Results 1 to 8 of 8
Thread: Levers
    Aug 2011
    St.Marys, Ontario Canada
    Default Levers
    I was thinking of getting some aftermarket levers... I read on here somewhere ....that different model years have a different style of lever!
    I used the search and came up with quite a variety of random stuff!
    If anyone knows ...please chime in!
    I have an '09 and on DLP they sell some levers that are for 06-08!
    will they fit or did they change for 09?
    thanks
  2. #2
    Sep 2012
    Chicago, Il
    Default RE: Levers
    Quote Originally Posted by grumpg View Post
    thanks
    The clutch lever is different. There is a difference in the radius of the curve where the lever inserts into the controls that cause it to bind. Also an '09 clutch lever has a closer reach to the handlebars than earlier models. Tigz and myself tried to install an aftermarket 08 lever as well as an 07 stock lever and they both did not work. I have an '09 as well. The brake lever seems to be the same though. Hope this helps.
  3. #3
    Aug 2007
    Montreal subburb
    newer model on bottom
    both Suzuki stock levers
    I don't know which year the change started
Name:	new clutch levers.jpg
    Every Time You Lift Your Tank Beware Of This .
  4. #4
    Very Active Member Wjduke's Avatar
    May 2012
    Fall River, Mass.
    If that's for an M109, I have an 11, and the top lever is what's on mine. Photo below.
    " Cinderella ", 2011, Candy Indy Blue, Halo Nation Alliance member. Not many mods. I bought it to ride.
  5. #5
    Aug 2011
    Quote Originally Posted by Wjduke View Post
    I'm really confused now....My clutch lever looks like the bottom lever ...'09
    Has anyone replaced their stock levers with aftermarket ones on 2009 and newer
    If so... where did you purchase them from?
  6. #6
    Very Active Member PanamaJack's Avatar
    Feb 2011
    Panama, Central America
    Quote Originally Posted by Kazimodo View Post
    I can tell you!!!!
    they changed from 08 to 09!!! those basterds!! lol!
    Edit: I have bought older levers, and had had to grind them to fit the handler, no biggie it can be done with dremel..
    2.25"Bones/2"Risers/StebelHorn/TitaniumFeelers/EngineGuards/StrdCutGel eat/K&NAir&OilFilters/JoeFloridaLED/LEDVoltimeter/GIPRO/USBdoc/Debeveared/FI2000/o2Sensor'sEliminator/KuryBlkGrips/PushPinMod /MotorMounts/Duck'sCovers
  7. #7
    May 2012
    Fall River, Mass.
ID:	75941 I don't know, but this is the lever on my 11 and I'm not sure it's either of the pictured ones earlier. It looks like it's in between them both to me, especially on a closeup view. I don't have a closeup pic for here.
  8. #8
    Apr 2011
    Pennsauken, New Jersey
    thanks
    I was confused with this too. Even on different websites there was all different years. I just called yani shiki direct. The change was in 09 on the clutch lever. No change in the brake lever. I ordered them while on the phone, received them and installed no problems. P.S. sometimes a phone call pays off-Even yani shiki had the wrong years listed on their website. They were very good to deal with and he actually corrected the listing right then while I was online!
