My clock resets when I turn off the ignition switch. Has anyone had this problem & what can I do to repair it?
Yep, had the same issue. The battery was at the end of its life. Replaced battery and havent had an issue yet. If you have the stock battery still, don'y know what year 9 you have, you may want to check it out. Don't want to get stranded.
Check your battery connections also, if there tight then see statement above.
Thanks guys, your the best! Thats why I like this forum!
