Results 1 to 8 of 8
Thread: Clutch cable finally!!!!
    Very Active Member Torn's Avatar
    Jun 2009
    Central VA
    Default Clutch cable finally!!!!
    My clutch cable finally gave out after 36k miles.....had to change it in parking lot while at work.....easy but for putting in bottom part...I've had the extra cable in tank bag for almost a year and a half should I be worried about lubing it?
    "Motorcyclist are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what make of machine he rides as long as he belongs to the clan" - Walter Davidson 1920.
  2. #2
    Very Active Member Robert May's Avatar
    Jun 2008
    Picayune, MS.39466
    Just lube it up when you get home. It's been a bag right?
  3. #3
    Very Active Member Nitrogary's Avatar
    Feb 2011
    Portland Oregon-Natures Natural Sunblock
    Quote Originally Posted by Torn View Post
    ...and due your wise move at carrying a cable, you just saved yourself a whole mess of grief, and possible a tow bill....GOOD JOB BRO ! i got my cable stashed on the bike too
    2007 Black M109R, Metzler 260/160,Debadge/Beav,HK Sideburner,Cobra Power Pro CVT,dropped 2",PC'd wheels,Ducks Cowl with LED's (yes,the rear seat cowl ! ),Kury all around,Holley Intakes,Garmin,2" Risers,Driver Backrest, Jardine Quick release billet backrest,Tach relocate,Odyssey battery, YS side plate,Alarm,V-stream sport, Factory engine guards, matuza GA bags on ghost brackets, Throttle tamer, jt's night rider. Gel seat, more to come
  4. #4
    Feb 2009
    Oklahoma
    Good on ya pal, for having the foresight to keep the spare on you. I keep a spare, in the bag, under the seat, along with a piece of string for the pull-through. I do not believe you'll need to worry about lubing it right away. Just do it when you get around to it.
    Mine has 17,500 miles right now, and I just inspected the ends last week. No sign of fraying. I lube the cable once a year with Dri-Slide.
    It's always better to have it and not need it, than need it and not have it.
    Sent from my Super Duper Cool Anus using Tapatoot!
    2006 M109R. Corbin Smuggler, Low & Mean chrome chin scoop and Reeper front fender, Cobra Tri-Pro exhaust, Big Air intakes, D2Moto tail light, Kuryakin clear signals.
  5. #5
    Very Active Member BigBully's Avatar
    Jul 2012
    Woodbridge, Va
    I have my spare running along side my current one and have the end at the handlebars wrapped in black tape. You really wouldn't know it was there unless I told you.
    2011 Black, Cobra PowerPro, Debeavered, DeReflectored, LED Licence plate light, 280 Metzeler Rear/160 Metzeler Front, Legacy Wheels, Sportiva HID Headlight, 2.25 Lowering Bones, Chrome Grill, Chrome Motor Mirror Plates
  6. #6
    Very Active Member fatboy99's Avatar
    Jul 2012
    Cashville, Tn
    Is it really necesssary to carry a spare cable, will it not give you some inclination that it worn and time to change before it breaks? At 36000 m i would be paying attention to a lot of things that are about to wear out at that point. I would think that it was time to change anyways. Preventive and general maintenance and inspections can get you a long way. Good to have that cable and tools for on the spot change thou. Is this a weak link on the 109 that can happen at low miles with no warning so that I need to be carrying a spare?
  7. #7
    Jun 2009
    Central VA
    Quote Originally Posted by fatboy99 View Post
    I got mine at 15k and rode with it since...it broke on the rear part so no warning other than I could tell it was breaking because it felt spongy no matter how much I adjusted it. While i was adjusting it bang ....it just snapped. I would start carrying one with that many miles..
  8. #8
    Member Rain's Avatar
    Oct 2012
    Surprise, Arizona
    Default Clutch Cable
    My cable snapped two weeks ago with no warning at all. The weird part was that it happened while crusin at 40 miles an hour on a city road, and it snapped somwhere in the middle, not on either end. Figure that one and at only 15,040 miles. Need to be very careful when adjusting and lubrication make sure you have at least 10- 15mm play in the clutch handel, They are known to snap if there to tight. You did really good carrying the extra, smart move. I always keep one under the seat.
    "It's not about where you're going, it's the adventure getting there"
    Rain
