Results 1 to 14 of 14
Thread: Engaging rear wheel hub with final drive
    Very Active Member 2007LE's Avatar
    Jul 2009
    Macon, GA
    Default Engaging rear wheel hub with final drive
    I've changed my tires and removed the rear wheel at least four or five times since I've owned the bike. Every time I try to re-engage the rear wheel hub with the final drive, I have to play with it for at least 20 minutes. I insert the axle all the way across to keep the tire level. It's nothing but dumb luck when it finally engages. Does anyone know the secret to getting these gear teeth to align and slide together? Are there matching points on both sides to line up or what? Appreciate any pointers.
    Bumfoozled
  2. #2
    Rockdale, Texas
    Do you have the bike in gear when you're doing it?
  3. #3
    Jul 2009
    Macon, GA
    Quote Originally Posted by antmor69 View Post
    No. It's usually in neutral so that I can spin the wheel.
  4. #4
    Jul 2009
    Macon, GA
    Quote Originally Posted by 2007LE View Post
    Wait a minute. After saying that, I just realized that the wheel is able to spin because the wheel isn't engaged to the final drive yet. It's just spinning on the axle.
  5. #5
    Rockdale, Texas
    Right. Put it in gear before you try to mate the splines together. It will hold the hub splines still and you can just rotate the wheel and voila it will go on.
  6. #6
    MoCo Maryland
    Yep, it's the luck of the draw. I stabbed it on the first try when I did my 280. However, I did look in the housing to see where the spline was. I slid the shaft in and when it hit the spline I just wiggled it around and it slid into place.
  7. #7
    Very Active Member lincoln1003's Avatar
    Jun 2010
    Little Falls, MN
    one of the members on here recommended using a floor jack to get the tire high enuf then slide the axle thru dont worry about the spacer yet then spin the tire untill it locks into place then pull the axel a little bit and add the spacer ... worked perfect !!
    08 109 Candy Max Orange, Vance & hines Big shots and fuelpak, Arlen Ness big suckers, debeaved
  8. #8
    Jul 2009
    Macon, GA
    Big-B
    Thanks to both of you!! That should make it a lot easier next time. That was the only part of removing the rear tire that I really dreaded - aligning the hub again.
    P.S. I haven't learned how to put two "quotes" in a response yet, so I just used the copy/paste for Big B's response.
  9. #9
    Apr 2006
    Annapolis, Md
    put it in gear.
    2013 Mid Atlantic Meet CLICK HERE
  10. #10
    MoCo Maryland
    Big-B
    The small icon next to the reply tab, you click that for as many posts as you want to quote, then on the last one click the reply w/ quote tab.
  11. #11
    Very Active Member snoobzilla's Avatar
    Jun 2009
    Rochester, NY
    My chromed rim was VERY difficult to get on so I made a custom spacer (about 2") with pvc to squeeze wheel on. Put between the head of the axle and the drive hub it is just long enough to allow me on the brake side to put the axle nut and normal spacer inside of the right side of the swing arm. With bike in gear, tighten a little, rotate wheel until splines align, then tighten until there is enough space to fit brake bracket in (approx 1/8" between wheel and hub on drive side). Then remove axle and custom spacer, replace axle.
  12. #12
    Jul 2009
    Macon, GA
    Thanks!
  13. #13
    MoCo Maryland
    Thanks!
    welcome
  14. #14
    Very Active Member BigpapaM109's Avatar
    Oct 2010
    Germantown, MD
    Quote Originally Posted by lincoln1003 View Post
    Exactly how I do it but yes, it must be in gear.
