Results 1 to 17 of 17
Thread: Hard to reach clutch lever????
    Active Member
    Aug 2012
    michigan
    Default Hard to reach clutch lever????
    Is there any fix for the clutch lever being to far to reach comfortably
  2. #2
    Sep 2010
    McPherson, KS
    Stock lever?
  3. #3
    Very Active Member g9r's Avatar
    Aug 2011
    Tennessee / North Carolina Mountains
    Ironically enough during my ride home yesterday I was wondering the same thing, actually wondering how guys with smaller hands use the clutch as it is quite a stretch. (mine are stock)
  4. #4
    Sep 2010
    McPherson, KS
    If there's no adjustment - and I'm assuming that there isn't but since mine already had aftermarket levers on it I don't know that for a fact - then you'll have to grow longer fingers. Sorry, couldn't resist.
  5. #5
    Aug 2007
    Montreal subburb
    What year is your bike ,
    because the shape of the stock levers have changed
    I don't know which year but my 2007 is older model .
    newer model at bottom .
Name:	new clutch levers.jpg
    Every Time You Lift Your Tank Beware Of This .
  6. #6
    Very Active Member BigpapaM109's Avatar
    Oct 2010
    Germantown, MD
    Way go to give your valuable advice there
  7. #7
    MoCo Maryland
    Quote Originally Posted by BigpapaM109 View Post
    Lol would you expect any less.
    Sent from my ultra cool Lightningbolt using Slapatalk
  8. #8
    Very Active Member RUBZERK's Avatar
    Jul 2008
    Lancaster, PA.
    is this you
    "You cant argue with my 9mm..........well you can, but you'll end up bleeding alot"
    RUBZERK = Are You BZERK
  9. #9
    Very Active Member Captnpirate's Avatar
    Oct 2011
    Port Saint Lucie, Florida
    Quote Originally Posted by RUBZERK View Post
    is this you
    Like they say, "Ya gotta have thick skin around these guy's"
    Go Big or Go Home
    '07 RED -
    Cycle House Big Air intakes, Debadged/Debeavered, PC III, Kuy grips and pegs, 50 watt driving lights, 260 Metz., sport windshield, chrome wheels, Gen III Knight Rider, Drivers Backrest, Dragon Tail Light, Derby and Side Lic Frame, +2 risers, 5" Cannon.
  10. #10
    Very Active Member keitho's Avatar
    Feb 2008
    Deltona FL.
    Laughing at some comments here. Make sure you have 2 quarters "coin" gap in the adjustment at the lever. See if that helps. Good luck!
    keitho
  11. #11
    Active Member
    Aug 2012
    michigan
    Default levers
    its a 07 with stock levers thx guys lotsaa love around here i see xoxoxo
  12. #12
    Mar 2007
    West Virginia
    You can try this. I did it years ago and it's not caused any problems. It's just a plastic button, I think they are called canoe clips, stuck in the clutch cable groove. It holds the lever away from the perch enough that the end of the lever is close enough to the bar to make it easier to reach. I still do the two quarters slack in the cable with the button in there.
    Life has no remote control, get up and change it yourself.
  13. #13
    Very Active Member bwl60's Avatar
    Apr 2008
    Las Cruces, New Mexico
    Quote Originally Posted by Kazimodo View Post
    Does the new lever give you more leverage? It looks like the lever is longer from the pivot point. And does the brak lever match the curve of the clutch on the newer one?
  14. #14
    Mar 2007
    West Virginia
    I've looked at them and gave them a pull and I don't think they give you more leverage, but they are closer to the grips. They also have to be used with the perch for them, you can't just swap the levers. The clutch lever matches and is still adjustable.
  15. #15
    Very Active Member cloud9's Avatar
    Jan 2009
    on the 9 houston,tx
    is this you
    ROFLMAO
    CHRISPIN
  16. #16
    Very Active Member holden,on's Avatar
    Mar 2008
    Default um
    you might have to buy a harley they cater for smaller people
  17. #17
    Very Active Member Stika's Avatar
    Sep 2010
    Jax.,FL
    is this you
