Gear Position Circuit?
Results 1 to 9 of 9
Thread: Gear Position Circuit?
    Apr 2017
    Detroit
    Default Gear Position Circuit?
    I need to pick up a signal from the gear position circuit. I made an Arduino nitrous controller and don't want it to come on in first gear. Anyone know what wire I can tap and what voltage is provided? Perhaps I can use the first gear timing retard signal? Much thanks for any help.
    Sep 2010
    McPherson, KS
    Right side wires coming out of back of the clutch cover. 3 wire white connector with pink - blue - black white trace. Measure voltage between the pink and black white trace for each gear.
    May 2006
    What he ^ said...and a question, considering you wouldnt want the Nitrus to activate by just hitting say 4th gear does this Adriano accommodate the RPMs or better yet throttle position so that the value opens under full throttle while in 4th gear? You can tap into the TPS circuit in the same area as the gear indiactor. The sensor is mounted behind the air box under the upper frame rail if im remembering correctly.
    Apr 2017
    Detroit
    Thanks guys. That should do it.
    RE: Question about the controller. I already have a window switch so I'm cheating for now and allowing it to handle RPM and TPS. One day I might incorporate it into the Arduino. TPS is super easy - RPM is a little more difficult code wise. I think I have it, but it could require de-bouncing the circuit and other possible pains I don't need right now. Perhaps in the future.
    What I have makes sure the system is armed and I am not in first. When it receives a signal from the window switch it will open stage 1. If I also hit the horn, it will open stage 2. If I hit the horn when not in window, it will just beep the horn.
    Sep 2010
    McPherson, KS
    If can't do code for the RPM you can get one of these https://www.summitracing.com/parts/s...FQ6NaQodqIwPzg
    Apr 2017
    Detroit
    Can someone post a picture of where these wires are located? I cannot find those colors on my bike.
    Jul 2008
    Forney, TX
    See TRods post below.
    Sep 2010
    McPherson, KS
    Quote Originally Posted by ebweiss View Post
    Apr 2017
    Detroit
    Thanks! That should do it.
