new grip install
Results 1 to 25 of 25
Thread: new grip install
    Apr 2012
    belpre,ohio
    Default new grip install
    I am trying to install the karyakn iso grips.
    when i slide the grips on the rubber inside the grip
    wants to roll up. Any suggestions on how to get
    the rubber to stay in place?
    Mod's
    De-badged, Throttle lock\Cruise, Brake Pedal adjustment, Drilled out baffles on pipes,
    backrest mod. De-beavered, and polished wheels from Gottatooz.
    Quote Originally Posted by joel12mi View Post
    You bought the universal ones w/o the throttle tube didn't you?
    Apr 2012
    belpre,ohio
    Default no not really
    I bought the one with the tube but the grip
    pretty much fell off the tube so i am trying to
    get in on the oem tube because with
    the tube that came with the grips the throtle
    wont return.
    Mod's
  5. #4
    Very Active Member AWESOME109's Avatar
    San Diego
    If I remember right I twisted the grip on instead of just pushing it on. Hope that makes sense.
  6. #5
    Apr 2012
    belpre,ohio
    Default tried that
    Tried that and it goes on most of the way then rolls under.
    Quote Originally Posted by AWESOME109 View Post
    Mod's
  7. #6
    what part no are they?
  8. #7
    Apr 2012
    belpre,ohio
    Mod's
  9. #8
    6235
    That's what I have, no problem w/ the tube falling out of the grip. Went on fine.
  10. #9
    Very Active Member Tigz's Avatar
    Matteson, Il
    Have you tried spraying the inside of the grip with water and soap, then slide it thru.
    sent from Tigz Galaxy
  11. #10
    Apr 2012
    belpre,ohio
    I can spray wwd40 or something on there
    but i am not sure what that will do to the glue?
    it does need to stick.
    Quote Originally Posted by Tigz View Post
    Mod's
  12. #11
    What glue, once the tube is inside, there's nothing else to do. I have never seen the throttle tube "fall" out of the grip. It should have already been secured inside it.
  13. #12
    Apr 2012
    belpre,ohio
    When i mounted the tube and twisted the grip it came off the tube. So now i am trying to get it glued back on. All i did wast twist throtle so it wasnt like i had vice grips turning it.
    Quote Originally Posted by Big-[CENTER
    [/CENTER]B;1740071]What glue, once the tube is inside, there's nothing else to do. I have never seen the throttle tube "fall" out of the grip. It should have already been secured inside it.
    Mod's
  14. #13
    Send them back for defects and get a new set. If you end up screwing them up, they'll be no good and you'll have to buy another set.
  15. #14
    Apr 2012
    belpre,ohio
    I cant send them back. Bought them here on the forum.
    may end up buying another set it seems.
    Mod's
  16. #15
    Well, just becareful trying to glue the tube back in. You have to get it in in one try w/o stopping. Otherwise the tube will stop half way in and you'll be f**ked Some ppl have used hairspray, it will act as a lubricant on the way in and dry like a glue. Worth a shot and it won't ruin anything if it doesn't work.
  17. #16
    Apr 2012
    belpre,ohio
    Thanks can try the hairspray idea. At this point nothing is working. So if i screw it up will buy a new set i guess.
    Mod's
  18. #17
    Very Active Member festersvan's Avatar
    Mar 2011
    wales,uk
    I have the kury grips,no probs here either
    NO IMAGES OVER 400 PIXELS IN HEIGHT
  19. #18
    Apr 2012
    belpre,ohio
    Default JUST AS A FOLLOW UP
    The hair spray did the trick. Thanks Big B for the tip : )
    Mod's
  20. #19
    That's great Joel glad to hear it. :thumbup:
    sent from my galaxy S3 from somewhere outside space
  21. #20
    Very Active Member Wjduke's Avatar
    May 2012
    Fall River, Mass.
    This puts a damper on the guy who was on Bernie earlier for his "useless" info....good job B.
  22. #21
    Quote Originally Posted by Wjduke View Post
    Lol thanks Wayne. We know the real truth don't we
  23. #22
    The truth is a broken clock is right twice a day. You got lucky.
  24. #23
    Quote Originally Posted by TRod View Post
    Lol T don't hate. I didnt see you offer up any suggestions. Luck had nothing to do with it. Useful knowledge did.
  25. #24
    By the time I even got to the thread it was already answered. Useful knowledge? Whatever. Mostly your advice is useless knowledge.
  26. #25
    Very Active Member weasel848's Avatar
    Smithers, British Columbia
    next time, you can also try blowing compressed air between the grip and bar.
    E.
    Does this bike make my ass look, small?
