Amsoil okay?
Results 1 to 18 of 18
Thread: Amsoil okay?
    Very Active Member forgetaboudit's Avatar
    Jan 2013
    West Bend, WI
    Default Amsoil okay?
    I've been looking around for new clutches online. Most say not to be used with synthetic oils. I haven't replaced the clutch yet, but was wondering with the stock clutch if synthetic amsoil would be ok to use. Also when I replace my clutch, would synthetic amsoil be okay to use? I really want to use amsoil, but not sure if it would cause more harm than good, and I never want to hurt my 9.
    Very Active Member porkchops9's Avatar
    Aug 2010
    Moore Haven florida
    Mobile 1. Is what I just went to when I did the push pin mod 2 weeks ago. Full syn and I haven't had any clutch slip that I can tell.
    ]I would rather be homeless than chromeless. She's got a few shinny do-dads on her.
    Jul 2008
    Forney, TX
    There are several here that run synthetic. I have ran synthetic and dino through mine and I have 42k on the clock and havent had any issues. Just make sure you use what the owners manual says and youll be good. I currently run Valvoline 10W-40. Clutch shifts better out of all I have tried and saves a little $.
    Sent from my DROID X2 using Tapatalk 2
  5. #4
    Very Active Member Dr CNC's Avatar
    Jan 2009
    Florida
    Quote Originally Posted by porkchops9 View Post
    I've always used Mobile 1 no issues. I did this weekend though it seems I might have broken a pressure plate spring, as all of a sudden I have much less resistance at the clutch lever than before. I've checked cable lower end return spring so can't really think of anything else it might be. I see some stuff on push pin mod what's that all about anyway??
    Marty
    "Four Wheels move the Body ~ Two Wheels Move the Soul"
  6. #5
    Aug 2010
    Moore Haven florida
    Quote Originally Posted by 06 M109R FL View Post
    Marty
    It gets rid of the clutch shutter, I have 21000 miles now and just started to get a little shutter so I pulled the push pin and ground it down a little. Do a search on it there is a real good step by step on it. It took about 30 mins to pull the cover off and pull the pin because I already had the pipes off to chop 6inches out of them.
  7. #6
    Jan 2009
    Florida
    Porter,
    Thanks didn't mean to hijack the thread. I've never experience any shutter so don't know if I'll mess with it. What filter do you use? I have 12k on mine never done my own oil change all had it done at shop they use Mobile 1 but I never specified filter want to say it K&N wasn't so lazy I'd go look LOL. Hoping this thing with the clutch is just pressure plate springs I ordered Barnett's to replace the OEM's
  8. #7
    Aug 2010
    Moore Haven florida
    I use k&n or fram.
  9. #8
    Rockdale, Texas
    I used Amsoil in mine with no problems. Still using it in my new bike. And fyi the stock clutch is the best one out there.
  10. #9
    Aug 2010
    Moore Haven florida
    Quote Originally Posted by antmor69 View Post
    I bet your new bike doesn't shutter, or does it?
  11. #10
    Very Active Member rockey's Avatar
    Jan 2008
    Music City USA
    Put Amsoil in mine before it hit 1,000 miles. Still occasional shudder but otherwise shifts smooth as buttah.
  12. #11
    Jan 2013
    West Bend, WI
    Excellent! Thanks for the info guys. I'll def be putting in amsoil after I put the shift star upgrade in. Good luck with the clutch issue 06 M109R FL
  13. #12
    Rockdale, Texas
    Actually not at all. Smooth as a Cadillac!
  14. #13
    Jan 2013
    West Bend, WI
    What weight AMS you using?
  15. #14
    Rockdale, Texas
    Quote Originally Posted by forgetaboudit View Post
    Amsoil 20w50 motorcycle oil.
  16. #15
    Very Active Member rnspark's Avatar
    Jan 2008
    Tampa Fl
    Default Amsoil
    with antmor69
  17. #16
    Jan 2013
    West Bend, WI
    Thanks guys! Gonna' be putting new blood in the beast next weekend.
  18. #17
    Very Active Member rcharles's Avatar
    Jan 2009
    Lyons GA
    Have used Amsoil since 1st oil change, but I have never had shutter. Made 2nd gear a little easier though. 20W-50 BTW
  19. #18
    Apr 2008
    Mobile Alabama
    Quote Originally Posted by rcharles View Post
    Same here over 13000 mi .
