Results 1 to 22 of 22
Thread: Spark Plugs WTF
    Very Active Member Kevin Nyberg's Avatar
    Apr 2009
    Cadillac,Michigan
    Default Spark Plugs WTF
    Well I found out why the nine wouldn't start, Spark Plugs!!! 10000 miles on them and 3 of the 4 were burned right up. The dealer says all the big bore stuff is having trouble with spark plugs on the gasoline their producing these days. I don't know if its true or not but he say the premium is staying in the underground tanks to long because there isn't as much demand anymore for something that pricey. So the premium your buying is what he called "stale"
    He said the big bore stuff is having the most problem with it and burning the plugs up faster. Just what I was told, don't shoot the messenger.
    So running a little more of the Startron additive might be a good idea to help the fuel start crisp as fresh lettuce.......
  2. #2
    MoCo Maryland
    can you post pics of the plugs? 10K seem very low mileage to be worn out to a point of not starting
  3. #3
    Very Active Member BAD BOY M109R's Avatar
    Harwood Mo. (SW)
    yea pics. mine had 17000+ on mine and they did not look bad at all could tell was running a little rich but not bad at all...
    BONE STOCK
  4. #4
    Very Active Member Nitrogary's Avatar
    Feb 2011
    Portland Oregon-Natures Natural Sunblock
    WOW, burnt plugs at 10k ? first ive heard of that....since ive been on this forum !
    2007 Black M109R, Metzler 260/160,Debadge/Beav,HK Sideburner,Cobra Power Pro CVT,dropped 2",PC'd wheels,Ducks Cowl with LED's (yes,the rear seat cowl ! ),Kury all around,Holley Intakes,Garmin,2" Risers,Driver Backrest, Jardine Quick release billet backrest,Tach relocate,Odyssey battery, YS side plate,Alarm,V-stream sport, Factory engine guards, matuza GA bags on ghost brackets, Throttle tamer, jt's night rider. Gel seat, more to come
  5. #5
    Apr 2009
    Cadillac,Michigan
    Default No plugs
    I didn't get the plugs back but boy what a difference in the nine it made, I get close to that start button and the nine is running. I drove it back home and its running like a top. I have been using alot of Shell premium and Shell Midgrade switching back and forth, refilling with premium and then refilling with midgrade the next time. My nine was running rich, I ride with a guy thats a pretty good tuner and he always said when he got behind my nine that it was definitely running on the rich side. I do know my nine wouldn't start and all they did to it was put in new plugs. It hasn't started this good for quite a while. So I believe what they told me to be the truth......
  6. #6
    Active Member
    Jul 2012
    Elgin, IL
    I thought they were platinum plugs? I may be wrong but thats very odd for any non copper plug...I always run 1.5 gals of 104 and the rest premium to make it run smoother and...i just like the smell LOLI am curious about my plugs now...
    2011 Indy Blue As Stock as Stock could be...minus the baffles
  7. #7
    Very Active Member lincoln1003's Avatar
    Jun 2010
    Little Falls, MN
    watch for the gas guy at the station and ask him how often they bring it in and shop at the one that sells the most.
    loves truck stop in fargo, nd gets a few thousand gals a week
    08 109 Candy Max Orange, Vance & hines Big shots and fuelpak, Arlen Ness big suckers, debeaved
  8. #8
    Sep 2010
    McPherson, KS
    Use 87 octane and you'll get fresher fuel. That's all I put in and no pings with standard heat platinum plugs.
  9. #9
    Very Active Member jimmy450r's Avatar
    Nov 2007
    Eastern Kansas
    I think the 9 has iridium spark plugs
  10. #10
    Rockdale, Texas
    Quote Originally Posted by jimmy450r View Post
    Not from the factory.
  11. #11
    Very Active Member keitho's Avatar
    Feb 2008
    Deltona FL.
    I agree that you will get fresher fuel buying 87 octane but the manual says run at least 90 octane. Wish mine would run on that but I still get pinging "spark knock" running 93 octane. Not a fan of ethanol!
    keitho
  12. #12
    Very Active Member fatboy99's Avatar
    Jul 2012
    Cashville, Tn
    I would stick to high octane... spark knocking/ detonating very very bad. burnt plugs makes me think lean mixture and hard starting
  13. #13
    Sep 2010
    McPherson, KS
    I was in error. They are iridium but they don't come stock.
  14. #14
    Sep 2010
    McPherson, KS
    Quote Originally Posted by keitho View Post
    The addition of ethanol actually raises the octane rating a few points (89 versus 87). However, it has a little less energy than gas.
  15. #15
    MoCo Maryland
    Let's book mark this day in history!!
  16. #16
    Aug 2006
    I don't know, my regular ol' NGKs have over 10K on them and the bike runs perfectly....
  17. #17
    Sep 2010
    McPherson, KS
    Maybe you should go find something to do, like work.
  18. #18
    Apr 2009
    Cadillac,Michigan
    Default COBRA POWER PRO
    I am thinking that my nine needs a power pro, it has OEM NGK's in it and the first set was fine but since then I have drilled out the baffles in the pipes and I think that threw me farther into a lean condition, thats why the plugs only lasted 10,000 miles. So its looking like I have to spend some money and get a fuel manager into it to monitor the amounts of fuel. I can't think of any other reason, I use top of the line shell gas in a station that has a large volume of customers and should be turning over its fuel supply at a fairly good rate. I think on the next set of plugs I would or should put in platinums because they handle the ethanol better than the stock NGK's. Well if anyone tells you that you can just drill your pipes with out changing anything else, that you don't need to put a fuel managment system in, I am living proof that that is a big pile of horsesh*t. If your change anything on this nine air intakes,drill your pipes, you have change the system and need a fuel manager and then you won't produce the lean condition that burns up spark plugs in 10,000 miles
  19. #19
    MoCo Maryland
    Why, it's more fun hounding you!!
  20. #20
    Apr 2009
    Cadillac,Michigan
    Default Be Nice Bernie
    Your supposed to work and play well with others, Not creat riffs in communication, and alway remember everyone is entitled to their opinion even if it doesn't agree with yours. Now shake hands and be well with each other..... your communication police force at work......
  21. #21
    MoCo Maryland
    Quote Originally Posted by Kevin Nyberg View Post
    Me, play well w/ Tbag, NEVER!!!!
  22. #22
    Aug 2006
    It has been said many times in this site these bikes come from the factory running lean, so I agree...in fact, a bone stock 9 would probably run better with a fuel manager...
