SET valve disable
Results 1 to 3 of 3
Thread: SET valve disable
    Member Chippy's Avatar
    Apr 2017
    Essex, England
    Default SET valve disable
    Hi there
    If I use one of those electronic boxes that plug into the valve wiring, will the SET butterfly valve be disabled in the open or closed position. I'm asking as I don't intend to swap out the exhaust but just mod the baffles.
    Jan 2017
    West coast, Finland
    Quote Originally Posted by Chippy View Post
    Hi there
    Spring turns valve fully open. I just debaffled my own exhaust.
    Sent from my E6853 using Tapatalk
    Nov 2014
    Southern Indiana
    Yea, I believe it's spring loaded, so if you disconnect the cables, it turns to full open.
