Results 1 to 25 of 25
Thread: new grip install
    Apr 2012
    belpre,ohio
    Default new grip install
    I am trying to install the karyakn iso grips.
    when i slide the grips on the rubber inside the grip
    wants to roll up. Any suggestions on how to get
    the rubber to stay in place?
    Mod's
    De-badged, Throttle lock\Cruise, Brake Pedal adjustment, Drilled out baffles on pipes,
    backrest mod. De-beavered, and polished wheels from Gottatooz.
  2. #2
    MoCo Maryland
    Quote Originally Posted by joel12mi View Post
    You bought the universal ones w/o the throttle tube didn't you?
  3. #3
    Apr 2012
    belpre,ohio
    Default no not really
    I bought the one with the tube but the grip
    pretty much fell off the tube so i am trying to
    get in on the oem tube because with
    the tube that came with the grips the throtle
    wont return.
    Mod's
  4. #4
    Very Active Member AWESOME109's Avatar
    Jan 2007
    San Diego
    If I remember right I twisted the grip on instead of just pushing it on. Hope that makes sense.
    DON'T DISTURB THIS GROOVE!!! Al B Sure
    The "Ignore Members" option is a great tool
    The more I get to know people, the better I like my dog -------- Mark Twain
  5. #5
    Apr 2012
    belpre,ohio
    Default tried that
    Tried that and it goes on most of the way then rolls under.
    Quote Originally Posted by AWESOME109 View Post
    Mod's
  6. #6
    MoCo Maryland
    what part no are they?
  7. #7
    Apr 2012
    belpre,ohio
    Mod's
  8. #8
    MoCo Maryland
    6235
    That's what I have, no problem w/ the tube falling out of the grip. Went on fine.
  9. #9
    Very Active Member Tigz's Avatar
    Feb 2009
    Matteson, Il
    Have you tried spraying the inside of the grip with water and soap, then slide it thru.
    sent from Tigz Galaxy
  10. #10
    Apr 2012
    belpre,ohio
    I can spray wwd40 or something on there
    but i am not sure what that will do to the glue?
    it does need to stick.
    Quote Originally Posted by Tigz View Post
    Mod's
  11. #11
    MoCo Maryland
    What glue, once the tube is inside, there's nothing else to do. I have never seen the throttle tube "fall" out of the grip. It should have already been secured inside it.
  12. #12
    Apr 2012
    belpre,ohio
    When i mounted the tube and twisted the grip it came off the tube. So now i am trying to get it glued back on. All i did wast twist throtle so it wasnt like i had vice grips turning it.
    Quote Originally Posted by Big-[CENTER
    [/CENTER]B;1740071]What glue, once the tube is inside, there's nothing else to do. I have never seen the throttle tube "fall" out of the grip. It should have already been secured inside it.
    Mod's
  13. #13
    MoCo Maryland
    Send them back for defects and get a new set. If you end up screwing them up, they'll be no good and you'll have to buy another set.
  14. #14
    Apr 2012
    belpre,ohio
    I cant send them back. Bought them here on the forum.
    may end up buying another set it seems.
    Mod's
  15. #15
    MoCo Maryland
    Well, just becareful trying to glue the tube back in. You have to get it in in one try w/o stopping. Otherwise the tube will stop half way in and you'll be f**ked Some ppl have used hairspray, it will act as a lubricant on the way in and dry like a glue. Worth a shot and it won't ruin anything if it doesn't work.
  16. #16
    Apr 2012
    belpre,ohio
    Thanks can try the hairspray idea. At this point nothing is working. So if i screw it up will buy a new set i guess.
    Mod's
  17. #17
    Very Active Member festersvan's Avatar
    Mar 2011
    wales,uk
    I have the kury grips,no probs here either
  18. #18
    Apr 2012
    belpre,ohio
    Default JUST AS A FOLLOW UP
    The hair spray did the trick. Thanks Big B for the tip : )
    Mod's
  19. #19
    MoCo Maryland
    That's great Joel glad to hear it. :thumbup:
    sent from my galaxy S3 from somewhere outside space
  20. #20
    Very Active Member Wjduke's Avatar
    May 2012
    Fall River, Mass.
    This puts a damper on the guy who was on Bernie earlier for his "useless" info....good job B.
    " Cinderella ", 2011, Candy Indy Blue, Halo Nation Alliance member. Not many mods. I bought it to ride.
  21. #21
    MoCo Maryland
    Quote Originally Posted by Wjduke View Post
    Lol thanks Wayne. We know the real truth don't we
  22. #22
    Sep 2010
    McPherson, KS
    The truth is a broken clock is right twice a day. You got lucky.
  23. #23
    MoCo Maryland
    Lol T don't hate. I didnt see you offer up any suggestions. Luck had nothing to do with it. Useful knowledge did.
  24. #24
    Sep 2010
    McPherson, KS
    By the time I even got to the thread it was already answered. Useful knowledge? Whatever. Mostly your advice is useless knowledge.
  25. #25
    Active Member weasel848's Avatar
    Jul 2012
    Smithers, British Columbia
    next time, you can also try blowing compressed air between the grip and bar.
    E.
    Does this bike make my ass look, small?
