Results 1 to 22 of 22
Thread: MESH GRILLE INSTALL HELP
    Member s.wood's Avatar
    Mar 2012
    NYC
    Default MESH GRILLE INSTALL HELP
    First , i would like to say hello, from NYC...this is a great site with a wealth of info...i bought a mesh grille to replace factory grille on the bully..it came with no instructions and i have looked and only saw a post about moving gas tank...but the photos didn't show up..so if anyone has replaced there grille can you please tell me the steps to do so...i jsut wanna make it as easy as possible don't wanna start pulling unnecessary things apart
    thanks
  2. #2
    Jan 2009
    Site Co-Sponsor, Zephyrhills, FL
    You should only have to pull the gas tank back a little to get to 2 screws, one on each side, to disassemble the radiator shroud. On the bottom center black piece of the shround, there are 2 "push pin" connectors you have to remove to separate the left and right sides, and the top middle section snaps together. When you remove the top 2 screws, slide the side piece up and out away from the neck cover to separate.
    -Josh
  3. #3
    Apr 2008
    Mobile Alabama
    Be careful not to spread the sides of the rad shroud to far apart they can crack where they a connected at the bottom , Easy job take your time be careful .
  4. #4
    Mar 2012
    NYC
    thanks , i will give it a shot,,,sure would love some photos of this
  5. #5
    Very Active Member Wjduke's Avatar
    May 2012
    Fall River, Mass.
    I have a new grille to install this weekend...following this thread for tips too!
    " Cinderella ", 2011, Candy Indy Blue, Halo Nation Alliance member. Not many mods. I bought it to ride.
  6. #6
    May 2012
    Fall River, Mass.
    I just want to add that I know a lot of you guys are saying how simple a job this is, what's their problem...and I'm sure it is. Guys like us with little or no tools, and want to try to work on our bikes a little, is the reason for this thread ( speaking for myself! ). Personally, I think there's enough info here right now, so thanks!
  7. #7
    Very Active Member drgncore's Avatar
    Jul 2011
    San Diego, CA
    http://www.youtube.com/watch?v=QlWwmEuPtOk
    found this on Youtube, it's from Low and Mean, and it's for their chin scoop install, but it shows how to disassemble the radiator shroud that will give you access to the grille.
    2011 Indy Blue M109R - Rainey's REVO 6" Monster Cannon, Xtreme Revolutions Ultra Stage III Intake System, DLXPRODOX Custom Forward Controls and Pegs, 2" Lowering Bones, Stebel Horn, X-TRE, Kury ISO Grips, Scythe II Mirrors, 8k HID, Cobra PowerPRO Autotuner, Clear Taillight w/Integrated Turn Signals, Grasshopper Backrest, Debadged and Debeavered.
  8. #8
    Aug 2007
    Montreal subburb
    You guys want pictures ,
    you shall have pictures .....
    the Irate grill comes with 3 pages of install info ,
    at top right corner of page one , there was a chrome screw/bolt scotch-taped.
    here are the 3 pages from a scan .
    I have no control over this ..
    the pages show here , page 3 - 2- 1
ID:	74663   Click image for larger version.
ID:	74664   Click image for larger version.
    Every Time You Lift Your Tank Beware Of This .
  9. #9
    Jan 2009
    Quote Originally Posted by Wjduke View Post
    Everyone has their level of mechanical knowledge or skill. It might be that you have never held a screwdriver, or you just aren't sure how something comes apart, ad you'd rather not break off a mounting tab because you pulled left instead of pulling right.
    I had a roommate who was afraid to check the air in his tires when I met him. By the time we parted ways, he'd remove the front clip off a mitsubishi eclipse, installed his own intercooler setup, and put it back together with me not even being there to help hand him tools.
    There is no stupid question. IF you don't know, ask. Speaking for myself, I love sharing knowledge and information. IF it saves you the aggrevation of taking it to a dealer, or paying to replace a part that was unnecessarily broken, then it's worth asking.
