Results 1 to 12 of 12
Thread: guys running metzler 160 need help
    Very Active Member jeffrey's Avatar
    Aug 2011
    endicott, ny
    Default guys running metzler 160 need help
    hey fellas im replacing my stock tires and im going with the mezt 260 and was thinking of doing the metz 160 up front and have two questions one is that a good combo in sizes?? and two when im looking at these mezt the only 160-60r18 i found said it was a reinforced one where the 260 is just a regular ME880. is that the correct one i should be buying? and just a recheck i have to put that front on in reverse correct.... thanks again guys
    Active Member joker07's Avatar
    Jun 2011
    va beach
    Default 160
    yes run it backwards just did mine love it
    Very Active Member gottattooz's Avatar
    Site Co-Sponsor, Zephyrhills, FL
    Quote Originally Posted by jeffrey View Post
    The Metzeler is a Marathon ME880 160/60VR18. The 160/260 combo is awesome.
    -Josh
    Active Member busato9's Avatar
    Aug 2012
    Baltimore, Maryland
    Will the 160 fit stock rim and what do you have to do to the front fender?
    Very Active Member Larry L's Avatar
    Copperas Cove, Texas
    Quote Originally Posted by busato9 View Post
    Yes it will. As far as fender, you do not need any modification to it but I would suggest to get some fender extensions for it as if you pick up a rock, it makes one heck of a noise & eventually can crack the fender. Do a search for them. Several people make them.
    Good luck👍
    Sent from my super cool iPhone using Tapatalk
    ISO Grips, Breakaway Cruise control, PC-V, K&N Filters, Skythe Mirrors, Gipro ATRE, Cobra Swept exhaust, Sumo-X Side mount, D2Moto tail light with turn signals, Arnott Air Ride.
    Looking to win lottery for more mods.
    Aug 2012
    Baltimore, Maryland
    Thanks for the advice. If I put a 260 on the rear and run the stock on front would that upset the balance to much?
    Aug 2011
    endicott, ny
    ive asked this before and i was told its still rides good
    Aug 2008
    cordova tn
    Default 160 front
    I just had the 160 tire put on, and it looks good, and I used no extensions. The tire was also mounted in reverse. Some say reverse, some say not. You make the call on the extensions and which way you want to have it mounted.
    Very Active Member She's real fine my 109's Avatar
    Westport Massachusetts
    Try the 140/ up front. It rides better then the stock 130/. The 140/ is lots more stable.
    What other people think of you is none of your business.
    May 2009
    Toronto, Canada
    Why backward, please clarifiocation, as I will do it soon as well.
    thanks
    Bob
    Quote Originally Posted by joker07 View Post
    Very Active Member Bujee1's Avatar
    Los Angeles, Ca
    I've been running the Metz 880 vr 160/260 combo for 12,000 miles now and I will never go back. (I picked up a nail so I'm on my second 260.) I have not made any modifications to the fender. I simply loosened the fender bolts, stuck a wedge under the back of the fender between it and the tire and re tightened them. It seems to give me enough room for the occasional pebble, should I run across one. I don't think I have, though.
    Oh yeah, run it backwards because it is a rear tire designed to be strongest with acceleration. Front tires are strongest with deceleration( braking). So turn it around when you put it on the front. Makes no difference in the tread pattern anyway from a standard 130 Metz. Of course, no one has had a failure from running it front ways either, your call.
    2008 Candy Max Orange,Chrome wheels, Debadged,poorman's debeaver,Garmin 765T GPS, V-Stream Touring windshield, Corbin Seat, OEM Engine guards,Metz 160/60 front 260/40 rear,Chrome Stebel air horn, Jardine QD Luggage rack and backrest,Orange LEDs
    By bujee1 at 2010-07-07
    Very Active Member OUTLAW's Avatar
    Oak Ridge, TN
    Just installed Metzeler 160/260 combo. Did it myself with Dynabeads and 260 with reversed direction of rotation. No change to fender. 200 miles later and I love it !!!!!
    07 Black M109R, Full cut Suz Gel Seat, CW Drivers backrest, Forward pegs, Breakaway Cruize Control, GI-PRO Blue, 2 inch risers, 2.25 lowering bones, Techmount radar det mnt, Tach relocate, alarm, debeavered, debadged, debitched
