Results 1 to 5 of 5
Thread: was i really that dense ?
    Very Active Member Nitrogary's Avatar
    Feb 2011
    Portland Oregon-Natures Natural Sunblock
    Default was i really that dense ?
    I just got a new "throttle Tamer" throttle tube. i thought id just zip apart the right handle controls and undo the cables and slide the tube out and....well, you get the idea !
    HOW IN THE LIVIN HELL DO I GET THESE THROTTLE CABLES OFF THE TUBE...do i have to remove my tank and get down to the throttle bodies and possibly mess up the synchronization or is there another trick to what "I" thought was going to be a 15 minute task ?
    your advice or reality check would be appreciated...
    2007 Black M109R, Metzler 260/160,Debadge/Beav,HK Sideburner,Cobra Power Pro CVT,dropped 2",PC'd wheels,Ducks Cowl with LED's (yes,the rear seat cowl ! ),Kury all around,Holley Intakes,Garmin,2" Risers,Driver Backrest, Jardine Quick release billet backrest,Tach relocate,Odyssey battery, YS side plate,Alarm,V-stream sport, Factory engine guards, matuza GA bags on ghost brackets, Throttle tamer, jt's night rider. Gel seat, more to come
  2. #2
    Very Active Member BAD BOY M109R's Avatar
    Harwood Mo. (SW)
    loosing up the cables all the way there at the controller should give you enough slack to take them off...
    BONE STOCK
  3. #3
    Feb 2011
    Quote Originally Posted by BAD BOY M109R View Post
    i only think i saw one part theat may looosen/tighten one cable. will this in fact take care of both ?
  4. #4
    Rockdale, Texas
    Yes it will allow you to twist the throttle and pull one cable and then the other one will come out easy.
  5. #5
    Feb 2011
    Quote Originally Posted by antmor69 View Post
    thanks tony, ill give it another shot tonight after work