    -Josh
  10. #10
    Apr 2008
    mass
    I told you if you ever need help I am here to help I have plenty of tools just let me know
    06 silver,500 LEDS,lots of extras and the 1st ever ducks floating S cover
  11. #11
    Very Active Member LOFLYR's Avatar
    Mar 2012
    Boise, ID
    Might have already been posted but here is a vid from Low and Mean
    http://www.lowandmean.com/index.php?...mart&Itemid=60
    It is pretty straight forward once you get started, sounds scarier than it is.
    My advice, just be very patient, don't force anything. This bike is unfortunately made with a lot of cheap plastic, don't force anything and you should be good.
    2007 M109R Pearl White - Mods: Gutted/Debaffled Exhaust, Yana Shiki 2" Bones, TDE TRE, V-Stream Windshield, Debadged, Debeavered, Kury Rear Tails, Tach Relocated, Kury ISO Grips, Kury Transformer Throttle Boss, Baron Bullet Bar Ends, Kury Switchblade Pegs, Cyclehouse Levers, Boulevard Mirrors, Rivco Highway Pegs, Corbin Seat, Metz 240/160. ​RIP
  12. #12
    May 2012
    Fall River, Mass.
    @ Kenny, I have tools at work, and I can handle this...I hacked the job on the HID install, broke a push pin, scratched the nacelle, etc...learning as I go, but I remember your offer!
    @ the other guys, the grille I got is from Ferreous and they shipped a one page instruction sheet. I was looking for that one little thing that would stop me from snapping something! I appreciate everything said here and I see what goes on in the forum as far as help, and it's great from all of you.
  13. #13
    Active Member
    Mar 2012
    Mexico
    Quote Originally Posted by gottattooz View Post
    -Josh
    Totally.
    In the end, we are all ignorants, the thing is that each of us ignores different things.
  14. #14
    May 2012
    Fall River, Mass.
    I'm going to emabarrass myself in front of the world right now, but who cares...I was raised in a gas station business owned by my father. My brother was the wrench, I was the "people person" at the pumps. I've been in automotive for over 30 years total, including still to this day. Don't own a wrench...I worked for an electrical contractor as a purchasing agent in between. During a break, I looked down at an electricians tool pouch. He had Klein screwdrivers. I actually asked him what the plus and minus symbols were on the handle !!! I had never seen that and that was one of my biggest duh moments in my life. I never lived that down either, as you can imagine!
  15. #15
    Very Active Member mlrman's Avatar
    May 2011
    central IL
    That's hilarious bro!! The plus was for tightening screws and the minus was for loosening them, LOL. Hey, if we can't laugh at ourselves, what fun would life be??
  16. #16
    Your thread was moved as it is not a how to but how do you do it thread.
  17. #17
    Mar 2012
    NYC
    thanks for all the input , mesh grille installed....took about 30 min tops........sorry for posting in wrong thread....
  18. #18
    Jan 2009
    Got any pics??
    -Josh
  19. #19
    Very Active Member Captnpirate's Avatar
    Oct 2011
    Port Saint Lucie, Florida
    -Josh
    and can attest to Josh's desire to help others, answer questions and give advise which is the best. It'salso another reson this forum is SO GREAT! He's right, there are no dumb questions and we all have different skill levels from slim to none all the way to the very talented wrench turner (Josh is in the very talented group). With this forum by your side you can enjoy learning about your scoot "hands on" from some of the best.
    Go Big or Go Home
    '07 RED -
    Cycle House Big Air intakes, Debadged/Debeavered, PC III, Kuy grips and pegs, 50 watt driving lights, 260 Metz., sport windshield, chrome wheels, Gen III Knight Rider, Drivers Backrest, Dragon Tail Light, Derby and Side Lic Frame, +2 risers, 5" Cannon.
  20. #20
    May 2012
    Fall River, Mass.
    Quote Originally Posted by mlrman View Post
    The funny part was that I have been around tools all my life and I still came out with that one. Oh well, one of you got a kick out of it! The others must have rolled their eyes! Doesn't change anything. Safe riding!
  21. #21
    Mar 2012
    NYC
    took them with my phone , not the best..Click image for larger version.
  22. #22
    Jan 2009
    Looks good, and it looks like you didn't break anthing in the process. Nice work.
    -Josh
