O2 Sensor question
Results 1 to 4 of 4
Thread: O2 Sensor question
    Aug 2016
    Perth, WA
    Default O2 Sensor question
    Many apologies guys if this has been asked before (I'm fairly certain it has). Ok, I relaced the left hand air filter on my 2012 M109R tonight - it got scratched by the garage door, my fault - anyhow, after I'd removed the air filter there was the wire from the O2 sensor just lying there. It's connected to the pipe on the other side, but not going anywhere. The bike has a set of V&H pipes on it. Do I need this re-connected or will it be ok as it is? Any ideas??
    Many thanks
    Alan
    Sep 2010
    McPherson, KS
    US bikes did not come with O2 sensors. However, there is probably a plug for them in the harness. But, if the ECU is not expecting to see O2 sensors there's probably not much use in plugging it in. The plugs may not even match.
    That is unless you have a Power Commander or other fuel control that needs the O2 sensor signal.
    Jan 2009
    Oro-Medonte, Ontario, Canada
    Default wire from the O2 sensor just lying there. It's connected to the pipe on the other sid
    Quote Originally Posted by mesmer View Post
    Many thanks
    Alan
    So what you are saying the new pipes have O2 sensors screwed in?
    One in each pipe?
    Member Chippy's Avatar
    Apr 2017
    Essex, England
    Many thanks
    Alan
    Alan
    Australian spec bikes same as Euro spec so work with O2 sensor on each header pipe, V&H for our bikes do not have O2 sensor bosses to fit the sensor in to so, have you got O2 sensors in your header pipes? If so then the cable should be plugged in. If you haven't got O2 sensors in the header pipes then doesn't matter if cable is plugged in. Do you have a tuner under the seat eg: Power commander, Fi2000, if so then the cable may be unplugged for a reason and have an O2 eliminator plug fitted.
