Cell phone charger top battery
Results 1 to 29 of 29
Thread: Cell phone charger top battery
    Very Active Member dreday1615's Avatar
    Aug 2014
    Default Cell phone charger top battery
    Hey everyone is it not wise to run a USB port to charge a cell phone or GPS through the battery? I hear different answers, battery is easier to get to for me....thanks
    Sent from my SM-G935T using Tapatalk
    Aug 2014
    Quote Originally Posted by dreday1615 View Post
    I meant to battery
    Very Active Member TM109R's Avatar
    Mar 2007
    Glen Ellyn, IL
    I meant to battery
    It's fine. Just make sure to turn off or unplug when not in use.
    Sent from Tod's Note 4
    Brakeaway Throttle Lock / Rivco Passenger Boards / K&N Air
    Very Active Member Stillfree's Avatar
    Oct 2015
    Toronto Ontario Canada
    Quote Originally Posted by TM109R View Post
    Buy metal not plastic
    Sent from my SM-G930W8 using Tapatalk
    Aug 2014
    Quote Originally Posted by Stillfree View Post
    Buy metal what?
    Aug 2014
    It won't drain the battery even when bike is not running?
    Mar 2007
    Glen Ellyn, IL
    Why I said turn off or unplug.
    Aug 2014
    Well i brought the usb adapter by battery tender that I can just disconnect when I get off the bike and not riding it for the rest of the day
    Aug 2014
    Mar 2007
    Glen Ellyn, IL
    You will be fine leaving this attached to your battery connections.
    Aug 2014
    Ok cool thanks
    Apr 2016
    Manteno Il
    I connected mine to a light pin and it turns off when the key is off but yeah it would take a few months to drain the battery even direct connection to the battery.
    Jan 2009
    Oro-Medonte, Ontario, Canada
    Yes, it consumes power if wired (unswitched) directly to the vehicle's battery even if it's not connected to a device. It converts the vehicles 12-14 volts down to 5 volts to power or charge iPhones, GPS, etc, and that conversion process consumes energy whether it's being utilized or not. You're better off to wire it through a switched 12 volt source so it only energizes once the bike is running or the ignition is switched to the accessory mode
    Very Active Member bludoc's Avatar
    Mar 2016
    Sweet Home Alabama
    I have this https://www.amazon.com/dp/B00W2Z04ZW?psc=1it has an on/off switch
    Happiness is a motorcycle, a full tank of gas and a long twisty road.
  17. #15
    Aug 2014
    Such as......
    Quote Originally Posted by bludoc View Post
  18. #16
    Aug 2014
    Wow wish I saw that, the battery tender usb is on the way already
  19. #17
    Very Active Member SouthernFattie's Avatar
    May 2013
    Southeast Louisiana
    Back of headlight nacelle.
    https://www.walmart.com/ip/12V-Dual-...hter/893091977
    The one I bought you can remove the 2 circular sockets and mount them where ever, just drill 1 large hole, socket is threaded.
    Each socket has its own cap/cover, so I removed it from the mounting plate and used seperately. When charging my phone,
    I just tuck wire under speedo housing. Damn near hidden.
    Or mount as is. More to cut though.
    Custom Z-Bars. Chromed Holey Grips. Scythe Knock Off Mirrors. Bullet Turn Signals. GMan ATRE. Cobra PowrPro (thanks Laurex). McNEMO Custom Rat Rod Exhaust. Custom Polished & Painted Stock Wheels. Smoked & Integrated Sequential LED Tail Light. Stealth LED signals under rear fender. De-beavered with plate mount. Edelbrock ProFlow Intakes. Plasti-dipped Speedo Housing, Chrome Rear Fender Rails, Tach Box and Chrome on Headlight Cowl.
  20. #18
    Aug 2014
    Quote Originally Posted by SouthernFattie View Post
    Seems like alot I want a simple set up
  21. #19
    Jan 2009
    But to be "drain proof" = "forgetfullproof", one needs to hook it up to 'switched' circuit, which is not energized when key is OFF.
  22. #20
    May 2013
    Southeast Louisiana
    2 holes. Cant get much simpler. 1 hole per socket. Or just use 1 socket for the USB-only, or the 12v socket only. Whichever.
    I did that with the 12v socket, but the USB is full time power.
  23. #21
    Oct 2015
    I went thru 3 cheap plastic chargers b4 buying a swivel metal handlebar clamped charger w/ auto shut down overload , led power amp indicator and USB / lighter Socket for about $45 - small , black , easy to install and never had any issues with it coming loose etc.
  24. #22
    Jan 2009
    Default but the USB is full time power.
    As I said, draw is minimal, but in Texas you do not winterize bikes like we are...
  25. #23
    May 2006
    Default Use a relay
    I have my power socket installed into the back black plastic piece of headlight bucket. I choose to go with the 12v socket vs a usb. I did this because for about $5-$10 you can buy a plug in usb adapter that plugs into the 12v socket which leaves you with access to multiple types of power sources.
    As for the wiring, I used a relay that draws its main power directly from a fused battery connection while tapping one of the orange light power wires to use as the off on switch. It is a very very easy process. Many people get nervous when relays are brought into the conversation Which in My opinion is needless worry. If you dont know how to wire a relay do a serch on youtube, there are plenty of videos that will walk you through the install. Simply speaking the relay will have 4 locations for wiring leads to connect to the relay. The leads are matched up with the lead directly across from each other. Two of those leads will carry the main power supply which means these wires need to be capable of carrying that power where as the other 2 leads act as the switch that turns the main power off and on and these wires can be as thin as the light power wire you tap. On each set of terminals you will have power (the "switch"set power will come from orange light power wire and the "main" power lead comes directly from your battery positive terminal) and the other 2 are Negative/ground wires that need to be connected to the black ground wires or back to negative battery terminal. Simple as that, easy peasy
  26. #24
    Apr 2017
    Ontario, Canada
    As mentioned, not a problem as long as the device you're using doesn't draw power when not in use, or has an on/off.
    I use this one (in Canada) hidden away, draws 0.02mA with no load. That means it would take about 50,000 hours to suck 1 Amp from your battery and you probably have 12 of them...
    https://m.canadiantire.ca/products/p...tedSku=0374560
  27. #25
    Very Active Member LoBlo's Avatar
    Nov 2016
    Texas
    I bought Rainey's USB charger and just wired it into the bike's "on" wiring.
    http://www.revo-cycles.com/shop/revo...r-port-socket/
  28. #26
    Apr 2016
    Manteno Il
    Quote Originally Posted by LoBlo View Post
    Looks nice but that is insane for a USB charger!
    You can't even see mine and it cost $12.
  29. #27
    May 2006
    Quote Originally Posted by Xfire68 View Post
    WOW that is one EXPENSIVE part and its absolutely unnecessary. I would agree with your statement but i dont even think it looks nice! My opinion, this is one of those things that are better off not being seen and a $10-$15 part at the high end is all that is needed, being flashy has no place here.
  30. #28
    Nov 2016
    Texas
    Naw, its pretty inconspicuous. Tucked nicely between the risers and down by the triple tree. Can't really even notice it, except to look for it. Keeps a lot of ugly USB cords from daggling acros the tank and even gives two outlets so to run the cell phone and the gps at the same time.
    As far as the cost...I look at the 109 as the 'Corvette' of cruisers. Go big or go home. But that's just IMHO.
    lb
  31. #29
    Nov 2016
    Texas
    Alternatively, you could always just go with a handlebar mount
    https://www.walmart.com/ip/MATCC-Mot...&wl13=&veh=sem
    lb
