Results 1 to 13 of 13
Thread: Oversized oil drain plug needed for stripped oil pan
    Very Active Member Syco's Avatar
    Apr 2009
    SE Minnesota
    Question Oversized oil drain plug needed for stripped oil pan
    Well I unscrewed the rear oil drain plug yesterday and the oil pan threads came out with it. Now I can't tighten the plug anymore and it has a slow oil leak. I afraid to ride it now cuz I don't want it to come loose and dump the oil on the road!!
    Since a new oil pan will cost $160 at Oneida I first wanted to try using an oversized self tapping oil plug but I cannot seem to find one.
    According to this chart: http://www.magneticdrainplugs.com/su...otorcycles.htm
    our bikes use a 14mm x 1.25 size plug but NAPA only has these in 14mm x 1.5
    I can't even find one of these with Google.
    Anybody have any good suggestions??
    -Thanks in advance for your help!!
    2006 Black: Cycle House Big Air Kit, debaffled stock exhaust, Cobra Fi2000r, GIpro, Stebel Horn, Full Cut Gel Seat, Dyna Beads, Amsoil Synthetic, Vstream Touring light tint, Big Brass Bawlz
  2. #2
    Active Member
    Oct 2011
    Breslau, Ontario, Canada
    I did the exact same thing to my bike. I put a helicoil in and used the stock plug. Hope that helps you.
    2009 M109R LE
    Ralley stripe paint. Integrated tach. Custom speedo and tach faces. Blue speedo and tach LEDs. ISO Grips. Throttlemeister Cruise control. Stock exhaust - Debaffled. Debadged. Debeavered.
    ATRE. Forward controls. HID kit. Full cut gel seat. LED wrap around rear signals.
  3. #3
    Very Active Member WindyCityDave's Avatar
    Sep 2006
    I used JD Weld for stripped threads, works well.
    WCD
  4. #4
    Very Active Member Captnpirate's Avatar
    Oct 2011
    Port Saint Lucie, Florida
    Or you could buy a new.....well used but in great condition, oil pan from me..... PM me if interested. Dennis
    Go Big or Go Home
    '07 RED -
    Cycle House Big Air intakes, Debadged/Debeavered, PC III, Kuy grips and pegs, 50 watt driving lights, 260 Metz., sport windshield, chrome wheels, Gen III Knight Rider, Drivers Backrest, Dragon Tail Light, Derby and Side Lic Frame, +2 risers, 5" Cannon.
  5. #5
    Very Active Member jhorsf's Avatar
    Sep 2011
    England
    Buy a helicoil kit http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
    or take it to the shop and have it helicoiled
    http://www.youtube.com/watch?v=sQHRB2ElZJ0
    very slightly modified
  6. #6
    Jul 2007
    Westport Massachusetts
    You guys are putting way to much on the bolts guys.
    Its only oil. I've used the same setup for over 60,000 miles and no weeps. I do the same for the filter. I put it on with my hand, snug. It comes off way easy. No tools for the filter.
    The bolt I just snug it to the washer. Then just check for weeps. If not, your in the ball park.
    I have never changed my plug washers.
    You don't have to do the bolts to spec.
  7. #7
    Very Active Member rnspark's Avatar
    Jan 2008
    Tampa Fl
    Default Drain Plug
  8. #8
    Mar 2007
    West Virginia
    They make these in different oversizes, which you pick depending on how badly the threads are stripped. A single oversize (+1) will basically rethread the hole if there are some threads left. A double oversize (+2) will make new threads completely. So you have options, you can even use a standard 1/2" drain plug in a double (+2) and it will work just fine, making new threads as it goes. The aluminum in the pain is soft, and the oversize plugs are tapered so they start easily. In the correct 14 x 1.25 thread you would only need a single oversize to rethread it.
    Some reading that may give you some tips:
    http://www.m109riders.com/forums/sho...d.php?t=138530
    http://www.m109riders.com/forums/showthread.php?t=90657
    http://www.m109riders.com/forums/sho...d.php?t=151512
    Life has no remote control, get up and change it yourself.
  9. #9
    Sep 2010
    McPherson, KS
    I agree. I've used a +2 1/2" drain plug before. The thread pitch is almost exactly the same as the 14mm drain plug threads.
  10. #10
    Very Active Member asviewedfrommars's Avatar
    Feb 2010
    Vancouver, B.C.
    I had a stripped drain bolt in my oil pan, which was caused by a careless mechanic at the Suzuki dealer (they agreed to repair it).
    The oil pan is made of aluminum and very soft, so torquing those bolts, in my view, is important.
    If you decide to helicoil, you could have a metal shop do it for you.
    BTW, you can easily remove the oil pan while the bike is on its side-stand.
  11. #11
    Apr 2009
    SE Minnesota
    Thumbs up
    I used the (+2) 1/2" piggy back drain plug from NAPA and it seems to be working pretty good so far. No leaks. Total cost: $6.50
    I agree, been using WAY too much torque on those drain plugs. They only need to be 'snug' enough to keep them from vibrating out. I will use a much softer touch on these in the future
    Thanks for all the help, you guys are awesome!!!
  12. #12
    MoCo Maryland
    Quote Originally Posted by Syco View Post
    That's why there is a torque value for them. Might wanna try that next time.
  13. #13
    Mar 2007
    West Virginia
    Glad that worked out for you. I usually keep one of the 1/2" around as they will fit the drain plugs on most cars and bikes. My old Sportster has one screwed into the oil tank drain on it.
