I finally got around to getting the 9 dynoed Friday. Here are my baseline results!
2011 Suzuki M109R Dyno Stock - YouTube
For sure man! Once I get this exhaust problem squared away I'll be able to start removing emissions equipment and adding performance parts!
That AFR is really messed up.
I agree, it looks TOO LEAN!
That's California for you, I need more FUEL!!!!!
Now throw a power pro on it and re dyno it
BONE STOCK
That would be a great service to us right now!
I was planning on making a poll to see if everyone wanted me to dyno an exhaust and then with a tuner or the tuner and then with an exhaust. Sounds to me like we want to see what the tuner does on its own?
If you can afford to do it in steps, would be awesome
That's the plan! Thing is once I put something on, whether it be a tuner or an exhaust, it's on and I don't want to take it back off to get a dyno of just the other mod. That's why I was thinking of taking a poll, it doesn't matter to me what goes on first!
We'd just be happy to see your info. Greatfull for your help on these issues that from time to time pop up.
Either one first I think wouldn't matter. Lest see what everyone else's says.
The object of war is not to die for your country, but to make the other bastard die for his.
Since you have done a stock run and do not have intakes, then do the exhaust first. By doing the exhaust first, you gain the info of knowing what it has done by bolting it on and knowledge of the what the A/F ratio is. Then afterwards when you do the tuner, you will gain info over all that was previously done and any additional gains. In the reverse order, you get zero info of what the exhaust was useful for. Just my opinion.
I vote #2 also.
I think a lot of us would love to see just what the PP does by itself.
^^^This sounds like it makes so much more sense.^^^ For one, I read somewhere, and I will try to find it, that the PP by itself does not add anything to the equation, it just tunes. So, if that is the case, I don't know what kind of results would people expect to get from testing it by itself.
If you've got the time and the luxury of access to the dyno, then I say do this:
Stock (which you've already done)
Stock w/PP
Intakes w/PP (throw in some K&N's)
Put stock filters back in, swap exhaust, w/PP
Intake and exhaust w/PP.
That way, you can see what gains each mod makes, and the intake filters are easier to swap out then the exhaust.
-Josh
Would also like to see 3 consecutive runs. with just the PP.
