Is there a Hydraulic clutch conversion for the M109R available. I have broken so many cables that I think it is now time to covert. On the other hand why does the Boulevard cables break so easy?
Yes there is one , made by Rainey
http://www.m109riders.com/forums/sho...d.php?t=155257
Its all about adjustment. Back off on the cable adjuster so you can adjust the cable on the pull side. Adjust so you have it pull all the way in and it shifts smooth. That way you have all the play you can get out of your system.
What you want to check is take the bike out and put her under stress in 2 gear and feel to see if you have a little play at that moment. If so, you have it adjusted correctly.
After you have it adjusted. Ride it for a bike and see if you have to do a fine adjustment. Just turn the adjuster half turns will be plenty.
Your cable will love you for it.
thanks![]()
"Motorcyclist are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what make of machine he rides as long as he belongs to the clan" - Walter Davidson 1920.
