asap, even over double yellow lines. There's nothing like an 1800 cc motorcycle for passing a bunch of slow pokes.
  22. #20
    Feb 2012
    I wasnt talking, or quoting you, my info was for others. But OK, good on you.
  23. #21
    Nov 2012
    I'm going to try cleaning first and hopes that stops it.
  24. #22
    Sep 2013
    Cary, NC
    Post
    Did cleaning your forks stop the leaking?
  25. #23
    Very Active Member Javier109's Avatar
    Jul 2013
    Madison Wi
    Heres the tool i made to compress the spring, this is the only specian tool you really need.
    Life is not measured by the number of breaths we take, but by the moments that take our breath
  26. #24
    Nov 2012
    Tried it, road about 20 km, clean...was happy, next day little drop on the garage floor, now sad again.
  27. #25
    Aug 2016
    Spokane Washington
    here's mine. Not as nice as what Javier made, but it's functional. Aside from having to drill the holes for the bolts, i had to enlarge the top hole so i could get it on and off with the fork cap. I think i was about $10 in parts from Lowes. I used 2 nuts on each bolt to keep the bolts from moving around. I'm gonna improve it by putting in some threaded inserts
    Current Rigs:
