Thread: fI light...again
    Member steveah's Avatar
    adelaide, south australia
    Default fI light...again
    hi all, got a fi light problem, dealer says it is the excva module, wouldn't look at it 'cause i have after market pipes! so the pipes are on my garage floor, nothing appears to be amiss with the module in question, the cam s in place and tight, the light is intermittent, so i'm wondering if this can be done away with, trick the ecu into thinking the box is still there, like you do with the o2 sensors, does anybody have an idea?
    appreciate any help, i'm quite sick of that nasty little red light.
    Very Active Member Tigz's Avatar
    Matteson, Il
    You can just pull the #7 black/brown wire off the ecu and call it a day.
    Default it won't look?
    Quote Originally Posted by Tigz View Post
    thnks Tigz, the ecu won't go looking for the input?...
    i have a aual but it is for an 06, doesn't show anything on number 7, shows excva position sensor as being number 5....gues i better go pull the side covers off!
    Quote Originally Posted by steveah View Post
    The no. 7 is the input. That's why you're getting the code.
    Sent from my ultra cool Lightningbolt using Slapatalk
    Active Member Papi07M109's Avatar
    Alvarado, TX
    I'm having the same problem. Shop says my O2 sensor may have back out some. Said to try to tighten it and see it that works. Cobra pipes.
    Sent from my Pimp iPhone using "Slapahoe"
    RIDE IT LIKE YOU STOLE IT...
    Alvarado, TX
    Did the #7 fix yours?
    Very Active Member antmor69's Avatar
    Rockdale, Texas
    Quote Originally Posted by Papi07M109 View Post
    If you have the code for the set valve then pulling the 7 pin will get rid of the code. Then remove the dead weight of the actuator, tape up the plugs on the bike and you'll never get that code again.
    http://www.mym109r.com/howtos/m109-disable_set.pdf
