Results 1 to 13 of 13
Thread: Irate Grills
    Sep 2012
    Chicago, Il
    Default Irate Grills
    Hey Everybody,
    For anyone that missed the last sale on the irate customs radiator grills (I did), they have them listed on ebay for $49. Just search for "m109r grill", they are listed towards the bottom. The sale is on for only 48 hours. Unfortunately it is only for select designs. Good time to pick one up. Hope this helps.
  2. #2
    Very Active Member WindyCityDave's Avatar
    Sep 2006
    Thanks for the "Heads Up" !
    Here's the link: http://stores.ebay.com/Irate-Customs...=p4634.c0.m322
    WCD
  3. #3
    Very Active Member cajuncop835's Avatar
    Sep 2011
    Houston Texas
    Good find ! Thanks for the info
  4. #4
    Active Member TTransport's Avatar
    Sep 2010
    Denver/Austin
    Great deal, thanks just ordered one!
    //GrassHopper/GelSeat/3" Riser/CF Riser & Speedo & Lower Frame Trim/Chrome axle cover/Sport Windshield/1.5" engine guards/Kuryakyn Transformer Grips & Throttle Boss, Constelation floor boards / Highway pegs / Tank Cover / Dunlop250 rear / Metz 160 Front / 2" Bones / Shayne TX Side Mount / DeBeaver / Cobra Power Pro / Freedom Performance Curves
  5. #5
    Very Active Member stevem109r's Avatar
    Nov 2011
    Australia nsw
    yep got one.
  6. #6
    Very Active Member MalM109R's Avatar
    West Malaysia
    Default Sharp burrs
    Got mine yesterday afternoon. Not sure if they cut it using water jet or laser cutting, the inside (the side facing the radiator after installation) is full of burrs that can cut the fingers if you are not careful while washing it after installation.
    They have a warning about the sharp edges and points while handling and cleaning.
    A de-burring tool might be handy in taking away the burrs. So happens I have one and it can take the burrs away but can be quite taxing. Maybe a small file might do the job faster as the curves can be a bit difficult to get to.
    If a 10 is near impossible, then we all at least have a 9!
  7. #7
    Nov 2011
    Australia nsw
    Think the same thing. I was going to run a small file along the edges.
    Sent via electronic carrier pigeon
  8. #8
    West Malaysia
    Quote Originally Posted by stevem109r View Post
    Gonna do just that tonite, the burring tool is a bit difficult. It cleaned the burrs at the outer edges of the grill with no problem, but the profiled edges are a bit difficult to have a 100% de-burred.
  9. #9
    Nov 2011
    Australia nsw
    Good luck
  10. #10
    Active Member clark_kent's Avatar
    Feb 2012
    Keswick, Ont
    Ordered, thx for the info!!
    2009 M90 Blue - Lowering Bones - 2 1/2" - ISO Grips w/ stiletto tips, Throttle Boss, LED Signals, Drilled Exhaust, De-beavered, Side Lic. Plate Mount, Blue LED accent lights, 240 rim and tire, TRE, M109 Radiator Shroud, Scythe II mirrors, Grasshopper backrest
  11. #11
    Very Active Member cape109R's Avatar
    May 2011
    BC
    Sale is over in 10 mins.
    "Man, you were really flyin' when I passed you"
  12. #12
    Very Active Member My1st109's Avatar
    Nov 2011
    Baker FL
    Thumbs down
    Dang! Missed it again!
  13. #13
    Nov 2011
    Australia nsw
    My $49 grillClick image for larger version.
